LED drls, which to get?
Discussion in 'Lighting' started by Tophergt99, Dec 26, 2016.
  1. Dec 26, 2016 at 3:52 PM
    Tophergt99
    Tophergt99 [OP] Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Been thinking about getting some led drls, I've seen the spyder and rosta drls with the new panels...look good but don't look like they put out much light. Could go the cheaper route and get universal drls...chime in on this or show me some pics of what you did.
  2. Dec 26, 2016 at 6:34 PM
    chphilo
    chphilo Tundra addict
    Western PA
    These drl's are not designed as the primary driving lights. It's true that they don't produce much light. But they are very difficult to not notice for the oncoming cars.
    I have 2010 with panel type leds. Be careful. Once you get LEDs, your stock lights will look very yellow in comparison. So I ended up installing white light halogen bulbs to better match them.
    Here is a picture with stock bulbs.
    With Philips Crystal Vision (not a perfect match, but a better match)
    Here is with just LEDs on
    Low Beam only (Crystal Vision)
    FlashCulprit and NewImprovedRon like this.
  3. Dec 26, 2016 at 6:37 PM
    Tophergt99
    Weston, Wisconsin
    In progress....
    I have Morimoto H4 HIDs and I also have Morimoto fog lights, just want some nice led drls. I also deleted the amber drl by switching out the box.
    chphilo likes this.
  4. Dec 26, 2016 at 7:51 PM
    chphilo
    Western PA
    That's a nice set-up. To be frank, I do like the panel type leds on 2nd gen Tundras. I've seen similar ones for the 3rd gen and they seem odd to me. I like those single row led bars that fit into the 3rd gen grille though. That will go well with your Headlight and fog light set-up.
  5. Dec 27, 2016 at 6:40 AM
    Tophergt99
    Weston, Wisconsin
    In progress....
    I agree, if they would of made the drl follow the contour of the light would of looked a lot better.
  6. Dec 27, 2016 at 9:22 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Vleds makes some dtrl led bulbs for the oem turn signal/dtrl they are white the go orange with the signals that's they way to go unless u wana crack the headlights open
  7. Dec 27, 2016 at 9:33 AM
    Tophergt99
    Weston, Wisconsin
    In progress....
    I have it so unless I have my running lights on I have no drl whatsoever. Just want a nice led strip up front.
  8. Dec 27, 2016 at 9:36 AM
    xtyfighterx
    Ty
    North Idaho
    They will be on every time you start your truck and they will be white.
    Crack the headlights open and put a strip in the filler panel pretty simple process just kinda scary at first if you have never taken a lens off a light before
  9. Dec 27, 2016 at 9:36 AM
    xtyfighterx
    Ty
    North Idaho
    Or find some platinum headlights for a good deal on eBay that would be my next choice
    Gasman675 likes this.
  10. Dec 27, 2016 at 9:39 AM
    xtyfighterx
    Ty
    North Idaho
    I have morimoto dtrl strips in my filler panel with a diffuser over iT.
    SouthBoundSteve and boardude like this.
  11. Dec 27, 2016 at 9:41 AM
    Tophergt99
    Weston, Wisconsin
    In progress....
    Well if I do it that way I'll be having a them retrofitted. :)
  12. Dec 27, 2016 at 9:43 AM
    xtyfighterx
    Ty
    North Idaho
    Yep I would to. That's your best option I've seen used platinum lights with oem dtrl strip for as low as 99$ a light on eBay
  13. Dec 27, 2016 at 9:47 AM
    Tophergt99
    Weston, Wisconsin
    In progress....
    I already have TRD Pro headlights I would have them retrofitted. ;)
  14. Dec 27, 2016 at 9:48 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I don't think the platinum lights are plug and play in the SR5s...so, you'd need to figure out the wiring.
    Tophergt99[OP] likes this.
  15. Dec 27, 2016 at 9:49 AM
    xtyfighterx
    Ty
    North Idaho
    Ya not plug and play but pretty easy to wire up
  16. Dec 27, 2016 at 9:54 AM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Really? I need to look into this option then. I like the white LED strip DRL on the platinums and 1794s.
    xtyfighterx[QUOTED] likes this.
  17. Dec 27, 2016 at 10:36 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Thats a badass pic.. and truck!
    PR_02 and xtyfighterx[QUOTED] like this.
  18. Dec 27, 2016 at 10:39 AM
    xtyfighterx
    Ty
    North Idaho
  19. Dec 27, 2016 at 10:56 AM
    Tophergt99
    Weston, Wisconsin
    In progress....
    How far did you walk around so you didnt leave footprints in the photo. :p
  20. Dec 27, 2016 at 11:35 AM
    xtyfighterx
    Ty
    North Idaho
    Ha I was actually cutting a tree down and Ana forgot where the truck was ha
    r4z0r51o likes this.
