Largest TRD Pro tire size on stock suspension?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by gregm76, Jul 6, 2020.
  1. Jul 18, 2020 at 10:00 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    What trimming was needed other than BMC
  2. Jul 18, 2020 at 10:20 AM
    Flytrap50
    Flytrap50 New Member
    2019 Toyota Tundra TRD PRO Voodoo Blue
    I took a picture so you can see. It's just interior plastic. I told my shop I didn't care what he trimmed because eventually I was going to get a after market bumper.
    Here is a pic.
  3. Jul 18, 2020 at 12:05 PM
    Elduder
    Elduder New Member
    Im getting 35" ATZ P3s on next week, stock pro otherwise. CMC already done and I just removed the liners for now.
    jewsNbrews and Flytrap50[QUOTED] like this.
  4. Sep 25, 2023 at 8:17 AM
    jrnightrider
    jrnightrider New Member
    2020 Black Tundra TRD PRO
    295/70R18 Toyo Open Country M/T on a 2019 TRD Pro with front mud flaps removed (there’s rubbing if not removed).
    5F4B99FB-3C8F-45D7-8A6E-931BF8055F30.jpg C601BC17-2976-4159-9E64-1E39D3E11FD9.jpg 990F7E40-30A3-444D-A9C2-79A19D0F07CC.jpg 23D5E692-9354-4071-8385-24F8E4B7E060.jpg
  5. Sep 26, 2023 at 12:29 PM
    woofhauler
    woofhauler New Member
    Pacifica, CA
    285/75R18 35" tall while 285 width, no rubbing and plenty of room between UCA
    ackthresher, SYNCRO, Refusuck and 2 others like this.
  6. Oct 27, 2023 at 9:37 PM
    U-moto
    U-moto New Member
    IMG_1415.jpg 285/75/18 Wildpeaks on Method 701 … heat gun work on front liner.
    Didn’t rub front liner using same size with stock wheels
  7. Nov 3, 2023 at 6:07 PM
    HairyFishies
    HairyFishies Somewhat new member
    Andy
    Central MN
    2016 MGM PRO
    295/70R18 Falken Wildpeak R/T01
    Trying out the new Wildpeak RT in 295/70. Removed front flap and no rub. Haven't really been able to test them out in mud/snow but they look nice :)
  8. Nov 6, 2023 at 5:49 AM
    ODST
    ODST New Member
    I'd like to hear back on these tires! They've caught my eye, but they're so new I haven't read enough about them yet.
    HairyFishies[QUOTED] likes this.
  9. Nov 25, 2023 at 9:38 AM
    CO.Tundra
    CO.Tundra New Member
    Taylor
    2019 White Tundra
    Coach Builder 1” shim, +2 Shackles. 285/75r18 AT3
    285/75r18 -Toyo AT3. Removed front thingy. Fit prior to Coachbuilder 1” shim no rub as well as after. IMG_1797.jpg
  10. Feb 29, 2024 at 6:29 PM
    muskylounge
    muskylounge New Member
    Jeff
    2021 Tundra TRD PRO
    Mine is Stock 21 TRD Pro. I went w 295.70.18 BFG A/T KO2. I cant go lock to lock without some rub. Like others said you can remove the small front mud flap and get more clearance and then go lock to lock. I also added RAS to improve squat in the rear. Rides great!!!
    Moving blankets are for spraying Fluid Film. I can be lazy sometimes.... :) Side Profile TRDPRO.jpg three quarters view TRDPRO.jpg
  11. Feb 29, 2024 at 6:30 PM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
  12. Feb 20, 2025 at 3:44 PM
    Kaiok3nC00pa
    Kaiok3nC00pa New Member
    Roy
    FromUndaTundra
    They took my side steps off and bed cover and sold it to me as if it had it
    What does M/T stand for? Mud tires? That truck is beautiful, what did you have to trim off
  13. Feb 20, 2025 at 4:42 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Looks very clean. How are these holding up? This is the size I am going with after my current tires are done. I prefer pizza cutters instead of extra width.
  14. Feb 20, 2025 at 7:06 PM
    woofhauler
    Pacifica, CA
    Holding up great! I like Duratracs, they have an updated version out I'll be trying next but for now plenty of life left on my current set.
    Pizza cutters are the way to go, https://www.youtube.com/watch?v=6wAJAOxh8LE (Tinkerer's Adventure vid)
  15. Feb 20, 2025 at 7:26 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Friend of mine runs Duratracs and said they handle well. I've ran the Toyo's and Falkens but wouldn't mind trying another tire. Looks like that size doesn't come in C range. E range is a lot heavier haha
  16. Feb 21, 2025 at 9:40 AM
    SYNCRO
    SYNCRO New Member
    Agreed on pizza cutter look! Also been struggling with the E vs C because of the weight difference.
  17. Feb 21, 2025 at 10:03 AM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    I used to run 285/75/17 on my Tacoma which was almost a 34” and C range. Though my tundra pro has the 18” rims so I can’t find any C range tires.
