Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Apr 18, 2023 at 1:07 PM
    #361
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    305s are supposed to have 8.5"+ rims, and stock are 8".
    I had 325/65r18s (35x13) on 9" +25 rims on mine without a lift, and I couldn't make them rub. The top of the fender which is where I thought I'd have issues. I did a BMC and a bunch of other things to make clearance fore-aft.
    Hammy44[QUOTED] likes this.
  2. Apr 18, 2023 at 6:52 PM
    #362
    Hammy44
    Hammy44 New Member
    Aram
    2008 silver sr5 Tundra
    I didn't get an answer in here and I decided to just get 285x65r18 lol...would you believe me if I said I got these for $550 brand new? It was such a good deal I couldn't pass it up.
  3. Apr 30, 2023 at 7:23 AM
    #363
    Munkeyphist
    Munkeyphist New Member
    Gary
    Maryland
    2016 Tundra CrewMax
    None
    Anybody here done the 2.5 inch levelling front end lift on their Tundra? Have the kit, not installed yet as I want to line up Tires and Rims to do it all at 1 time. Bought mine new in 2016 and came with Custom 20 inch PVD Rims. The Rims are shot as the PVD coating has almost all peeled off. Anyway, the tires on it from the dealer are 285/55/20's. Will replace the Rims with same size, but custom brand, and trying to find what size tire I can go with on the 2.5 inch lift, not a 2 inch, and not a 3 inch. Front end measurement is 36 inches from center Rim ground to top of front wheel fender arch. rear is 38.5 inches. Do not want to do any major trimming either. Any ideas, inputs appreciated. Later
  4. Apr 30, 2023 at 7:57 AM
    #364
    Hammy44
    Hammy44 New Member
    Aram
    Well, I can confirm no rubbing with stock wheels and 285/65r18. After and before...
  5. Apr 30, 2023 at 8:54 AM
    #365
    rruff
    rruff New Member
    What is your size preference? Do you want 37s?... because you can fit them with a 1"+ lift. What do you call major trimming? IMO the BMC is the biggest one if you don't know how to weld, but even then it's just a few $. Actually I cut mine and still haven't welded a plate on as I suspect it isn't needed... and so far that has been the case. Actually I don't think I even needed the BMC now that I've moved my wheels as far forward as I could with the alignment cams (max castor). The other "trimming" is basically free and not that much work. I have 35x13s.
    It's a common misconception that a lift using the shocks will gain you clearance. This is only true if you mount 37'+ tires and need clearance at the top of the wheel well. You may rub fore and aft with much smaller tires when you turn the wheel, if they are wide or stick out. Offset is important! And if you want to avoid rubbing even when you hit bumps, then a lift <6" won't help with clearance, vs zero lift.
    BTW, lift is measured from the hub center to the fender. Stock is ~22.0" front and 24.2" rear.
    Saltyhero13 and D4x4TRD like this.
  6. May 1, 2023 at 10:01 AM
    #366
    Munkeyphist
    Gary
    Maryland
    2016 Tundra CrewMax
    None
    Hi RRuff. Was looking at 295/65/20 for extra width and height on top of the 2.5 inch front end leveling to be added. I do need to change Rims as the stock ones that came with my model are the PVD coated type, and they are all basically 50% peeled off on all 4 wheels. Staying with 20 inch Rims just seemed easier knowing what I have right for clearance with my 285/55/20 tires on my 20 X 9 Rims. Have not looked at 37's though. With 20 inch Rims though, that might give the same results as you mention.
    Trimming is something i just have either neither the tooling, or space to do as I live in an apartment complex. I guess if I can find someone local who can cut, remove, reshape the front wheel well as needed, that is an option.
  7. May 1, 2023 at 10:46 AM
    #367
    rruff
    rruff New Member
    If you really have stock rims the width is 8" and the offset is +60. If you want to make life easy, blasting and powder coating those would be your best bet I think. Less offset (sticking farther outboard) is going to make fitting harder, and all the aftermarket rims stick outboard more, by 1"+. Using stock rims with 295/60s (not 295/65s) should make fitting/trimming really trivial, if you want to make it easy.
    Or you can see if you can find a place that will do the trimming for you... offroad shop probably. You don't need a lot of tools to make clearance, but if you don't have DIY experience, tools, or inclination or a place to do it... :confused:
    I'd recommend a 2" front lift, else you might be ass-low. Easier to align with stock UCAs also, and less wear on the front end.
  8. May 1, 2023 at 2:27 PM
    #368
    Saltyhero13
    Saltyhero13 Throbbing Member
    https://www.coastaloffroad.com/clearing-37-tires-on-a-toyota-tundra-at-any-ride-height/
    ghost0211, boomtime and rruff[QUOTED] like this.
  9. May 11, 2023 at 9:19 AM
    #369
    AVI_YOTA
    AVI_YOTA New Member
    07 TRD CrewMax
    Any idea on largest tire size for 2nd gen (2007) crewmax 4x4, 17 Icons +25 offset wheels. No lift or level for now, trying to avoid any trimming if possible. Thanks
  10. May 11, 2023 at 9:45 AM
    #370
    rruff
    rruff New Member
    The offset will make it hard to avoid some trimming with a decent size tire. A lift won't help either, not if you want to avoid rubbing when the suspension is compressed.
    285/75r17 is probably your best bet. 33.8" dia. Might be a little trimming but not much.
    AVI_YOTA[QUOTED] likes this.
  11. Jul 12, 2023 at 9:56 PM
    #371
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    295/70/18 Ridge Grapplers on 100% stock TRD Sport package suspension. No rubbing. I did remove the front mud guards, but I removed them way before deciding to try this combo.
    *This truck IS NOT the TRD PRO with the 2" higher front end.
    Possible keys to success-
    * Stock offset wheels
    * Aftermarket skid plate.
    Rdh1223, jomikepa, equin and 2 others like this.
  12. Jul 12, 2023 at 10:30 PM
    #372
    rruff
    rruff New Member
    Can't even rub the sway bar?
  13. Jul 12, 2023 at 10:32 PM
    #373
    BillyB
    BillyB New Member
    Billy
    AZ
    I'll give it a better look tomorrow and see if there is any red paint missing, but it didn't appear to.
    rruff[QUOTED] likes this.
  14. Jul 13, 2023 at 8:34 PM
    #374
    BillyB
    BillyB New Member
    Billy
    AZ
    Nope, no rubbing. Plenty of room.
    equin, JediMedic86 and rruff[QUOTED] like this.
  15. Jul 19, 2023 at 6:02 AM
    #375
    JesterUno
    JesterUno New Member
    Daytona Florida
    Stock 2016 2wd Off Road TRD
    None. Yet.
    I have a 2016 two-wheel drive with no lift. I see per this post that I can go to a 285 but with some trimming. Can someone show me what I need to trim? I've already taken off the mud guards.
    Thanks!
  16. Jul 20, 2023 at 10:44 AM
    #376
    JesterUno
    Daytona Florida
    None. Yet.
    Where does it rub???
  17. Jul 20, 2023 at 11:48 AM
    #377
    rruff
    rruff New Member
    I don't know about 2wd... but on 4wd you can fit 295/70r18s (~34.4" tire) on stock rims with no lift.
    Clearance issues (if any) are fore and aft. There are many threads that show how it's done.
    JesterUno[QUOTED] likes this.
  18. Jul 21, 2023 at 5:09 PM
    nodnero
    nodnero I'm here legally yo!
    Temecula, CA
    Cement 2018 Limited 4x4 Crewmax
    18x9 Method 312 285/75R18 Toyo R/T Trail TRD Pro Suspension
    That was 5 years ago... I think I remember the front splitter was the rub spot. It didn't last long. I put on Bilstein 6112/5160 within that week. Still have the same set going on 80,100 miles. Still dig the tires, probably go up to 35" when I put TRD Pro suspension on.
  19. Aug 8, 2023 at 7:03 AM
    #379
    EZdoz1T
    EZdoz1T New Member
    2010 white rock warrior
    I have 2010 rock warrior (gen2) currently has 285/70R17 didn't see any info for 17 inch rim gen2 no lift thanks in advance
  20. Aug 8, 2023 at 8:15 AM
    #380
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Comparable size from a R18 -> R17 would be 285/70R17
    32.7/11.2R17 is the actual dimension which matches the 285/65R18 they have listed for no lift
    rruff likes this.
  21. Aug 8, 2023 at 9:15 AM
    #381
    rruff
    rruff New Member
    Forget the listings.... see what others have done.
    I had my current tires (which are as tall as a 35 and wider) mounted for a couple years with no lift, and I could never make them hit the upper fender or liner. So a 35 is fine with no lift. The other places you need to look at are fore and aft in the wheel well, and inside to the shock and swaybar. Contrary to popular belief, a shock lift (vs a bracket lift) won't even help with clearance there.
    To fit the biggest tire with the least/easiest mods, you want to just clear the shock and swaybar. This means you don't want the rim offset to stick out very much. Your Rockwarriors are narrow (8") and stick out only 10mm vs typical stock rims, so they are near-ideal for fitting larger tires.
    Forward clearance is easy... if necessary, you can move the liner forward and also space the bumper forward a little. It's easy to move the wheel forward on Tundras using the caster cams... if you are outside spec on the high side that is totally fine.
    I just looked up the options in a 17, and was surprised to find that 315/70r17 (nominally 34.4x12.4) will fit on a 8" rim. That's what I'd get. If you don't want to go that big, 285/75r17 or 305/70r17 are pretty common too.
    ghost0211, equin and joseph_womack like this.
  22. Sep 2, 2023 at 5:50 PM
    #382
    Dawoofles
    Dawoofles New Member
    Cheyenne, WY
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    285/65/18 on a +25 18x9 wheel, would it fit on a stock suspension or would I need to look into a +35, or +40 wheel? Like to run a larger tire but also keep everything flush with the truck. No luck in finding some trail edition wheels to swap out my sr5 wheels.
    EZdoz1T likes this.
  23. Sep 5, 2023 at 5:08 AM
    #383
    wackyhacky
    wackyhacky New Member
    Keith
    Berthoud, CO
    2020 Limited Double Cab
    For what it is worth, I just mounted 285/65/18 on 18x8.5 wheel, ET 45 and it perfectly flush, with almost no poke out.
  24. Sep 27, 2023 at 5:41 PM
    #384
    Cova_84
    Cova_84 New Member
    Stephen
    Southern California
    2024 Terra Tundra TRD Pro
    Nitto Recon Grappler LT295/70/17 Taco Vinyl Heritage front grill vinyl Tint 50% windshield 15% all other windows. BAKFlip MX4 Bed Cover
    Hey everyone, I ask for a little grace for the question I’m about to ask. I have a 2024 TRD Pro. I don’t have much faith with the stock tires. I want to go with a set of Toyo Open Country R/T Trails in LT 295/70/18. Does anyone have experience with this time on the new gen’s? Any rub? I appreciate the responses. I’ve attached a picture of my rig for reference.
  25. Sep 27, 2023 at 6:30 PM
    #385
    rruff
    rruff New Member
    If you are going to put those tires on the stock rims, you'll be fine... based on the testimony of others.
  26. Sep 27, 2023 at 7:37 PM
    #386
    Cova_84
    Cova_84 New Member
    Stephen
    Southern California
    Thank you for the response. That gives me a bit more confidence wanting to pull the trigged.
  27. Oct 2, 2023 at 7:40 PM
    #387
    Tricardo
    Tricardo New Member
    Ricky
    Will 295/70r18 with a 18mm to 30mm rim offset fit on 2020 4x4 tundra sr5 stock tundra? Looking to upsize tires but not sure if they will fit
  28. Nov 8, 2023 at 12:30 PM
    #388
    BryMan83
    BryMan83 Slappin da bass mon
    Rio Rancho, NM
    2022 Tundra SR5 TRD OR 4x4 CrewMax
    Definitely the aftermarket wheel offset. I have these exact same tires, same size on the stock TRD OR wheels and have zero issues with fitment. Full lock, flexing, they work great on the stock wheels.
  29. Nov 8, 2023 at 2:10 PM
    #389
    rruff
    rruff New Member
    Yes, they will fit. You might need to trim, move, or manipulate plastic in the front or rear of the wheelwell. Higher offset will have better clearance. Stock is +60 and those wheels can take 295s.
  30. Nov 21, 2023 at 1:41 PM
    #390
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Looking at 34s (275/65/20) for a 2024 tundra SR5 but little unclear if these work for the 4x4 Sports on OE TRD wheels? No mods, to suspension. Any help greatly appreciated
