LED Headlight Burn Out....
Discussion in '1st Gen Tundras (2000-2006)' started by smokey0810, Jun 19, 2021.
  1. Jun 19, 2021 at 9:17 PM
    smokey0810
    smokey0810 [OP] New Member
    '03 Tundra SR5 AC 4WD
    Lost the low beam on one of my Techmaxx LED headlight bulbs tonight. Kinda disappointed, but for the price ($35ish range) they worked well for the past few years.
    Any thoughts on a decent replacement? Not looking for Morimoto $$$ (and I've searched the forum on this topic) and was just wondering what the general consensus was.
  2. Jun 19, 2021 at 10:09 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Handiclaus is going to tell you to get the Morimoto anyways because he hasn't yet
  3. Jun 19, 2021 at 10:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I have katana fanless led
    Works well with a set of superbrightleds.com load resistors. One per headlight.
    Don't forget that them morimoto 2 strokes are pushing $350 or whatever. Go ahead and do those too so @Professional Hand Model will hush about it. :rofl:
  4. Jun 19, 2021 at 10:18 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Also, forgot to mention. These are not clock-able. If you don't know what that means then you've never adjusted a set of LEDS.
    These are plug, and play. They were pushing $50 when I bought them, but they were new on the market then.
    Link to install (which has more pictures.)
  5. Jun 19, 2021 at 10:46 PM
    smokey0810
    Will read up more on the Katanas tomorrow….and about “clocking”
  6. Jun 20, 2021 at 7:09 AM
    Hand Protectors
    I have the other Katanas that have a fan on them that do clock. They are the newer version of the fan cooled type BUT they don’t have a driver box like the original Katana which only lasted me 14 months (in DRL Mode). I’ve disconnected DRL Mode and barely drive at night since I’m usually here harassing and heckling others. Time will tell on their longevity.
    Tundra2 has their other newer version without fan.
    The new Katanas work nicely when I do drive in darkness. They are a great value ($37). Value meaning they put good light on the road at a great price. They aren’t going to be life changing bulbs like some here thought they would be and then go and complain about them. Still better than $50-$60 for a 100 hour incandescent.
    Did anyone mention Morimotos 2.0 LED? :rofl:
    Tundra2 likes this.
  7. Jun 20, 2021 at 7:57 AM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
  8. Jun 20, 2021 at 8:15 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Are you guys clocking these at 90 degrees vertical for the LED side throw?
  9. Jun 20, 2021 at 8:26 AM
    Hand Protectors
    No. The clocking allows for easier install depending on your boot/clip on your vehicle. Nice idea you have though.
    Another note: Tundra2 bulb doesn’t have that cup over the one module like most. That cup is what focuses the beam similar to and incandescent cup.
    Glock 40[QUOTED] likes this.
  10. Jun 20, 2021 at 8:34 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    This is what I'm running: https://www.amazon.com/gp/product/B07J1Y2MDD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    When installed, they are 90 degrees vertical to side-throw the light. Very similar to what you guys are using. Super bright, yes. They work well with low beam (as long as my fogs are on for lower spectrum filler). If I hit high beam... forget it. Throws shards of light everywhere and useless. LEDs aren't really made for the OE style reflector buckets. Did you guys modify your buckets somehow.... or?? I'm considering going to a quality halogen so I can use my high beams again.
  11. Jun 20, 2021 at 8:45 AM
    Hand Protectors
    I have aftermarket headlight assys and haven't modified them as there is no need. My low beams are good and the high beam has some shard/rays, but I’ve rarely ever needed them. My Fogs are the PerfectFits LED and are outstanding.
    BravoDeltaRomeo and Glock 40 like this.
  12. Jun 20, 2021 at 8:52 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I probably have the same aftermarket headlight assys as you. Sounds like you're in the same boat as me then. My fogs are also LED and fantastic filler for the very good low beam that the LED headlights provide. That combo is almost too bright though. I occasionally get flashed. My other complaint about the LEDs is that they run cool. I live in a climate that is cold about 70% of the year. Halogens do a much better job of keeping ice melted on the lenses. I'm still on the fence with this. One thing's for sure, these LEDs are 100 times better than the OE when I received the used truck.
  13. Jun 20, 2021 at 9:01 AM
    Hand Protectors
    Yeah.
    Never been flashed as I used/followed the FSM aiming specs with the Akkon Aftermarket Housings. I don’t have the Cold Ice Problem here like I can imagine you have. Those Morimoto LED 2.0 have a built in special breather/heater for such a situation. :thumbsup:
    smokey0810[OP] likes this.
  14. Jun 20, 2021 at 9:09 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  15. Jun 20, 2021 at 9:20 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  16. Jun 20, 2021 at 9:25 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    The 2017 has different reflector buckets.
  17. Jun 20, 2021 at 9:26 AM
    Hand Protectors
  18. Jun 20, 2021 at 9:48 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Link had several different bulb types to choose from.
  19. Jun 20, 2021 at 9:56 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Yes, I understand. It's the 2017 Tundra headlight REFLECTOR bucket which differs from the FGT bucket... wherein lies the difference in how the vehicle throws (reflects) light. For this reason your comparison is moot.
  20. Jun 20, 2021 at 11:08 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
    OP never said what year he had, was just trying to help Mr. Gatekeeper. My apologies.
  21. Jun 20, 2021 at 11:15 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Not gatekeeping, just trying to clarify. It was posted in the Gen 1 section so probably safe to assume he's got a Gen 1. There is a difference in how the different headlight assys emit/reflect light.
    ... and no need to apologize for anything.
  22. Jun 20, 2021 at 2:04 PM
    smokey0810
    Techmaxx LEDs in my ‘03.
  23. Jun 21, 2021 at 7:33 PM
    smokey0810
    Katana's ordered. Will be here thursday
  24. Jun 21, 2021 at 8:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Which one? Lol
  25. Jun 21, 2021 at 8:20 PM
    smokey0810
  26. Jun 21, 2021 at 8:26 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Cuppage!
    HBTundra likes this.
  27. Jun 21, 2021 at 9:23 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Good choice.
    Tundra2 likes this.
  28. Jun 23, 2021 at 6:13 AM
    smokey0810
    They were in the mailbox yesterday. Will be put in today sometime.
    Tundra2 likes this.
  29. Jun 23, 2021 at 6:38 AM
    Clocking may make install easier, putting the connector in a favorable location, but its true purpose is to place the LED "bulb" portion facing towards the reflector in a manor that it reflects the light appropriately. Usually facing down.
  30. Jun 23, 2021 at 6:49 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I think they're side-throw, meaning they throw light from two sides. They'll clock in to throw light right and left in the reflector bucket. That's how mine are anyway.
    KNABORES likes this.
