LED headlight upgrade
Discussion in '2.5 Gen Tundras (2014-2021)' started by NewRider, May 6, 2022.
  1. May 6, 2022 at 4:30 AM
    NewRider
    NewRider [OP] New Member
    Travis
    Roaming the Shenandoah's
    2014 Tundra Limited Crew cab w/Flatbed
    Flatbed
    I have a 2014 Limited and would like to upgrade to LED but don’t want to lose the adjustment feature of the stock setup as I tow often.
    mos there a lot on here anywhere or what are the suggestions??
  2. May 6, 2022 at 4:37 AM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    If you just replace the bulbs with LEDS you do not lose the adjustment.
    Some new housing replacements also have the adjustment in them.
    I suggest. Headlightrevolution.com and VLEDS.com
    I have bought LEDs from both.
    Taco-Spike likes this.
  3. May 6, 2022 at 4:38 AM
    OEM leds or the way more expensive Morimoto XB's.
  4. May 6, 2022 at 4:58 AM
    PermaFrostTRD
    Northern NY
    OEM + @iHacker wiring harness is the business. :thumbsup:
    STR1, doggunner, bwlsn13 and 3 others like this.
  5. May 6, 2022 at 5:35 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Second recommendation for @iHacker.
    I talked to him recently about swapping mine to LEDs out have been dragging my feet. He really knows his stuff.
    He can build you an almost fully plug and play harness for a very reasonable cost. Then you can just purchase a set of new OEM LED headlights and be good to go with a few hours work to install.
    bwlsn13, iHacker and Taco-Spike like this.
  6. May 6, 2022 at 6:26 AM
    Taco-Spike
    Two Trucks
    X3 for iHacker and OEM LED
    STR1 likes this.
  7. May 6, 2022 at 6:39 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    OEM LED and ihacker harness is the way to go. Good light output and super reliable. And you keep the height adjustment feature. I had a 2014 and can confirm that this works with no issue whatsoever.
    huntsonora, NewRider[OP] and Sumo91 like this.
  8. May 6, 2022 at 10:31 AM
    NewRider
    Travis
    Flatbed
    Thanks y’all! The truck came with somebody’s aftermarket LED modification. LED bulbs and standard housings just absolutely suck! So I’m ready to upgrade and it looks like that’s what I’ll do.
  9. May 6, 2022 at 10:32 AM
    NewRider
    Travis
    Flatbed
    Anyone have a link to those OEM headlights?
  10. May 6, 2022 at 10:48 AM
    Taco-Spike
    Two Trucks
  11. May 6, 2022 at 10:53 AM
    PermaFrostTRD
    Northern NY
    STR1, NewRider[QUOTED][OP] and WFD473 like this.
  12. May 6, 2022 at 10:54 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Same. Works perfectly!
  13. May 6, 2022 at 10:56 AM
    BlacknWhite23
    BlacknWhite23 New Member
    2021 Black TRD Off Road
    Good luck and hope you get the OE LED's, they do a wonderfull job on my truck. I have put led's in none led housing and it is garbage.
  14. Feb 12, 2024 at 11:37 AM
    beaverPilot89
    beaverPilot89 New Member
    Looks like the price on the OEM headlights on is:
    811100c210 - 296$
    811100c211 - 301$
    Has anyone found these a bit cheaper? or is this about right
  15. Feb 12, 2024 at 12:47 PM
    You won't find them cheaper. @iHacker can get you set up with the harness.
