LED back up lights
Discussion in 'Lighting' started by Red Freighter, Jan 19, 2016.
  1. May 22, 2017 at 9:01 AM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    I just ordered all head light, tail light, and license plate bulb replacement LEDS (with the exception of getting the low and high beam head light bulbs. Went with HID conversion for those. 35w on low beam and 55w on the high beam)
    From what I can determine every thing is plug and play except for all of the amber turn signal bulbs. They need a resistor on each bulb so those are on the way as well. Other interesting note is if your truck has the "bulb out" detecting capability there are different Can bus type bulbs that you will have to use vs the stock replacement LED bulbs. I tried to figure out if my truck has that feature and I don't think that its that smart. I pulled one of my bulbs out to see what I got on the instrument cluster and did not see any indication of a bulb being out so I THINK that I am good.
    Sorry if I am behind on the knowledge about all of this but if anyone is up on this and knows another way to check to see if your truck has the "bulb out" feature let me know.
  2. May 24, 2017 at 7:46 AM
    Fishin1981
    Fishin1981 New Member
    2015 tundra limited crewmax
    Pop and lock, esp storage, access lorado, front tints
    Is there a trick in getting out the license plate bulbs? Can't seem to figure it out
  3. May 24, 2017 at 8:51 AM
    JTP
    The Big Black Moose
    They just twist 90 degrees out of the socket.
  4. May 25, 2017 at 3:22 AM
    Fishin1981
    I'm not talking about the bulb itself. I get my hand under the bumper, I just can't seem the get the harness separated form the bumper. I should have made myself clearer
  5. May 26, 2017 at 8:32 PM
    Fishin1981
    That's exactly what I was talking about. Thanks.
    NewImprovedRon likes this.
  6. Jul 29, 2017 at 11:18 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I remembered you posted this the other day when neither of my revers lights were working... looks like it's back to regular bulbs for me
