Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Sep 21, 2021 at 3:47 PM
    #331
    Mcdqpr
    Mcdqpr New Member
    Maybe someone here may know, Will 275/55/20 fit stock 2020 SR5 with no rubbing?
    thanks!
  2. Sep 21, 2021 at 5:16 PM
    #332
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    I have 285/55R20 on my stock 2017 SR5 Tundra. All part of the Southeast region TSS package wheels. So the 275/55R20 should not be an issue. Also, the first post says that 270/60R20 is the max for stock, so you should be good to go.
    ghost0211 likes this.
  3. Sep 21, 2021 at 5:53 PM
    #333
    Mcdqpr
    Mcdqpr New Member
    Thanks. Does the TSS package come with a different suspension than regular stock?
  4. Sep 21, 2021 at 7:24 PM
    #334
    3rdTundra
    Central Texas
    No, standard suspension
  5. Nov 14, 2021 at 10:19 AM
    #335
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    so with all these posts has any one have issues with hitting aftermarket sid plates!mind are RCI ones! want to stick stock size tires on a 9" wide wheel! ! have 275/65/18 thanks
  6. Jan 3, 2022 at 9:06 AM
    #336
    Mjrpa
    Mjrpa New Member
    I have a 2020 SR5 Crewmax with the TRD Sport package. Can I fit 22x12's with low profile tires without having to modify the suspension? If so, what tire size can I go with to avoid rubbing? Mud guard have already been removed.
  7. Jan 4, 2022 at 5:03 PM
    #337
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    Stock suspension
    18x9 wheels with +18 offset
    275/70 tires
    No go on my truck. Ended up removing the front air deflector and will need to get the leveling kit installed ASAP. I'm shocked how little room there is to go up in size. I did 34x12.00 on my Ram 1500. Oh well these will be ok!
    Sonicbluerider likes this.
  8. Jan 5, 2022 at 11:48 AM
    #338
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Factory +60 offset and you'd probably be fine. I think its the +18 causing the issue.
    Ace96 and WXman[QUOTED] like this.
  9. Jan 5, 2022 at 2:05 PM
    #339
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    It is the offset of the rims. I run 275/70s no lift on stock wheels +60 offset. You can actually fit 285/70 or 295/70 on stock wheels, no lift.
    JoshO and WXman[QUOTED] like this.
  10. Jan 5, 2022 at 2:33 PM
    #340
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    easy fix if you trim the extra plastic from your flaps and push the liner in front of the wheel forward. i had the exact same scrubbing spots as you and in an hour have a rub free truck to full lock on 275/65/20's with +20 offset.
    WXman[QUOTED] likes this.
  11. Jan 6, 2022 at 1:22 PM
    #341
    localmotion
    localmotion New Member
    Love this thread since it has a ton of info on tire size and what lifts are required.
    There is a consensus that 275/60/20 on Platinum OEM wheels will fit on the Tundra with no modifications.
    I am unclear if 275/65/20 with OEM Platinum wheels without modification, ie: factory non-trd skid plate cutout or mudflap removal.
    Is anyone running 275/65/20 Platinum/OEM wheels with a TRD Skid Plate or RCI? I plan on getting either one to make oil changes much simpler.
  12. Jan 7, 2022 at 8:50 AM
    #342
    PlatinumPro
    i was running 275/65/20 on stock platinum wheels for a few months before i switched up my wheels. They'll tuck in and fit and on a level surface will likely be perfect but as soon as the truck leans or is backing and turning you're likely going to be scrubbing the front spads, the rear flaps (both of which will eventually be ripped off if not manually removed) and i have the stock skid plate which needs bending.
    my truck is also sits about 2.5" higher than stock on 6112's but i'm not sure if it affects the tire fit.
    Boerseun likes this.
  13. Jan 8, 2022 at 6:18 PM
    #343
    localmotion
    Thank you!
    Im going to stick with 275/60s for now…
    PlatinumPro[QUOTED] likes this.
  14. Feb 2, 2022 at 1:27 PM
    #344
    tsgoodwin23
    tsgoodwin23 New Member
    2020 tundra TRD Sport
    Does this account for the TRD Sport’s lowered suspension on the 20 inch wheels?
  15. Feb 6, 2022 at 12:41 PM
    #345
    rattmobbins
    rattmobbins New Member
    2021 Platinum 4x4
    :worthless:
  16. Feb 28, 2022 at 6:38 AM
    #346
    BayRunner
    2017 Tundra Platinum
    In my local off-road shop getting my Alcan springs put on and saw this.
    Question: will this fit on stock suspension? :eek2:
    46x19.5x16
    Rigger and SAGE63 like this.
  17. Feb 28, 2022 at 6:50 AM
    #347
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Imagine the gas mileage threads on this forum with those tires......
  18. Feb 28, 2022 at 6:53 AM
    #348
    BayRunner
    Lol…yup, the tire alone comes in at 137 lbs.
  19. Apr 24, 2022 at 8:03 PM
    #349
    sikdog
    sikdog New Member
    2005 double cab limited 4WD with 275/70/17 Mickey Thompson Baja Legends on stock wheels. Has a Rancho Quick lift coilovers that level it. 4CF592F3-AB2B-421F-9126-188B5B76E28C.jpg
    D4x4TRD and Pbed85 like this.
  20. Apr 24, 2022 at 8:07 PM
    #350
    sikdog
    sikdog New Member
    Another pic
    D4x4TRD likes this.
  21. Apr 24, 2022 at 8:08 PM
    #351
    sikdog
    sikdog New Member
    Another pic
    D4x4TRD, pvmike and Hbjeff like this.
  22. Jul 6, 2022 at 8:29 AM
    #352
    tunpunch
    tunpunch New Member
    Cord
    2007 TRD DC 4X4
    Hey I know this post is from a while ago but you have no spacers, leveling kits, 5100's or shims? Everything is stock?
  23. Jul 24, 2022 at 12:10 AM
    #353
    1WIDETRD
    1WIDETRD 8 Footer
    James
    Charleston, S.C.
    2019 TRD Wide Body (8 Footer)
    Recently Divorced.
    Anyone on 24 x14's on 33x14 MTs.... Now there's a discussion starter.
  24. Apr 3, 2023 at 11:16 AM
    #354
    Hammy44
    Hammy44 New Member
    Aram
    2008 silver sr5 Tundra
    So I've got a 2008 Tundra with stock wheels from a 2009? I think. I wanna run 305x60r18 instead of 285x65r18. Will the 305s not fit because it's wider? I like wider tires more than narrow tires. I literally just got this tundra a week ago so I'm not familiar on the offset on these wheels. I recently moved into the tundra from a 97 80 series that I had built with 2.5 inch lift and 35s. I plan on leaving the tundra completely stock, suspension wise. Thanks in advance.
    D4x4TRD likes this.
  25. Apr 11, 2023 at 9:24 AM
    #355
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    Truck currently has 285/75/16s on it, just ordered 4 of the same. Based on this, I may have a problem! Uh oh. Hope not. (2000 4wd sr5). They've already shipped. :confused:
  26. Apr 11, 2023 at 4:30 PM
    #356
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Don't believe everything you read....
    Hbjeff likes this.
  27. Apr 12, 2023 at 6:12 PM
    #357
    icodeintx
    icodeintx New Member
    Scott
    Bryan, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    man that's purdy... I'm looking to fatten up my tires too and put on a 3.5 lift. soon... soon...
  28. Apr 12, 2023 at 7:26 PM
    #358
    rruff
    rruff New Member
    If you like that, then do 1.5-2" lift and run stock rims with 295/70r18. No reason to go higher.
  29. Apr 12, 2023 at 8:26 PM
    #359
    icodeintx
    Scott
    Bryan, Texas
    That sounds good. I'll check into that size lift as well, will see what they offer. I have R20 stock rims so I'll probably have to go to 295/60r20
    rruff[QUOTED] likes this.
  30. Apr 18, 2023 at 12:10 PM
    #360
    SouthwestSon
    SouthwestSon New Member
    Rob
    Which one?
    Not yet :-)
    I'm looking to do the same size; just talked to 1010tires. A 9" rim with 20mm offset gets you 27mm more inner clearance, which will accommodate the additional 1.25" of tire width. (or go with 25mm offset). Will post the results when I make it happen :) Afterthought: Need to ensure that the tire is true to size including sidewall lugs.....
    Hammy44[QUOTED] likes this.
