Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Sep 8, 2018 at 2:04 PM
    #91
    PRO_Knock
    PRO_Knock New Member
    Enoch
    Harker Heights, TX
    2017 Cement TRD PRO
    Has anyone purchased the TOYO Open Country R/T on stock TRD Pro suspension? If so whats the biggest size you've gone with? I want to go with a bigger tire and was told 295/70R18 would fit but the R/Ts do not come in that size only the M/T's.
  2. Sep 24, 2018 at 6:16 PM
    #92
    nodnero
    nodnero I'm here legally yo!
    Temecula, CA
    Cement 2018 Limited 4x4 Crewmax
    18x9 Method 312 285/75R18 Toyo R/T Trail TRD Pro Suspension
    This thread helped me decide on my tire choice and I went with LT285/65/R18 AT3W on a (currently) stock setup. Minor rub at full lock in reverse but not anytime else. Also happy to report no diminished highway mileage, still getting 17.6MPG highway.
  3. Sep 24, 2018 at 7:16 PM
    #93
    Quadzilla
    Quadzilla New Member
    Dallas
    16 Tundra Platinum CM 4x4
    Do you have pics to share? Same set up I’m thinking about.
  4. Oct 4, 2018 at 7:54 PM
    #94
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    I don’t get it either, no one wants to provide info on the Rock Warrior package of the 2nd gen, but everyone seems to love the 17” wheels that came with it!
  5. Oct 4, 2018 at 8:08 PM
    #95
    fatalkhaos
    fatalkhaos New Member
    2019 Tundra TRD PRO CM
    Sway Bar 20x10 Fuel Assault 295/55r20 Toyo AT
    It doesnt answer question fully but i had bilstein 5100 3/1 level on my last Tundra
    295/55/20 Toyo AT fit... i had to only make mod when i qent to a 20x10 rim and it was minimal
  6. Oct 7, 2018 at 5:19 AM
    #96
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I don't think it is a stupid question at all, sometimes there are just no members who have the answers and then it goes unanswered.
  7. Oct 15, 2018 at 9:35 PM
    #97
    GPC Tundra PRO
    GPC Tundra PRO New Member
    Gabriel
    2019 Tundra TRD PRO
    Noob question as this thread been updated for the new 2019 TRD Pro?? I don’t know if the new suspension matters I read a few post here but everything is relating to the 2017 model. Desired tires I have in order are the nitro grapplers 295/70 r18
    doggiecareman likes this.
  8. Oct 16, 2018 at 8:02 AM
    #98
    sonusfaber
    sonusfaber New Member
    2008 Electric Blue 5.7 4Dr
    Hi Nodnero...I'm really thinking of going with these make/model tires. But I'm torn on the part of the website description that reads: "Designed for severe snow conditions". Is this in fact a winter tire? Will this not last as a typical daily driver tire? How do you use yours? Daily driver, normal road/hwy use? Thanks.
  9. Oct 21, 2018 at 4:39 PM
    #99
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    Would like to know max tire size on 2019 TRD Pro without any modifications?
  10. Oct 21, 2018 at 6:00 PM
    #100
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    This is the only 2019 PRO build I know of so far, looks like he’s got 295/70R18’s. The 19’s are so new still, not sure we’ll see a ton of builds for awhile.
    https://www.tundras.com/threads/pops-super-slow-pro.32922/
  11. Oct 21, 2018 at 6:29 PM
    #101
    15whtrd
    15whtrd Mr. Blonde
    I would imagine it’s no different than the previous pro, same offset wheels and I imagine the lift is about the same.
  12. Oct 21, 2018 at 6:41 PM
    #102
    GPC Tundra PRO
    Gabriel
    2019 Tundra TRD PRO
    I have the 2019 Pro I was able to fit 295/70 r18 Nitto Ridge Grapplers only mod was removing small front mud flaps.
  13. Oct 21, 2018 at 6:42 PM
    #103
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Probably, but if it were me I’d want more info beforehand just to be sure.
  14. Oct 22, 2018 at 12:48 PM
    #104
    toyohtadude
    toyohtadude Old man with a young mind....
    Eric
    Austin, TX
    2017 Tundra CrewMax SR5 4x4
    2017 4x4 with MotoFab 3/2 level kit, 20" OEM Limited alloy wheels (no spacers) and 285/65R/20 BFG T/A KO2 tires. I had to remove the small front mud flaps and trim the skid plate at the front on both sides. These tires caught the plate at full lock in both directions (where the plate protects the bends in the front sway bar). No other rub noticed.
    jetmonkey, zihyer, TUNDRA375 and 2 others like this.
  15. Oct 23, 2018 at 7:09 PM
    #105
    doggiecareman
    Eric
    North Central CT
    I am looking at a set of BF Goodrich T/A KO2's 275/70/18 from Costco OTD for 1104.00. Doesn't sound like I should have any issue as I plan to leave the suspension completely unaltered. I really like the E load rating 10 ply rating with the extra side wall ply that you don't get with the others to the extent you do with these KO2's. For whatever reason their inventory for 275/65/18's were discontinued.
    YeeYeeTundra likes this.
  16. Oct 23, 2018 at 8:09 PM
    #106
    GPC Tundra PRO
    Gabriel
    2019 Tundra TRD PRO
    You should be more than ok with those tires.
  17. Nov 3, 2018 at 7:42 AM
    #107
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Just wanted clarification. First post stated the platinum stock can go up to 275/60/20. I see guys with 285/60/20’s too. Will those 285’s rub? I was going to get a supercharger instead of a lift. So I want the biggest without rubbing. Just got the dual installed. Wheels/tires next, then sc.
  18. Nov 3, 2018 at 8:01 AM
    #108
    mattyd170
    mattyd170 New Member
    Rio Rancho, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    Stock for now, but have TRD Rear Sway bar for it.
    LOVE IT. Looks super bad ass. I think I am going with 275/65R20's.
    toyohtadude[QUOTED] likes this.
  19. Nov 4, 2018 at 5:40 PM
    #109
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    37/12.50R17
    You need a healthy BMC of course like you’d need when running 37’s. However they work well and look fantastic. I have the MCM Fab UCA’s and 3.0 ADS Coilover mid travel kit however ran into a bit of a hiccup upon installation. So I’ll just be running these like this till I can get what I need. Toyo Open Country MT. Icon Six Speed
    BMiller421, Quebec and equin like this.
  20. Nov 19, 2018 at 10:47 PM
    #110
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Got an 18 Crewmax 4x4, upgrading tires and rims on Black Friday. Here’s my setup, and I am trying to stay away from the CMC and new UCA’s. My question is how big of a tire can i go with and just have some minor molding/trimming of plastic and flap removal?
    - 6112’s at 2.5”
    - 5160’s in rear with 1” shackles
    - 17” Icon Rebounds
    - Going with Goodyear tires
    Help! My other option was getting 18” @SCSPerformance rims, but they’re a wee bit more expensive than the Icons, and just going with 295-70-18s.
  21. Nov 20, 2018 at 11:02 AM
    #111
    Bates5450
    Jacob Bates
    Dickinson, ND
    My opinion would be go with the 18’s unless your going to planning on some tires bigger than 35’s then 17’s are good. With the 18’s you can get 35” tires more narrow than what I’ve found available on 17’s. Also less rubber on road will allow more comfort while driving because they’re easier to balance.
    jewsNbrews likes this.
  22. Nov 20, 2018 at 11:05 AM
    #112
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Leaning towards 315-70-17’s...
  23. Nov 20, 2018 at 11:29 AM
    #113
    Bates5450
    Jacob Bates
    Dickinson, ND
    Those will do you well.
  24. Nov 27, 2018 at 4:57 PM
    #114
    Briggze2
    Briggze2 New Member
    2010 Tundra SR5 DC complete stock
    18” antenna only mod done lol
    How far do your tires stick out ?
  25. Dec 1, 2018 at 9:51 PM
    #115
    Pigglet222
    Pigglet222 New Member
    Factory height? Factory wheels?
    How did these work out for you?
  26. Dec 2, 2018 at 6:00 AM
    #116
    doggiecareman
    Eric
    North Central CT
    Factory height and factory wheels. Ended up staying with the OEM size of 275/65/18's. Multiple factors but ultimately feel either one is absolutely fine and don't believe from reading about other posts here that any mods would be necessary with the 70's. Still go back and forth as to whether or not I should have gone with the 70's.
    jerzeedivr and aturp34 like this.
  27. Dec 18, 2018 at 7:46 PM
    #117
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Just to update the largest tire size. With a 3/2 lift 285/65/20’s will rub and require trimming of the front well. You will also need a couple zip ties/heat gun on the front mud-flaps.
  28. Dec 27, 2018 at 8:42 AM
    #118
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Hey y’all! I read the whole thread & don’t think anyone has asked this. But would anyone happen to know how much leveling kits are with installation? Thank you!
  29. Dec 27, 2018 at 8:43 AM
    #119
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    $750-$900 with parts and labor
    KELZ84[QUOTED] likes this.
  30. Dec 29, 2018 at 11:01 PM
    #120
    Kirkulese
    Kirkulese New Member
    Kirk
    2019 sr5 trd sport
    You can buy a 3” leveling kit for 50$. Me and a buddy installed mine. Then just go get an alignment. I had a 2014 tundra with 3” lift in front and I ran 35x12.50x20. Can’t remember the offset. I sold the truck and now have a 19 I’ll do the same to.
    jerzeedivr, Haven and KELZ84 like this.
