LED DRL Switchbacks
Discussion in 'Lighting' started by boardude, May 31, 2016.
  1. Jul 29, 2016 at 3:07 PM
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Here's where I tapped the fuses and then connected them to the white dimming wires.
    And towards the end of the video the headlights come on and you see the DRLs dim
    https://www.youtube.com/watch?v=UmvNnj9ZA_E
  2. Jul 29, 2016 at 4:53 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Thanks again! Didn't notice them dimming when you posted the video the first time. Unless I'm mistaken looks like the dimming feature works only for the DRL mode and not while they are blinking. Very nice since looks like the DRL's dim down much better to match the brightness of the headlights. Now I've got to do this.
  3. Jul 29, 2016 at 10:45 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah the video is a little deceiving but the dim works on the DRLs and the turns.
  4. Jul 29, 2016 at 11:08 PM
    r4z0r51o
    Dave
    and the turns as well, good to know. That's probably for the better as these LED's are bright!
  5. Oct 3, 2016 at 11:45 AM
    kaycock18
    kaycock18 New Member
    Kevin
    Shreveport, LA
    2014 Tundra SR5
    3" pro comp lift, carven exhaust, gorecon taillights, 6k vleds everywhere, rigid industries D2 driving lights for fog lights, 20" fuel maverick rims, 33" toyo R/T tires, color match TRD Pro grill
    Where did you mount your resistors in the front for the switchbacks? I just talked to VLED and they said the resistors get really hot and to not mount them on plastic.
  6. Oct 3, 2016 at 3:08 PM
    r4z0r51o
    Dave
    When you have your headlamps off you'll see there some open spots of metal that you can mount the resistors too via the double sided tape.
  7. Dec 24, 2016 at 6:21 AM
    r4z0r51o
    Dave
    Sad to report but I've given up on the V3's ... both bulbs ended up having problems either lighting up or switching back. I called VLeds and they replaced both bulbs without any problem (great customer service) However, Thursday when I went to hook up the new bulbs the first one worked perfectly, the second one not so ... it would turn on only whenever I used the hazards/blinkers but not as a DRL. I ended up pulling the whole system out in frustration. When I get the chance I will try and play with them once more, but if they don't work as expected ... I'll be giving up on the V3's.
    Backslider likes this.
  8. Dec 24, 2016 at 6:43 AM
    r4z0r51o
    Dave
    It's so sad Steve, the kit looks like such a quality build. It's just sad that these bulbs have been failing. Not to mention I've had issues with a few of the Headlight Revolution front parking lamps too. :annoyed:
    SouthBoundSteve likes this.
  9. Dec 24, 2016 at 6:51 AM
    r4z0r51o
    Dave
    I really couldn't tell you if they do or don't ... I was so pleased with the quality of the kit that I never thought I'd have to worry about bulb issues.
  10. Dec 24, 2016 at 11:12 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    That's a bummer.
  11. Dec 31, 2016 at 11:26 AM
    xando
    xando New Member
    Oregon
    Tundra TRD OFF ROAD 2015 crewmax/ silver metallic
    Kris,
    I like the way you did. What mini fuse did you use for the white wire? 15A?
  12. Dec 31, 2016 at 11:33 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Sorry to hear that Steve. I planned on installing mine next week. Im hoping I have better luck
  13. Dec 31, 2016 at 1:31 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    VLED's has a sale today.
    16% OFF CODE ACTIVE TODAY: NEWYEAR16
  14. Dec 31, 2016 at 1:37 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah, I think I just matched the headlight fuse.
  15. Jan 13, 2017 at 6:21 PM
    xando
    xando New Member
    Oregon
    talked with Vleds today, the switchbacks use less than 1.5A
    They told me 5A fuse should be plenty
  16. Jan 16, 2017 at 5:08 PM
    xando
    xando New Member
    Oregon
    Kris,
    it worked perfect. thank you for above advice
    boardude[QUOTED][OP] likes this.
  17. Jan 16, 2017 at 5:34 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Anytime man! Glad it worked out.
  18. Aug 13, 2018 at 2:16 PM
    TrueTexan86
    TrueTexan86 New Member
    2014 Black Tundra TSS Crew Cab
    I know this is an old post, but i just hooked up the V6 Tritons. They look good, but the are hella bright. I am worried about them at night. They might be brighter than the OEM head lights. I plan on upgrading the headlights/ fogs soon to either a LED or " white halogen to match. Can anyone help me with the "dimming" install? Kris's video is no longer available. I'm not great with this kind of stuff. The install took me a little longer than i wanted it to.
  19. Aug 13, 2018 at 2:54 PM
    #49
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    I have this exact same set up. It’s the best.
  20. Aug 13, 2018 at 2:56 PM
    #50
    poheller
    Scot
    2018 platinum
    I just hooked the dimming wire in the 3 prong light connector, works like a charm.
  21. Aug 13, 2018 at 3:08 PM
    #51
    TrueTexan86
    could you explain a little further in detail?
  22. Aug 13, 2018 at 3:19 PM
    #52
    poheller
    Scot
    2018 platinum
    Sure, tap in the dimmer wire to the connection on the wiring set up from vleds, strip a little bit of wire at the end unplug the head lamp connector and wedge it between the male, female lamp connector. I added some electrical tape to seal it better. All it does is sense a power source and it cuts the power to the switch backs about 10%.
    TheBeast likes this.
  23. Aug 13, 2018 at 3:45 PM
    #53
    TheBeast The Beach
    good to know. anyone running the V6 on a gen 2 stock headlight ?
  24. Aug 13, 2018 at 4:02 PM
    #54
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    NickBrewer and TheBeast like this.
  25. Aug 14, 2018 at 5:25 PM
    #55
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    Any tips on installing these along with the 2018 LED's? I'll be doing this modification as soon as my order from VLED's arrives. Thanks in advance!
  26. Aug 14, 2018 at 5:51 PM
    #56
    DallasTundra
    DallasTundra New Member
    2014 Tundra CrewMax SR5 4X4 5.7L Silver Sky
    2" MotoFab leveling Kit, 2Crave NX-5 wheels(5X150 +15 offset to fill in fender flares space), 275/60R20XL Nitto Terra Grappler G2 Tires, VLEDs Triton V3 Switchbacks, TRS Morimoto XB LED Fog Lights, CCI Chrome Grille, 2019 LED Headlights, Extang Solid Fold, Texas Edition, Leather, Nav, JBL, OEM Flares, Husky WeatherBeaters.
    I’ll be doing the headlights update as well. I’ve got http://www.vleds.com/triton 5000K in the old housing and wondering if:
    1. It fits the 2018 housing.
    2. Would 5000K look too yellow compared to the surrounding LED DRL?
  27. Aug 14, 2018 at 7:25 PM
    #57
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    You got the harness from ihacker right? Since these are not plug and play?
    You can bypass the turns on the harness and plug the switchbacks into your regular turn plugs.
    NickBrewer[QUOTED] likes this.
  28. Aug 14, 2018 at 7:29 PM
    #58
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    1. It fits the 2018 housing. - Yes the vleds come with a ton of adaptors to make it fit. I had mine in my 2015 lights, the spyder lights and the 2018 lights.
    2. Would 5000K look too yellow compared to the surrounding LED DRL? - Mine are 6k and they almost match perfectly (Disclaimer - mine are the V3 tritons)
  29. Aug 15, 2018 at 7:53 AM
    #59
    NickBrewer
    Yeah, I got the harness from iHacker. I also ordered the 7440/7443 base adapter so they have the same connector type as the 2018's, so I am guessing that they will just plug in and work with the exception of the dimming circuit. Did you do the dimming circuit the same way you did on the truck you had when you first posted this thread? Thanks!
  30. Aug 15, 2018 at 8:12 AM
    #60
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah I have the switchbacks plugged into my factory plug (no adapter) and didn't use the turn plugs on the harness. The vleds have a dimming wire that I taped into the headlights in the fuse box, so when the headlights come on the switchbacks dim.
