LED Light Bar install
Discussion in '2.5 Gen Tundras (2014-2021)' started by callymanjrod, Jul 15, 2018.
  1. Jul 15, 2018 at 6:50 AM
    callymanjrod
    callymanjrod [OP] New Member
    Jared
    Surprise
    2017 Tundra Crewmax SR5 MGM
    Raptor grille, spyder head and tail lights, LED all interior/exterior lighting, led third brake light, Pioneer mixtrax touch screen, AFe exhaust and K&N intake. 4” lift, front and rear TRD sway bars, LED bumper light-bar, LineX color match bumpers.
    Need your help guys. So, I ordered an LED light bar online that came with all the pre-wiring, blade fuse, relay and a 5 pin rocker switch which I thought would fit perfectly since “it said it would” but it’s not even close. I didn’t want to cut the dash so now I’m left searching for a 5 pin rocker switch that fits. Are there any suggestions? I’ve looked everywhere and the only thing I’ve found is the Toyota S Push button which has a different wiring set up and I’m not the most electrically inclined. Any help is appreciated. Thanks in advance!
  2. Jul 15, 2018 at 6:53 AM
    callymanjrod
    Jared
    Surprise
    Here is a picture of what they sent me.
  3. Jul 15, 2018 at 7:20 AM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    This is my best guess as to why you have a 5 pin switch. Do you have a multi-meter or plain old volt meter? 20180715_071550.jpg
    Erichudgins likes this.
  4. Jul 15, 2018 at 7:22 AM
    nishibot
    Perris, CA.
    Also what's on the other end of the harness?
  5. Jul 15, 2018 at 7:54 AM
    callymanjrod
    Jared
    Surprise
    Here is what I have,
    3567C887-556D-49F0-BA0D-B3EF876A3F91.jpg E6F1A9E0-D7B8-4E7D-8DF7-9654575B854B.jpg 903C4329-3974-474D-A607-9C908670B7DB.jpg
  6. Jul 15, 2018 at 7:57 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
  7. Jul 15, 2018 at 8:06 AM
    callymanjrod
    Jared
    Surprise
  8. Jul 15, 2018 at 10:31 AM
    nishibot
    Perris, CA.
    Where are you located? Maybe another member can help you out if close? Do you have the instructions that came with bar? Wiring diagram?
  9. Jul 15, 2018 at 11:13 AM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Exactly. Whites are power to switch and switch illumination when switch is on on position.. blue wire supplies power to bar when in on position. Black wires are all grounded by the lead in your hand with the power wire and in line fuse
    nishibot[QUOTED] likes this.
  10. Jul 15, 2018 at 3:09 PM
    callymanjrod
    Jared
    Surprise
    Got it, okay so I’ve ordered a different push switch that fits the Tundra through air on board and it has basically the same set up I’ll just need to strip the black white and blue from the connector and connect to the switch so when it gets here I’ll just use the diagram that NewImprovedRon uploaded and see. 74F0D954-76D7-467B-95F1-274B68CF06A6.jpg 73938117-B4B4-42BD-866B-BF58E7165613.jpg
    Erichudgins[QUOTED] likes this.
  11. Aug 6, 2018 at 9:01 PM
    callymanjrod
    Jared
    Surprise
    Update: LED Lightbar install is finally done. I had some free time and it worked out perfectly with the new switch. Pretty easy when you have the right equipment! I also had the bumpers paint matched in LineX coating and it turned out awesome I think! Thanks for your help guys!
    GAknight, pdiddy, JoshuaA and 4 others like this.
  12. Aug 6, 2018 at 9:31 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Looks good.
    callymanjrod[OP] likes this.
  13. Aug 6, 2018 at 9:50 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Line-X bumpers look good. Nice job getting the LED light bar done!
  14. Aug 10, 2018 at 9:15 AM
    dmking8
    dmking8 New Member
    DAVID
    Great looking truck! I'm about to get a MGM Tundra Crewmax myself and I'm gathering ideas for what to do to it. What type of lift/level are you running and what size tires are those?
  15. Aug 10, 2018 at 9:19 AM
    Sandbox
    Sandbox New Member
    Canada
    2017 White TRD Pro Crewmax
    Very nice! looks clean, any trimming needing to be done to put the lightbar in that location? how is it mounted? link to the light bar?
  16. Aug 10, 2018 at 9:27 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    To piggyback on this, if I'm installing a second light bar that has the same switch style do I tap all 3 wires that run between the relay and the switch? Or tap only the blue and black and cap off the white since there's not a second switch to illuminate?
  17. Aug 10, 2018 at 9:48 AM
    callymanjrod
    Jared
    Surprise
    The lift is only about 4” it’s really just a leveling kit purchased through Rough Country. https://www.roughcountry.com/toyota-suspension-lift-kit-76720.html Tires are 33”
  18. Aug 10, 2018 at 10:07 AM
    callymanjrod
    Jared
    Surprise
    Thanks! Yeah I trimmed the inside of the plastic cover with just a small saw. The brackets are attached directly to the frame. Here’s the YouTube video I followed: https://youtu.be/OiWmoD-JyBs
  19. Aug 10, 2018 at 10:38 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Exactly. If no illumination, no wire should be tapped. At that point your just going to have a single power and the one wire that actually powers the light bar.
  20. Aug 10, 2018 at 3:26 PM
    Sandbox
    Sandbox New Member
    Canada
    thanks for that! what length bar is that? 30"? does anyone know if the Baja Designs bar fits in that space?
  21. Aug 10, 2018 at 3:40 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Looks good!what brand bar did you use?lumens?any pics of output?
  22. Aug 10, 2018 at 5:42 PM
    callymanjrod
    Jared
    Surprise
    Yeah it’s a 30” I’m not sure about the height of the Baja light bar but you only have like 1 3/4” space to work with.
  23. Aug 10, 2018 at 5:58 PM
    callymanjrod
    Jared
    Surprise
    So I just got a cree light bar that puts out about 15000 lumens flood/spot combo, it’s brighter than I was even expecting! It was only $75. I may change it later but for now I just couldn’t bring myself to spend $400-$900 on something by rigid or anyone else that does the same thing I was looking for. When it gets dark I’ll post some pics of output.
    philly likes this.
  24. Aug 10, 2018 at 6:17 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Mine are both wired off one switch. I good not imagine a situation where I would just want one bar on. Just tapped in to the trigger wire from switch to trigger on second relay.
  25. Aug 11, 2018 at 12:37 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Any heat issues if you leave them om for extended periods of time? Ive ran vali raised bars and have had great luck with them and great outout as well.been thinking about the same setup as you stumpjumper....samw grille even lmao.....B
  26. Aug 11, 2018 at 1:24 PM
    belanger9
    Edmonton, AB
    A bunch
    Thanks, I'm thinking of putting the rough country bumper light in addition to my hood bulge light and like second opinions on how to do truck wiring
  27. Aug 11, 2018 at 6:40 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Nope, I have 2 relays and separate power leads to each bar
  28. Aug 13, 2018 at 9:09 PM
    Adrwshry
    Adrwshry New Member
    2018 Tundra TRD Sport DCLB
    Where are you mounting your switch?
  29. Aug 14, 2018 at 4:36 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Mounted mine left of steering wheel
  30. Nov 9, 2020 at 4:58 PM
    SkoBuffs22
    SkoBuffs22 New Member
    What brand is your lower bumper one? I like that it installs behind the factory bumper without having to cut anything
