Leaking front axle seal
Discussion in '2.5 Gen Tundras (2014-2021)' started by BabyBlackYota, Jan 16, 2022.
  1. Jan 16, 2022 at 4:40 PM
    BabyBlackYota
    BabyBlackYota [OP] New Member
    Alex
    Longview TX
    2015 Black Tundra SR5 offroad
    AFE cold air intake, Outlaw Catback Dual Exhaust, ProRunner Fender Flares, DAPTISED 37x12.5x20’s, (soon to be 38x13.5x17) Zone 5 bracket lift kit /with pro comp spindles and outer tie rods grip pro lsd rear, Revolution 5.29 gears Deaver U748 springs Camburg shackles Fox 2.5 Coilovers 7” BDS Icon Billet adj/UCA’s
    So here’s what’s going on…
    replaced both front axles with Napa’s extended axles install was good except passenger side seal keeps leaking I replaced seal twice already but still leaking drivers side is fine I checked breather hoses they seem to be good. Going to try to replace again I had it flush with that first lip you see don’t know if that is to far in or not far enough? could bearings be bad I don’t know they seemed fine. Also should shaft have a little play once you bang the shaft in and set the ring inside or should it be tight with no play at all?
  2. Jan 16, 2022 at 4:55 PM
    BabyBlackYota
    Alex
    Longview TX
    Here’s a pic a lot on this one considering I just made a 4 hour drive but just sitting doesn’t leak much
  3. Jan 16, 2022 at 7:50 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Was it leaking before you installed the new shaft? If it just started with the new shaft I would look at the sealing surface of the new shaft and see if there are any nicks etc.
    If you still have the old shaft I would measure the diameter of the sealing area.
    When you pull the shaft back out I would run my finger around the seal and see if it feels smooth.
    2mchfun and boostedtrdpro like this.
  4. Jan 16, 2022 at 7:59 PM
    BabyBlackYota
    Alex
    Longview TX
    No it wasn’t leaking before only after I plan to take it back off tomorrow I will check
    what do you mean by dealing surface?
  5. Jan 16, 2022 at 8:05 PM
    BabyBlackYota
    Alex
    Longview TX
    I would of thought it would be the same since the drivers side isn’t leaking and I compared the new shaft with the old one same lengths and everything
  6. Jan 16, 2022 at 9:03 PM
    huntertn
    huntertn New Member
    Tennessee
    The seal will ride on a part of the cv-shaft (sealing surface). If that somehow got a nick or other damage it could be damaging the seal lip. But, I would think if you run your finger around the seal lip you would feel it. If the shaft were used it might have a groove from wear but since it is new it should be smooth.
    If you are going to install a new seal I would first see how it fits around the seal surface. It is possible that either the size of the seal or the size of the cv-shaft seal surface is not the correct size. I have seen it on aftermarket stuff before.
  7. Jan 17, 2022 at 6:57 AM
    blanchard7684
    blanchard7684 New Member
    This is the answer.
  8. Jan 17, 2022 at 7:24 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Do you still have your old axles? By process of elimination, if you put the old axles back on and the leak stops, then you know the problem is with the new CV axle and would be a great time to use that Napa warranty.
  9. Jul 5, 2024 at 5:43 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    I’m in need of passenger side axle seal. Sort of in a pinch right now. Would anyone use a Napa seal for this job?
  10. Jul 5, 2024 at 6:32 AM
    2mchfun
    Yep, especially if in a pinch.
    huntertn likes this.
