LED lights not working. Need Help.
Discussion in 'Lighting' started by Mexican Papi, Jan 26, 2025.
  1. Jan 26, 2025 at 4:03 PM
    Mexican Papi
    Mexican Papi [OP] New Member
    2023 Tundra SR5
    Tonneau Cover for now.
  2. Jan 26, 2025 at 4:10 PM
    Just replied to the other post. Of the fuse is good and you mare getting 12 volts, I would try a different grounding spot.
  3. Jan 26, 2025 at 4:12 PM
    j_supra
    j_supra Dreamin about boooost!
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    Proper ground? Polarity correct? Led lights are polarity sensitive so sometimes when they don't work, flip the wires around.
    Johnsonman likes this.
  4. Jan 26, 2025 at 4:14 PM
    Mexican Papi
    2023 Tundra SR5
    For the fuse I’ve tried 1 Amp, 5, 10, 15, 20, 30. All worked. I was starting to wonder about the ground. Where is a good spot to ground on the 2023? It’s not so obvious.
  5. Jan 26, 2025 at 4:15 PM
    Mexican Papi
    2023 Tundra SR5
    flip the wires around? So black with red and read with black. Like that? I went positive(red) to positive on the battery and negative to negative directly and the lights turned on. With that said would you still think polarity issue?
  6. Jan 26, 2025 at 4:19 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    Ok good. Then no polarity issue. I'd test your ground source with multimeter. Power lead to the power wire you ran out back and ground lead to where you have the leds grounded. Should have battery voltage. If you don't, try a different ground source. If you do have battery voltage, could be faulty leds. Retest directly on battery to confirm.
  7. Jan 26, 2025 at 4:25 PM
    Mexican Papi
    2023 Tundra SR5
    I retested directly on battery again and they work. I think it’s the ground I’m just not sure where a good spot for grounding is.
  8. Jan 26, 2025 at 4:28 PM
    Mexican Papi
    2023 Tundra SR5
    where is a good grounding spot?
  9. Jan 26, 2025 at 4:28 PM
    Any bolt on the frame or unpainted surface should work.
  10. Jan 27, 2025 at 5:31 AM
    Mexican Papi
    2023 Tundra SR5
    so it was a bad ground connection. Found a better spot to ground and it worked just fine. Thank you and thank you everyone for the help.
    Tundra234[QUOTED] likes this.
