Leaning with non adjustable coilover?
Discussion in 'Suspension' started by Toytec Lifts, Jan 5, 2018.
  1. Jan 5, 2018 at 1:58 PM
    Toytec Lifts
    Toytec Lifts [OP] New Member
    Denver, CO.
    Do you suffer from the driver side lean?
    Do you wish there was a simple way to fix it without spending a ton?
    Well Toytec has you covered!!!
    Introducing our newest product, the Front Top Plate Spacer (1/4'' Think)
    • Top plate spacer adds approximately 1/4"-1/2" lift.
    • Great for correction of drivers side ride height.
    • CNC Machined From 6061 T-6 Aluminum.
    • Does not require longer top mount studs.
    • Fits on top of your coilover assembly. No spring compressor needed for installation.
    • Sold Individually. Includes 1 spacer.
    • Fits 07+Tundra/08+Sequoia
    ****Not recommended for use with adjustable coilovers or damage can occur****
    http://toyteclifts.3dcartstores.com...cer-14-Thick--07-Tundra08Sequoia_p_1899.html#
    MistrRoboto and T-Rex266 like this.
  2. Jan 5, 2018 at 2:09 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Nice. What happens when you install these on non adj coils? Say my radflos. I’d like to lessen the preload to soften the ride but not lose any height.
    Berdine likes this.
  3. Jan 6, 2018 at 10:02 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    I don’t picture a 1/4” being enough to effect then preload. Could be wrong though.
