LED fog light assembly upgrade on 2012 Sequoia Platinum compatibility
Discussion in 'General Tundra Discussion' started by SprinterAE86, Sep 7, 2020.
  1. Sep 7, 2020 at 2:22 AM
    SprinterAE86
    SprinterAE86 [OP] New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    So, I bought an LED fog light assembly Morimoto look a like. When I installed it, it did not work, so I taught it was a dud. I had it replaced still nothing. I tested it with direct power and works just fine.
    Do I need to direct wire it to the battery with a relay using the original plug as a trigger. Or just get a resistor adapter to make it work?
  2. Sep 7, 2020 at 2:37 PM
    omgboost
    omgboost The Accountant
    East Coast
    I don't think you need to do that. Should be plug and play. Does your stock fog lights turn on?
    Maybe try changing the polarity of the plug? I had to do that to my led fog light install since it was inserted the wrong way and when I flipped it around, it turned on.
