LED bulbs or headlampassem?
Discussion in '2.5 Gen Tundras (2014-2021)' started by bfd300, Sep 28, 2018.
  1. Sep 28, 2018 at 3:12 PM
    bfd300
    bfd300 [OP] New Member
    I bought. 19 Tundra sr5 should I go with LED bulbs. (Cheaper) or the headlight assembly?
    If bulbs which ones?
    Thanks
  2. Sep 28, 2018 at 3:36 PM
    L3TT3RS
    L3TT3RS New Member
    Taylor
    19 Tundra
    Fox/Total Chaos/Coachbuilder
    The search function is your friend
  3. Sep 28, 2018 at 6:23 PM
    Gibo244
    Gibo244 New Member
    KG
    Maui
    Hikari
  4. Sep 28, 2018 at 6:28 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Do it right and get the full LED headlight assemblies. They are brighter, DOT approved, OEM Toyota parts. Adding LED bulbs isn't a great idea. They tend to cause glare and scatter light.l, both of which create unsafe driving conditions. A good set of bulbs will run 200 bucks, not worth it when you figure you can get the real deal LED headlights for 500-600.
    bfd300[OP] likes this.
  5. Sep 28, 2018 at 6:35 PM
    bfd300
    These?
    https://www.ebay.com/ulk/itm/323060356222
  6. Sep 28, 2018 at 6:39 PM
    Pudge
    CT
  7. Sep 28, 2018 at 6:43 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Say what dawg? What is that title? I visited just out of wonder.
    Better halogen bulbs are your friend unless you're going to spend the money to perfect your LEDs or HIDs.
  8. Sep 28, 2018 at 6:51 PM
    PATTEN
    PATTEN New Member
    Neil
    Guntown MS
    2018 CM XSP MGM SR5 4X4
    This^^^
    OBXTundra likes this.
  9. Sep 28, 2018 at 6:56 PM
    DallasTundra
    DallasTundra New Member
    2014 Tundra CrewMax SR5 4X4 5.7L Silver Sky
    2" MotoFab leveling Kit, 2Crave NX-5 wheels(5X150 +15 offset to fill in fender flares space), 275/60R20XL Nitto Terra Grappler G2 Tires, VLEDs Triton V3 Switchbacks, TRS Morimoto XB LED Fog Lights, CCI Chrome Grille, 2019 LED Headlights, Extang Solid Fold, Texas Edition, Leather, Nav, JBL, OEM Flares, Husky WeatherBeaters.
  10. Sep 28, 2018 at 7:15 PM
    bfd300
    I had Hid’s on my Tacoma and liked them alot. I figured LED might be the way to go
  11. Sep 28, 2018 at 7:15 PM
    bfd300
    Is there any aftermarket headlamp assemlys you guys reccomend?
  12. Sep 28, 2018 at 7:19 PM
    bfd300
    Ok may I ask why?
  13. Sep 28, 2018 at 7:23 PM
    Pudge
    CT
    What year Tacoma? I had them in my 2008 which had halogen reflector housings, like your tundra. And while yes they were bright, they had a ton of light scatter, horrible unsafe glare to oncoming traffic, and they shook over bumps. I removed them after about a month and threw them in the trash, couldn't even bring myself to sell them for someone else to use.
    Guys seem to have luck with spyder projectors with HID kits installed into them.
    For your money you won't find better than the OEM Toyota LEDs. Do it right the first time. I'm a cheap bastard and have zero regrets that I spent the extra cash on the right parts for the job.
    bfd300[QUOTED][OP] likes this.
  14. Sep 28, 2018 at 7:24 PM
    Pudge
    CT
    See below
  15. Sep 28, 2018 at 7:25 PM
    bfd300
    My Tacoma was an 11 I never had a problem with the Hid’s
  16. Sep 28, 2018 at 7:26 PM
    bfd300
    I thought I may do a temp fix with led bulbs untill I get the cash for the oem headlamps
