LED exterior lights, do I need a resistor?
Discussion in '1st Gen Tundras (2000-2006)' started by wcooperider3rd, Apr 5, 2021.
  1. Apr 5, 2021 at 10:57 AM
    wcooperider3rd
    wcooperider3rd [OP] New Member
    Wayne
    2005 Tundra Double Cab Sr5 4.7L RWD
    Hey guys! Long time! So anyway, I've been busy with new stuff but lately I said the hell with it and bought the LED license plate lights (https://www.amazon.com/dp/B07NF9J8L8/ref=cm_sw_r_cp_apa_glc_fabc_76QQAMNVDJJSSP6YPBH3?_encoding=UTF8) and since then, the compass and my Kenwood radio are in night mode, except when reverse lights are on. (With headlights on everything is how it should) but when I turn off the headlights, and engine on, the lights stay dimmed/ and my map is still night mode. If I'm just on battery power, the compass will switch, but the radio will not. Should I get a resistor? Of so, where should I splice it? Also all exterior lights are LED with the exception to headlights and fogs .
  2. Apr 5, 2021 at 11:09 AM
    Resistors are used to eliminate hyperflashing on turn signals.
  3. Apr 5, 2021 at 11:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    IF all you did was install those plugin lights, I would suggest unpluging the new T10 plug and see if things go back to normal. IF the below instructions is what you used from your Amazon link, cannot see how that would cause your symtoms !
  4. Apr 5, 2021 at 2:42 PM
    Professional Hand Model
    Hand Protectors
    Might try going back to the old assys with a higher quality bulb like Sylvania Zevo type. First try your old bulbs again and then do the Sylvania next.
    wcooperider3rd[OP] likes this.
  5. Apr 5, 2021 at 2:55 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    I replaced just my bulbs with led and had no problems.
    wcooperider3rd[OP] and Tundra2 like this.
  6. Apr 5, 2021 at 3:30 PM
    Hand Protectors
    Check your vector.
  7. Apr 5, 2021 at 4:52 PM
    wcooperider3rd
    Wayne
    For that I just installed a smart flasher
  8. Apr 5, 2021 at 4:53 PM
    wcooperider3rd
    Wayne
    Hm. Will do!
  9. Apr 5, 2021 at 7:55 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I just installed the exact plate lights. All systems go. Super bright tail now
  10. Apr 5, 2021 at 7:57 PM
    wcooperider3rd
    Wayne
    Do you have your tails and 3rd brake led as well? I have the XEVO lights for everything else in the back, except these.
  11. Apr 5, 2021 at 8:20 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Just the plate lights, and the El Cheezo third brake light.
