LED Headlight Conversion Help
Discussion in 'Lighting' started by TigOlTundra, Jun 27, 2020.
  1. Jun 27, 2020 at 8:10 AM
    TigOlTundra
    TigOlTundra [OP] New Member
    Tig
    New Hampshire
    2010 SR5 TRD Off-Road, DC 4.6L Slate Metalic
    Hypertech Interceptor, Old Man Emu 612 Front Coilovers and Rear Sport Nitrocharger Shocks, Mamba M19 Wheels, Falken Wildpeak AT3W Tires, Tyger Auto Blades, EAG Grill with lights, DNA Motoring LED/DRL Smoked Headlights, Tubro SII LED Highs and Lows, DTMoto LED Tube Smoked Tail/Brakelights, Alla Lighting Rear Signal LEDs and Reverse LEDs, Note Smoked Third Brake/Cargo light, Plasti-dipped badges, Back-rack, Husky X-Act Contour Floor Liners, OEM Rear Underseat Storage, Colormatched Land Cruiser "Toyota" Grill Badge
    Hey all,
    So I wanted to change the highs and lows to LEDs to match the DRL bars on my new headlights but I am not sure if it is as plug and play as I would hope.
    The bulbs that are currently in are stock as far as I know. 2010 SR5 Trd offroad.
    I bought these from Amazon.
    My question is whether it is a straight swap or not before I get going. They dont come with any resistors or anything and I dont know much about electrical but from what I have seen, a lot of conversion kits come with resistors or ballasts. Should I buy some resistors that are compatible with these new LEDs? If so could someone point me in the right direction as to which ones?
    Any help would be greatly appreciated.
  2. Jun 27, 2020 at 8:21 AM
    PhysicZ
    PhysicZ 1g3
    Robert
    2013 MGM Tundra crewmax
    Just changed mine in my 2013, was plug and play. Easy
    TigOlTundra [OP] likes this.
  3. Jun 27, 2020 at 8:23 AM
    PhysicZ
    PhysicZ 1g3
    Robert
  4. Jun 27, 2020 at 12:31 PM
    TigOlTundra
    Tig
    New Hampshire
    See the video you posted he has a Ballast for the LEDs. My question is whether I need resistors or ballasts as the Torchbeams T2 LED highs and lows that I bought do not have them. The harness that is on them is indeed plug and play but its not so much a conversion kit, just new bulbs and hardwired plugs that for my tundra.
  5. Jun 27, 2020 at 12:37 PM
    PhysicZ
    PhysicZ 1g3
    Robert
    I clicked on amazon link, it says it doesnt fit my 2013 tundra? Maybe wrong size ,this is what I got, came wit little ballist
    Check this out at Amazon.com
    Fahren H11/H9/H8 LED Headlight Bulbs, 60W 10000 Lumens Super Bright LED Headlights Conversion Kit 6500K Cool White IP68 Waterproof, Pack of 2 https://www.amazon.com/dp/B07NPMV1H5/ref=cm_sw_r_other_apa_i_4-59Eb9GZZJH2
  6. Jun 27, 2020 at 12:57 PM
    TigOlTundra
    Tig
    New Hampshire
    Yeah I should have done more research I guess. On one of the pictures for the ones I got it says "built in driver", so I assume that it is similar to the external balasts on the harness for other LEDs. I think I will attempt the plug and play tomorrow and see how it goes. If there is flickering or any other issues I guess I will revisit the issue. I appreciate the help.
    If anyone else has any other input please feel free.
  7. Jul 3, 2020 at 10:50 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    I just converted my headlamps, backup lamps and interiors to LED. all work fine without resistors. i have the LED front turn signals on order, also with 50w 6 ohm resistors from Amazon. Only blinking LED's need resistors or they blink rapidly . LED's make a HUGE difference on my 04 dc from the dull yellow lamps it had. I will be moving onto rear LED turn signals next and got the 4pack of resistors in anticipation. Cant wait until i get 100% LED!!!
  8. Jul 4, 2020 at 9:09 AM
    TigOlTundra
    Tig
    New Hampshire
    I appreciate the help! I just found out that I bought H11 LEDs thinking that my new smoked headlights were the same specs as the OEM ones but it turns out my knock off spyders from ebay run H1s so now I am awaiting delivery on those.
