LED hyper flash problem
Discussion in 'Lighting' started by Kripple, Jan 28, 2018.
  1. Apr 26, 2018 at 5:35 AM
    atxtundra
    atxtundra New Member
    I know I’m connected to the right wires because I had retros hooked up before which used an led strip, and the same resistors fixed the hyperflash for those. I’ll try again tonight. The resistors are 6ohm.
  2. Apr 26, 2018 at 5:56 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    If the retros used LED strips for the turn signal and this was the only LED in the turn signal circuit (considering front and back) on each side, then 6 ohms is appropriate. If this LED strip was the turn signal for the front and there is another LED in the turn signal in the back, then 3 ohms is appropriate. There may be some characteristic of the switchback that is different from the retro causing the issue or a connection issue.
  3. Apr 26, 2018 at 2:45 PM
    Alptbird
    Alptbird SR5, Limited, TRD, Mutt.
    Glen
    Houston Tx
    2016 crew max SR5
    Too many to list, I actually have an excel spread sheet!
    Okay. Call me crazy. But take the 6 ohm you have in out. If for some reason the cheepy Amazon lights have a 6 ohm load and you have a 6 ohm resistor and a normal bulb. The circuit impedance is 2 ohms and your hyper flash condition would be because of too low resistance
  4. Nov 14, 2018 at 8:14 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    @atxtundra Did you figure out the resistance issue. I want to run the same thing (LED DRL with my led spyder rear taillights) Thank you in advance.
  5. Nov 14, 2018 at 10:45 PM
    atxtundra
    Sorry dude. I sold the retros and went with 2018 LED headlights.
    The problem never went away and left me stumped since it worked fine with the led strip switchback but not the bulb. :shrug:
    tinman10101[QUOTED] likes this.
  6. Jul 16, 2019 at 6:37 AM
    Gryphon1721
    Gryphon1721 New Member
    2012 Tundra TSS
    Ok so I'm new to changing light bulbs. I've tried to different sets of LED turn signals. I have the load resistors attached. They seem to work fine when my headlights are off, but the minute I turn my headlights on I get a hyperflash. 2012 CM. Any ideas what could be causing this?
  7. Jul 16, 2019 at 7:08 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Im late to the party ...
    My Wife's 2004 Sequoia has hyperflash problems with the LEDS i installed.
    Is there an inline resistor available?
    Thx
  8. Aug 6, 2019 at 9:35 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Which bulbs are you running?
  9. Aug 9, 2019 at 9:45 AM
    TRD-tv
    TRD-tv New Member
    OHIO
    2012 MGM Tundra TRD
    Woah
    Tundyfundy likes this.
  10. Sep 11, 2019 at 1:54 PM
    Sgtwheats
    Sgtwheats New Member
    Justin
    09 silver tundra
    Lift, exhaust, CAI
    I found my 09 Tundra for all 4 turn signal bulbs switched to LED is if you solder In 0.15 ohm resistors in place of the metal bars in the flasher relay you get no hyper flash and no need to use load resistors. If you do this mod when soldering in the resistors leave about inch of the leads above the board. Here is link to the resistors I used.
    https://www.amazon.com/gp/aw/d/B07KS329FT?psc=1&ref=ppx_pop_mob_b_asin_title
    careyrob likes this.
  11. Sep 24, 2019 at 1:43 AM
    Bauldin
    Bauldin New Member
    2014 Tundra Limited
    Did you have any success resolving this issue? I have the same issue with my truck.
  12. Sep 24, 2019 at 3:10 AM
    Tundyfundy
    Bay Area, CA
    The vled switchback harness is tricky. There is a specific way you need to connect it. It seems intuitive but it’s not. Check the wiring diagram on the vled site... I had this problem and when I called vled they sent me the wiring diagram and it worked perfect.
  13. Sep 27, 2019 at 2:44 PM
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    I just purchased the 2019 trd pro led headlights is it 7443 now for the front turns do I need the ck or no
  14. Jun 15, 2020 at 9:45 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    So pretty much what your saying is, if you have LED bulbs on both the front and rear, then you need 3ohm resistors, otherwise 6ohm resistors?
  15. Jun 15, 2020 at 9:50 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Also, "rear" refers to LED brake lights or reverse lights?
  16. Nov 22, 2020 at 8:48 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Has anyone else tried this?
    Chrslefty likes this.
  17. Nov 22, 2020 at 11:09 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    I’m wondering also ..read the entire thread but it’s like in language I dont understand. I have AlphaRex front & rear Aftermarket lights. Now I have the annoying hyper flash problem. Obviously I now need resistors...so the 3 or 6? Can someone post a link of them?
  18. Dec 6, 2020 at 6:19 PM
    Chrslefty
    Chrslefty New Member
    08 dubble cab
    Or more information about it.
    @Sgtwheats
  19. Dec 8, 2020 at 5:37 PM
    #49
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Alright so I got resistors now that Alpha Rex company set. Nooooow to install in tail lights which colored wires in rear am I tapping into?! Anyone?!
  20. Sep 10, 2021 at 12:31 PM
    #50
    Ders
    Ders Washington
    Washington
    2014 Tundra
    MKW Chrome Off-Road Wheels 275/65R20 Tires Bilstein 5100 Middle Setting In the Front, 1/2 Block in the Rear Highway Products Gull Wing with Roof Rack Tracks Protech lumber rack LED headlight and foglight bulbs 30% Front window tints Boost Auto Tow Mirrors
    I realize this is old. But I did try this on my 2014 and it worked like a charm. F71C7D15-0CAC-423F-BF44-C5C7221EA2A2.jpg
  21. Sep 10, 2021 at 12:32 PM
    #51
    Ders
    Ders Washington
    Washington
    2014 Tundra
    i do have a platinum so the front signal does not function as a running light. I don’t know if that will make a difference or not.
  22. Oct 30, 2021 at 10:07 PM
    #52
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    Have either of you hooked up to a trailer to see what happens? I’m interested to know if the extra load from trailer bulbs will cause some sort of an issue.
  23. Oct 31, 2021 at 6:13 AM
    #53
    Ders
    Ders Washington
    Washington
    2014 Tundra
    Yep. i tow my travel trailer. No issues
  24. Oct 31, 2021 at 9:59 AM
    #54
    Redline870
    Ian
    Central NY
    Thanks for the quick response! I like the idea of using this method instead of the load resistors only because I don’t like cutting into the factory wiring if I can avoid it.
    The lights in your trailer, are they LED or incandescent bulbs?
  25. Nov 1, 2021 at 1:55 PM
    #55
    Ders
    Ders Washington
    Washington
    2014 Tundra
    That’s the same reason I did it.
    it has incandescent bulbs. It shouldn't make a difference. I don’t think your truck checks trailer turn signal load like it does for turn signals on the truck.
    Redline870 likes this.
  26. Nov 1, 2021 at 4:18 PM
    #56
    Redline870
    Ian
    Central NY
    Cool thanks for all the info. Much appreciated!
  27. Nov 17, 2021 at 8:05 PM
    #57
    Redline870
    Ian
    Central NY
    I went to do this mod today but the 2021 doesn’t have this flasher relay. I tried 6ohm 50W load resistors which weren’t enough for 2 LED replacement lights. I would still get hyperflash. I’ve ordered some 3ohm 50W load resistors to try out as it said on the VLED’s site that I’d need 3ohm resistors for multiple LED lights.
  28. Nov 17, 2021 at 9:00 PM
    #58
    Ders
    Ders Washington
    Washington
    2014 Tundra
    Maybe the flasher relay is different in the models that come with factory LED headlights. It must have a flasher relay somewhere though. If you turn the signals on you could try and locate where the clicking noise comes from, that would be the relay.
  29. Nov 17, 2021 at 9:08 PM
    #59
    Redline870
    Ian
    Central NY
    It’s computer controlled by the BCM I think, you can hear the noise from that area but I don’t think there’s any relay or module. You can tell this because if you put the flasher stalk in the down or up position and press the start button twice, the first several seconds of flashing is completely silent in the cab while the ignition beeping is occurring. It only starts making an audible ticking sound once all the ignition beeping has stopped. If it were controlled by a mechanical or thermal flasher relay, it would make the noise all the time. The noise is definitely coming from that same area, but there’s no module to be found.
  30. Nov 22, 2021 at 8:06 AM
    #60
    TOY4TKK
    TOY4TKK New Member
    2016, Silver Tundra TRD OFF ROAD
    Trailer light work normal.
