LCAs won’t go back up
Discussion in 'Suspension' started by blakekircher, Jan 8, 2019.
  1. Jan 8, 2019 at 1:11 PM
    blakekircher
    blakekircher [OP] New Member
    Blake
    San Diego
    2018 Tundra TRD Sport 4x4
    3” level 17x8.5 Icon Rebounds 315/70/70 Cooper Discoverer Mtps
    Hey guys i’m installing a rough country leveling kit. i’ve got all the way to putting the strut back in but now i can’t connect the knuckle to the uca. should i jack up the lca?
  2. Jan 8, 2019 at 1:15 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Floor jack under the lower control arm should work
    831Tun, Law323, joonbug and 1 other person like this.
  3. Jan 8, 2019 at 1:16 PM
    blakekircher
    Blake
    San Diego
    i forgot to mention, when i tried that it lifted the whole truck rather than just the lca.
  4. Jan 8, 2019 at 1:17 PM
    15whtrd
    15whtrd Mr. Blonde
    Did you loosen your LCA bolts?
    Black Wolf likes this.
  5. Jan 8, 2019 at 1:33 PM
    blakekircher
    Blake
    San Diego
    so i’ve got it up a little more but now this won’t reach. I’m new to working on trucks so i’m not very familiar with what to do. do i just need to man handle it?
    Black Wolf and ColoradoTJ like this.
  6. Jan 8, 2019 at 1:37 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Take the sway bar loose from both sides. That should help.
  7. Jan 8, 2019 at 1:38 PM
    Porschetech29
    Francis
    Yup your fighting the sway bar
    Jerry311SD, Tundra_361 and 15whtrd like this.
  8. Jan 8, 2019 at 1:38 PM
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    2016 MGM SR5 4x4 Crewmax
    TC UCA's, King 2.5, Ex-Pelf Bumpers and skids, TRD Pro Grill, 2018 Lights, BD Fogs, FRAC
    Kinda looks like your bump stop is in the way. And you might need to remove a bolt from you sway bar.
  9. Jan 8, 2019 at 1:39 PM
    15whtrd
    15whtrd Mr. Blonde
    I didn’t take that apart from my application. I loosened the lower part of that knuckle and disconnected. Loosen the LCA cam eccentrics if you’re lifting it. If it’s like for like height then you don’t need to.
    Here are some instructions for the pro suspension installation. Maybe this will help.
    https://www.dropbox.com/s/sxjguie9rkx4dti/PTR13-34140inst.pdf?dl=0
    equin, EDDO and Law323 like this.
  10. Jan 8, 2019 at 1:40 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Loosen the sway bar bolt in the front on both sides.
    I had the same plm. Also, don’t tighten the sway bar until everything’s done. Had to go back and forth a few times.
  11. Jan 8, 2019 at 1:40 PM
    15whtrd
    15whtrd Mr. Blonde
    I missed that in the picture. That will definitely make all the difference.
    NewImprovedRon likes this.
  12. Jan 8, 2019 at 1:40 PM
    Ok, this is going to make you so happy.
    You didn't need to separate the knuckle from the UCA. The knuckle is a two piece design and you remove the two bolts on the bottom. The LCA alignment cam bolts need to be loosened a bit.
    Remove the coilover assembly again, connect the knuckle and UCA, separate the lower part of the knuckle, reinstall CO, use floor jack to assemble the lower part of the knuckle and LCA, torque to spec.
    equin, 300BLK, rv740 and 6 others like this.
  13. Jan 8, 2019 at 1:47 PM
    blakekircher
    Blake
    San Diego
    Thanks for all the replies. So i have the bolt out of the sway bar, but are you guys saying i should take it out of that slot?
  14. Jan 8, 2019 at 1:49 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah and drop it down out of the way. Not the U-shaped brackets just the ones you already have the bolts taken out of. Swing it out-of-the-way. It needs to be disconnected on both sides.
    rv740, Law323 and ColoradoTJ like this.
  15. Jan 8, 2019 at 1:50 PM
    blakekircher
    Blake
    San Diego
    also i’m starting to worry that i might’ve done something to the price i’m pointing at because the wheel mount isn’t moving the same as the drivers side
  16. Jan 8, 2019 at 1:51 PM
    blakekircher
    Blake
    San Diego
    thanks sean i’m gonna try that now
    Danimal86 and 15whtrd like this.
  17. Jan 8, 2019 at 1:55 PM
    15whtrd
    15whtrd Mr. Blonde
    You might want to try to reattach that upper knuckle. Hopefully you didn’t over extend that joint. I don’t know much about that piece and how it works internally. @ColoradoTJ any suggestions?
    ColoradoTJ likes this.
  18. Jan 8, 2019 at 2:15 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Make sure 4 wheel axle is in all the way on both sides first, then remove coil over assembly and reinstall spindle to upper control arm just get Nut snug so it does come loose. Then reinstall coil over , install top three bolts first then lower mount to lower control arm. Looks like you are fighting coilover spring tension
  19. Jan 8, 2019 at 2:18 PM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    If that don’t help you might have to get coilover spring compressor to compress coil springs enough to fit in spring bucket
  20. Jan 8, 2019 at 2:19 PM
    15whtrd
    15whtrd Mr. Blonde
    No it shouldn’t be that way. He’s fighting the sway bar as well as disconnecting the upper knuckle instead of the lower two bolts.
  21. Jan 8, 2019 at 2:52 PM
    This is why I would like to see him pull the coilover, reattach the knuckle to the uca. The half shaft may have pulled out of the center section. If he is attempting to lift the suspension with the half shaft out of the differential splines, he will never get that knuckle back up to the uca. There is a good chance the shaft seal is damaged as of right now.
    This is why we separate the knuckle and do the install this way. No prying on parts to attempt lining up.
    jeremyd, equin, joonbug and 3 others like this.
  22. Jan 8, 2019 at 2:56 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
  23. Jan 8, 2019 at 2:59 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    She's got a sneaky grin on her face!
    Sorry, mang. I know you're struggling right now but I couldn't resist.
  24. Jan 8, 2019 at 3:04 PM
  25. Jan 8, 2019 at 3:43 PM
    Jrharvey02
    Yes, there’s a lot of things that shouldn’t be done, especially the first dude outside, but considering the pickle the op is in, a video is prolly gonna be of some help. Watching these two videos, I had mine swapped out in about 1.5 hours per side. They may not be Toyota’s way of doing it, but they’re the only 2 videos I could find on swapping out front struts and they helped me, figured they could do the same for the op.
  26. Jan 8, 2019 at 3:50 PM
    15whtrd
    15whtrd Mr. Blonde
    Except it’s so much easier to disconnect the lower control arm from the knuckle as opposed to the knuckle from the upper ball joint. If you’re just changing like for like coilover height, you don’t even need to loosen the alignment cam bolts. Just disconnect the sway bar and those two bolts. If you read the PDF that I posted, it shows this way to install TRD pro shocks.
    Obviously it can be done the way he did it in the video. To be honest that’s the first video I watched before I performed my coil over swap. Glad I got the proper instructions before I did that. Also that first video was a 2x. Less stuff to worry about messing up when you disconnect that upper knuckle.
    splitfuse and ColoradoTJ like this.
  27. Jan 8, 2019 at 3:54 PM
    I already told him how to do it in 12 & 22 post. I had to swap out my 6112’s several times and a few COs.
    The CO is one bolt and three nuts and it’s out at this point.
    He needs to verify if the half shaft is seated all the way in.
    I would bet a 6 pack the diff seal leaks in 10k miles if he keeps on wrenching on it.
    This is where I would like to point out, at times, actually listening to a Toyota A Technician is a good thing. This is why I don’t call dealerships “stealerships”, and a true A Tech is a great resource. That’s how I learned it.
  28. Jan 8, 2019 at 4:32 PM
  29. Jan 8, 2019 at 4:47 PM
    Exactly^^^^^^^TJ has it covered...No need for me to chime in. Been there...done that! :smokertransformer:
    15whtrd likes this.
  30. Jan 8, 2019 at 4:48 PM
    15whtrd and ColoradoTJ[QUOTED] like this.
