Leather/heated seat (front and rear) installation write up
Discussion in '2.5 Gen Tundras (2014-2021)' started by AlmightyCrash, Dec 8, 2018.
  1. Dec 29, 2018 at 9:54 AM
    #61
    AlmightyCrash
    AlmightyCrash [OP] Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    Black went to the bolt by the gas pedal
    Red went to an add-a-fuse on the constant 30 amp in the fuse box.
    I didn’t feel like tapping into the Illumination system, so the other two went to the heated seat fuse in the fuse box.
  2. Dec 29, 2018 at 11:57 AM
    #62
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Another big thanks for your write up Almighty- it’ll be a huge help when I get a chance to to do mine.
    AlmightyCrash[OP] likes this.
  3. Dec 29, 2018 at 12:27 PM
    #63
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Thank you for the great write up. If I get a near new or new truck . I was planning on adding these leather seats to the SR5 package and save about ten grand. My only tip I can offer you is protection from Lexol. Has worked great for me with my last three Toyota’s. Plus recommended by Toyota and Lexus to protect their vehicles. May great Karma shower you with great things for clueing us in on how to this.
    Love yours. D
  4. Dec 30, 2018 at 5:46 PM
    #64
    JoeCoastie
    JoeCoastie New Member
    Joe
    Hammond, OR
    2015 White Crew Max SR5
    So.Much.Good.Info
    Thank you!
  5. Dec 31, 2018 at 8:15 AM
    #65
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Got it, thanks man!!
  6. Jan 16, 2019 at 6:42 AM
    #66
    AlmightyCrash
    Crash
    San Leon, TX
    Just wanted to update everyone now that I’ve had these a while.
    I love the leather. They fit snug and are so much more comfortable.
    The fronts heat up quickly. The rears take a bit longer, but only by a minute.
    They all get warm enough that my gf actually lowers the setting after a while. She never did that on the previous vehicle with factory heat.
    All in all, I’m very pleased with the functionality of the heaters as well.
    TexasVol1794 and onetohunt like this.
  7. Jan 16, 2019 at 3:07 PM
    #67
    tubal
    tubal New Member
    SLC, UT
    Just want to say thanks for your thread. I did mine last weekend, following your step by step with some Alea leather with the TRD logo and they turned out awesome. I got the same heater kits you did, but I put massagers in my front seats when I had the covers off.
    I bought these covers:
    https://www.ebay.com/itm/303011470253?ViewItem=&vxp=mtr&item=303011470253
    I bought the same heaters you did.
    And I got a couple of these used on ebay, cut the motors out, and use the controllers to control them.
    https://www.amazon.com/Relaxzen-10-Motor-Massage-Cushion-Extra/dp/B01LYRI38M
    #67
  8. Jan 16, 2019 at 3:16 PM
    #68
    Snowcat4360
    Snowcat4360 New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    Did your kit come with the upper door skins as well? If so how difficult were they to install?
    #68
  9. Jan 16, 2019 at 3:36 PM
    #69
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    TexasVol1794 likes this.
  10. Jan 16, 2019 at 3:52 PM
    #70
    tubal
    tubal New Member
    SLC, UT
    It did come with the upper door skins, and a center console skin.
    I'm putting some speakers in my doors in the next few weeks so I was going to look at what the process would be to install them then. The current skins are a black fake leather that look somewhat similar, so if I don't think I can do it well I might just leave them be. I've never done it before, so I'm not sure if I should glue it to the existing vinyl or pull it off and glue it to the shell. I know installers use 3M Heavy Duty 20 adhesive, so I was going to use that either way.
  11. Jan 16, 2019 at 6:29 PM
    #71
    shhernandez74
    Samuel
    First off, I would like to apologize for my ignorance I am an accountant not a mechanic.
    So to my understanding, I have two harness that look like this. They both have those 3 loose wires at the end. I am guessing I will have to combined them and hook them up as follows-
    - Both black- will go to a ground
    - Both red- will go to a tap a fuse (I know the OP said 30 but how do I know if this is the appropriate power for mine)
    - Both White- will go to the seat heater fuse inside the cabin
    Any help will be greatly appreciated since I plan on doing this in the upcoming week.
    Once again I apologize for my ignorance and I will gladly help out with any taxation questions lol image.jpg
  12. Jan 16, 2019 at 6:35 PM
    #72
    tubal
    tubal New Member
    SLC, UT
    Yes that's exactly right. A 30A fuse will be plenty for seat heaters.
    The white just hooks to any accessory line so that your heaters will turn off if you turn your truck off. The seat heater fuse just happens to be an empty one you can use.
    The red is what will actually carry the load to your heating elements. This can be any powered line. That's the one you want to be on the 30A line.
  13. Jan 16, 2019 at 6:47 PM
    #73
    shhernandez74
    Samuel
    Awesome thanks man! I really appreciate it
  14. Jan 17, 2019 at 6:54 PM
    #74
    shhernandez74
    Samuel
    One more question. My red wire currently has a 10amp that came installed on the harness. Since that is the wire I will be attaching to the tap-a-fuse is it ok if I leave the fuse there or should I cut it off and connect the wire directly to the piggy back? FDD75BC2-12C9-4849-B68F-A7C1DAB75732.jpg
  15. Jan 17, 2019 at 7:04 PM
    #75
    AlmightyCrash
    Crash
    San Leon, TX
    If you’re using a tap, you can cut it off....or keep it if you really want. Either way will be fine.
    shhernandez74[QUOTED] likes this.
  16. Jan 28, 2019 at 8:48 AM
    #76
    tubal
    tubal New Member
    SLC, UT
    I pulled the door skins off, and it would require plastic welding, which I've never done, so I think I'm just going to leave those as is for now.
    There are videos on youtube showing plastic welding, and you can get plastic welding kits at harbor freight for relatively cheap if you wanted to try it. https://youtu.be/t7Rardz_m8Q?t=181
  17. Feb 6, 2019 at 9:08 AM
    #77
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Anyone know what the difference between the Katzkin leather and the Katzkin ALEA leather covers are?
  18. Feb 6, 2019 at 10:56 AM
    #78
    Touch-Ups
    Touch-Ups New Member
    Toby
    Jonesboro, AR
    Not sure if that is a typo, but it's just Katzkin or Alea. They are different companies. Their fit, quality, and warranty is the same. In the case of the Tundra, Alea does provide the door panel parts. That doesn't matter if you are just going with a factory match color, but if you went with contrast stitching, it would be nice to have the doors match. And if it matters to you, Alea does not put that branding tag on the side of the seat.
  19. Feb 6, 2019 at 11:42 AM
    #79
    tubal
    tubal New Member
    SLC, UT
    If you're talking about the little cloth tag that says Alea Leather, Alea does have that tag on the side of the seat. At least on the ones I purchased from you on ebay.
    #79
  20. Feb 6, 2019 at 12:22 PM
    #80
    Touch-Ups
    Toby
    Jonesboro, AR
    Yes you’re correct. I forgot they do add their tag to the custom made kits. They do not add it to the factory match high volume kits, which is what we deal with the most.
  21. Feb 27, 2019 at 8:02 AM
    #81
    tundra403
    tundra403 New Member
    KG
    2018 Tundra SR5 4x4 TSS Off Road - MGM
    -Internal LED Lights -Added VLED's Footwell light strip
    @AlmightyCrash what kinda button did you use up front?? i saw the pic, but does that one switch control both? I saw L & R.. but do you get the option to turn on one or the other? high/low?
  22. Feb 27, 2019 at 11:31 AM
    #82
    tubal
    tubal New Member
    SLC, UT
    I got the same set. It's a split button. So the right half of the circle controls the right seat, the left half controls the left seat. Press once for high, again for low, again for off.
  23. Feb 27, 2019 at 2:07 PM
    #83
    AlmightyCrash
    Crash
    San Leon, TX
    What tubal said is correct.
  24. Mar 7, 2019 at 5:44 AM
    #84
    Finch
    Finch New Member
    Donnie
    '16 Inferno CM 5.7L TRD Off-Road
    @AlmightyCrash is there any way that airbag deployment could be jeopardized in a future accident? I'm on the fence about doing this install myself or paying the man. I checked with a local shop (non Katzkin dealer) and they told me they'd charge me around $300 or so for the install for fronts and rears. I may just have them do it since the install price is pretty reasonable. I just worry if myself or someone would screw up something with the airbags. Easy to do or am I just worrying too much? Nice writeup btw.
  25. Mar 7, 2019 at 10:46 AM
    #85
    AlmightyCrash
    Crash
    San Leon, TX
    These covers are made to work with your airbags, and are just like your oem covers....just a different material.
    As for deployment during install, make sure you disconnect the battery before doing anything else.
  26. Mar 7, 2019 at 11:19 AM
    #86
    Finch
    Finch New Member
    Donnie
    Thanks. I guess I was talking more along the lines of something be messed up during the install that would hinder the correct operation of the airbags when needed. So it seems that really the only thing someone could screw up is forgetting to reconnect the airbag wiring connector once completed.
  27. Mar 12, 2019 at 7:09 AM
    #87
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    For those that have installed these, what size hog rings should be used? 3/8, 1/2 or 3/4"?? eBay is having a 15% off sale today and I'm pulling the trigger.
    Update- I went with 3/4" hog rings and pliers ($16.59), black Katzkin ($550+20), and Sojoy 18.9"x11" heater ($61.74) with the single switch like OP for $554.08 delivered after the 15% off.
    The OP's link to Amazon for the Sojoy heater is dead, and since i was getting 15% off on eBay, here's the link to the heater kit: https://www.ebay.com/itm/262801977601
    #87
  28. Mar 12, 2019 at 7:28 AM
    #88
    Finch
    Finch New Member
    Donnie
    Me too! They are already in my cart...just looking for more stuff to add.
    #88
  29. Mar 12, 2019 at 8:19 AM
    #89
    Finch
    Finch New Member
    Donnie
    Just placed my order for Katzkins and the seat heaters that @AlmightyCrash used. $540 shipped :bananadance: FYI - those seat heaters appear to no longer sold on Amazon.
  30. Mar 12, 2019 at 10:34 AM
    #90
    AlmightyCrash
    Crash
    San Leon, TX
    I believe my hog rings were 3/8”, but it really doesn’t matter. They wrap around themselves and all end up the same size when tight.
