Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Mar 19, 2019 at 8:36 AM
    #151
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    So I’m getting a 3/1 level installed on Friday and I ordered a set of ridge grapplers 295/65/r20 (35.12x11.77) I wanted to get the 285/65/r20’s (34.8x11.5) but they didn’t have any in stock. The 295’s are 0.32” taller and 0.27” wider than the 285’s
    I’m running stock suspension with the 3/1 readylift sst kit on 20x9 +20
    Do you think the slight height and width increase will cause any more issues than the plastic massaging/trimming , maybe skid plate that I was expecting? I don’t want to hit the cab mount or buy new suspension. Don’t really want to bottom out on the wheel well either
    The tire guide says 285/65/r20 will work and the readylift website says 295/65/r20 will work.
  2. Mar 19, 2019 at 10:01 AM
    #152
    Tundra$
    Las Vegas
    What did you cut/trim ?
  3. Mar 19, 2019 at 5:57 PM
    #153
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    Did you have to do a CMC, or just plastic trimming? I’m looking at getting a 20x9 with a -12 offset and trying to decide on tire size. Do you have any more pics? Thanks in advance.
  4. Mar 26, 2019 at 5:45 AM
    #154
    West Texas Tundra
    West Texas Tundra 2016 Bronze Beast
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    20 inch CECO wheels Drop in K&N air filter 2 inch front leveling kit
    Man I just picked up some 295/55/20s thinking they were not going to rub. Guhreat. I’ve got a 3rd gen with a 2” front lift.
  5. Mar 26, 2019 at 6:04 AM
    #155
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    are you saying they do rub? if so, what is the offset of the wheel you are using? my comment was for a wheel with a +50mm offset.
  6. Mar 26, 2019 at 6:08 AM
    #156
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    I don’t know the offset, I have some dick cepek wheels that came with the truck so I’m not sure how to figure it out. As of now, I have some 275/55 that are sitting flush with my fenders so I was thinking these 295/55 were going to stick out maybe .5 an inch.
    I called Cepek and they said the only way to find out is to break down the tire and look inside the wheel to find the offset. They weren’t very helpful on the phone.
  7. Mar 26, 2019 at 6:12 AM
    #157
    sundance
    sundance New Member
    You can run 285/55/20s or 275/65/20s with a 20x9 +20 and zero changes without rubbing.
    Boerseun likes this.
  8. Mar 26, 2019 at 6:40 AM
    #158
    Netmonkey
    Georgetown, TX
    you don't have go through all that trouble. the wheel offset is usually stamped on the inner (rotor) side of the wheel. all you have to do is remove the tire and look.
    for example (+35 offset):
  9. Mar 26, 2019 at 6:40 AM
    #159
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    All offset is is the distance in millimeters from the center of the wheel to the backside face that mounts to the hub.
    #1, Put a straightedge on the back rim of the wheel and use a tape or ruler to measure from your straightedge to that face in inches. Be very precise, down to the 1/16".
    #2, Divide your wheel width by two, you said you're on 20x9s, so it's 4.5".
    #3, This is where you determine whether you have positive or negative offset. If your measurement in #1 is more than the answer from #2, you have positive offset. Subtract #2 from your measurement in #1. If #2 is more than what you got in #1, you have negative offset. Subtract #1 from #2. If #1 and #2 are equal, you have 0 offset.
    #4, Multiple the answer in #3 by 25.4 to convert to millimeters.
  10. Mar 26, 2019 at 6:54 AM
    #160
    Netmonkey
    Georgetown, TX
    from your description, I would guess that the offset it either +18mm or +25mm.
    but pull a tire off and check the inside of the wheel :)
  11. Mar 26, 2019 at 7:09 AM
    #161
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    So what you think, are the 295s going to fit???
  12. Mar 26, 2019 at 7:12 AM
    #162
    Netmonkey
    Georgetown, TX
    295/55/20? yes. you may just have to trim or manipulate plastic a bit more. which shouldn't be too bad for that size.
  13. Mar 26, 2019 at 7:13 AM
    #163
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Hmmm. Nice, I figured it was going to be close. Man thanks for the input!
    Netmonkey likes this.
  14. Mar 26, 2019 at 7:29 AM
    #164
    Tundra$
    Las Vegas
    I posted this on the ultimate wheel/tire thread but I’ll add here.
    Readylift 3/1 sst kit
    Fuel sledge 20” wheels +20 offset
    35x11.5 r20 Nitto Ridge Grapplers
    Removed both front mud flaps, trimmed plastic behind front bumper. Missed the cab mount but very very close to rubbing
  15. Mar 26, 2019 at 2:41 PM
    #165
    Turk980
    Turk980 Freedom Isn't Free
    2019 Tundra Limited TRD Double cab
    Leveling kit, tires and wheels, fender flairs, nerf bar steps, flow master dual exhaust, spray in bed liner, rear airbags
  16. Apr 1, 2019 at 8:47 PM
    #166
    NoMoTaco
    NoMoTaco New Member
    Bluffton SC
    2018 Tundra DC TRD OR Silver
    Quick question
    Bumping front end up .75”
    Think 275/70/18 RG’s will fit with no issues at all?
    (6112’s lowest setting)
    Thanks
  17. Apr 1, 2019 at 9:10 PM
    #167
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Yes, I ran that size on stock suspension. It only rubbed the front mini flap in reverse at full lock.
    NoMoTaco[QUOTED] likes this.
  18. Apr 1, 2019 at 9:36 PM
    #168
    NoMoTaco
    NoMoTaco New Member
    Bluffton SC
    So the 3/4” while not much could eliminate the rubbing??
  19. Apr 2, 2019 at 7:48 AM
    #169
    equin
    Ed
    DFW, TX
    I think it depends more on the wheel offset, although lift may help alleviate, but not necessarily eliminate altogether, the rubbing up front.
  20. Apr 2, 2019 at 8:52 AM
    #170
    NoMoTaco
    NoMoTaco New Member
    Bluffton SC
    equin[QUOTED] likes this.
  21. Apr 8, 2019 at 9:00 AM
    #171
    LiftMeUp
    LiftMeUp New Member
    Stock UCAs? I want to run the 285/65/20s and trying to figure out same things.
  22. Apr 8, 2019 at 9:10 AM
    #172
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    I also Want to run 285/65/20’s waiting to see if anyone has any and how they look & fit. I have Front Bilsteins at 2.5” setting nothing in the rear.
  23. Apr 8, 2019 at 9:20 AM
    #173
    LiftMeUp
    LiftMeUp New Member
    Yeah, pics would be perfect. Same here, nothing in rear. I'm just going 3" because the rack from rear to front is about 3.25" (not normally seen). But the dealer was worried about providing that much lift in front would have the UCAs at an angle bringing them closer to the tires.
  24. Apr 8, 2019 at 9:24 AM
    #174
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    I had a had a very well known place where i live That does lifts and truck maintenance the owner did my truck and he said they would fit with some minor running would have to remove the flaps maybe and i also got some Spidertrax spacers so thinking i also Might have rubbing due to that.
  25. Apr 8, 2019 at 9:46 AM
    #175
    LiftMeUp
    LiftMeUp New Member
    Yeah, the guy at the tire shop said I may have to go with spacers but was looking to avoid that.
  26. Apr 8, 2019 at 9:47 AM
    #176
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Yeah i needed Them when i added Fender flares looked like my truck had big thighs and skinny legs lol couldn’t stand the look!
    LiftMeUp[QUOTED] likes this.
  27. Apr 8, 2019 at 10:04 AM
    #177
    Tundra$
    Las Vegas
    I ended up going with 35x11.5r20 ridge grapplers (they’re just a tad bit smaller than the 285/65’s). Just trimmed plastic behind bumper. Stock uca’s had plenty of clearance. I’m barely missing the cab mount.
    equin likes this.
  28. Apr 8, 2019 at 12:13 PM
    #178
    LiftMeUp
    LiftMeUp New Member
    You wouldn't happen to have any pics of tire well or where you trimmed plastic, huh? But it's encouraging that the stock UCAs had plenty of clearance and basically same tire. So you went with the
    295/65/r20s and went 3" on front right?
  29. Apr 8, 2019 at 5:21 PM
    #179
    Tundra$
    Las Vegas
    No I didn’t end up going with the 295’s I went with the ridge grappler 35x11.5xr20’s they’re a hair smaller than the 285/65’s. I have a +20 offset. Any bigger would prob hit cab mount. I’m missing by millimeters. The UCAs have lots of room
    Top pic you can kind of see where the plastic was trimmed. It probably could have been massaged but that’s what the shop did and I wasn’t there
    LiftMeUp[QUOTED], equin and NoMoTaco like this.
  30. Apr 9, 2019 at 7:30 AM
    #180
    LiftMeUp
    LiftMeUp New Member
    And you running a 3" lift on front?, can't remember.
    This is the specs I'm seeing for the two tires are: If they are correct, then yours would actually be a little bigger which is good for me as well. Plenty of clearance on the UCA but I'll be on stock wheels.
    285/65-20 35/11.5
    Diameter inches (mm)
    34.59 (878.5) 34.94 (887.6) 0.36 (9.1)
    Width inches (mm) 11.22 (285) 11.5 (292)
