Leaking Diamondback...........
Discussion in 'Tonneau Covers, Caps and Shells' started by dugfur, Nov 6, 2018.
  1. Oct 26, 2019 at 11:13 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    If u need any info don't hesitate.
  2. Oct 27, 2019 at 12:03 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    My boyfriend has one on his 2019. He doesn't get water in the center area. I'll take a pic of his on Monday when we see each other and it's light out (he works second shift and I work third).
  3. Oct 27, 2019 at 8:21 AM
    2chains
    2chains New Member
    Southern Ablerta
  4. Nov 29, 2019 at 5:58 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    What's the procedure for adjusting the rods, @JoshuaA ? I assume you're referring to the locking rods that lock the tilt up rear portion of the cover in place. I had some water intrusion near my tail gate area and would love to be able to figure out a way to stop it.
  5. Dec 1, 2019 at 4:54 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Basically the lower you have these bolts, the more downward pressure is on the weather stripping. Also if you can afford to center the whole lid further back, that might help any leaking at the tailgate end.
    equin likes this.
  6. Dec 1, 2019 at 6:40 PM
    chrisbusnut
    Pasadena, CA
  7. Feb 8, 2020 at 7:15 PM
    Tulsi-Tupac-Tucker
    Tulsi-Tupac-Tucker New Member
    I just purchased the HD Diamondback model. It came with 24 3M-taped rubber shims for adhering underneath the central portions of the bed rail caps, and a special instruction sheet explaining how to arrange them. A separate 3M tape gasket for the bulkhead (with instructions) was also included. So prior leak issues/problems are being addressed. I was also advised to apply a silicone bead at cab end of the bed rail caps if dryness is an important/ paramount concern for me. I can also attest to having to adjust the locking mechanism so that you need to place downward pressure on the top when closing (if you want water-tightness).
  8. Feb 22, 2020 at 12:04 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    Do you have any idea how thick those shins are? My cap is leaking between the rails and the bed so I am going to shim with someadhesive EPDM shims and seal. 1/8” 1/4”??
  9. Feb 22, 2020 at 1:14 PM
    Tulsi-Tupac-Tucker
    My guess is they were 1/4 inch thick. However, you should probably contact diamondback. I’m sure they would probably provide a set of shims to you at no charge, or minimum charge, along with an instruction sheet on how/where to place them.
  10. Feb 22, 2020 at 1:27 PM
    AK 6.7PSD Replacement
    AK 6.7PSD Replacement New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    The problem is that flimsy crappy Diamondback. I’ll do you a favor and take it off your hands for $50 so you can go ahead and get something quality. Like off Amazon.
    Luckydog likes this.
