Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Jan 5, 2021 at 7:40 AM
    #301
    305TUNDRA
    305TUNDRA New Member
    2012 Crewmax XSP
    I have a 2012 Crewmax with 305/50r20 they are the BBS 20x9 +50 offset with 1” clearance to UCA and 1.5” fore and aft to mud flaps.
  2. Jan 6, 2021 at 10:50 PM
    #302
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    Looks awesome! I think you convinced me to run the same tire size. I have the Bilsteins 5100 on all 4 corners and it’s leveled. Should work! Thanks for sharing
  3. Jan 14, 2021 at 2:52 PM
    #303
    BentJr
    BentJr New Member
    Ben
    2019 Tundra Crewmax Limited Cement 4x4
    How is the ride difference with those 5100's up front and the 1 " in the rear? and can I ask what brand or what approach you did in the rear of the truck? TIA
    biebs96[QUOTED] likes this.
  4. Jan 14, 2021 at 6:27 PM
    #304
    biebs96
    PA
    I had the 5100s installed before the block and the upsized tires for about a week.
    The ride was noticeably more planted feeling and the steering/cornering was much more responsive/tighter feeling.
    The tires were installed and that afternoon I installed the rear block.
    The tires obviously change the ride feel. They are heavier, stiffer sidewalls and more aggressive treads.
    The rear block is a rough country block which came with new, long U bolts. Install is simple if you have the means. I did it in the driveway with two jacks, four jack stands and a torque wrench.
    The ride overall after everything is installed and done is certainly more “truck-ish” but by no means uncomfortable. For me, this lift/tire combo was done to achieve as close to a factory ride, while achieving a comfortable ride, as this vehicle is my daily commuter along with the family traveling vehicle.
    Hope this helps. Any questions, let me know.
    BentJr[QUOTED] likes this.
  5. Feb 1, 2021 at 10:10 AM
    #305
    CoryShap09
    CoryShap09 New Member
    Cory
    2020 CM XP
    I have a 2020 CM SR5 XP with 5100s on the second setting. Can I fit 295/70-18 on my stock wheels? If not, what would be my next best bet?
  6. Feb 3, 2021 at 10:43 AM
    #306
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    From what I've heard you should only have to remove the small front flap, maybe trim/adjust the skid plate a little, and reposition the front bumper liner. I was originally going to go with this size on the same set up (5100's mid setting) but think I may just stick with 275/70r18's. Wish there were more options available in 285/70r18's. That is the perfect size for these truck on a small lift/level IMO.
    CoryShap09[QUOTED] likes this.
  7. Feb 6, 2021 at 5:57 PM
    #307
    Tropnevad
    Tropnevad New Member
    A-dog
    2018 TUNDRA TSS Magnetic gray
  8. Feb 14, 2021 at 8:30 AM
    #308
    Calidude7
    Calidude7 New Member
    Anyone here have, or know about someone running Bilsteins 5100's with BFgoodrich 295X60X20?
    if so is there any major trimming going this route, I would love to get answers before I put myself in a no back situation.
    NoRcptn likes this.
  9. Feb 15, 2021 at 12:35 PM
    #309
    Dustoff55
    Dustoff55 New Member
    Tennessee
    2017 Limited TRD 4x4 MBM
    OEM Audio Plus, Reference 500Q. Leer 100XL
    BFG T/A KO2 275/70/18 on stock 2017 DC TRD Off Road, zero rubbing issues. Just came back from Discount Tire where they weren’t busy and had me in and out in an hour! Ready for snowmageddon.
  10. Feb 21, 2021 at 6:54 PM
    #310
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    I have my lift but cannot put on till Saturday. However I bought 17” Method 312s with 0 offset and 35x12.50x17 ridge grapplers. Gonna see how they fit on stock height for experimental purposes. Should be interesting with that offset.
    mcharfauros, wodje96 and Burdturger like this.
  11. Feb 23, 2021 at 6:30 AM
    #311
    Tonkatoytaco
    Tonkatoytaco New Member
    Louie
    Maryland
    2017 Platinum XP MGM
    LRO 3/1 Leveling Kit, Dirty Deeds 10" exhaust, Bully Dog Programmer, AFE Super stock Intake with TB Spacer, Custom Rough Country Grill, Andres Devil Horns, Caliraised Fog lights, Morimoto XB Headlights, HRS taillight, Boost Auto tow mirrors, LED interior lights and Reg, light, Trail edition bed compartment, TRD rear sway bar, weathertech floor mats and window visor, Nitto Ridge grappler.
    subd, good information, nice write up
  12. Mar 28, 2021 at 2:25 PM
    #312
    Redcon41318
    Redcon41318 New Member
    Will oem rock warrior wheels with 285/70/17 fit with no rub on a 3rd gen?
    mcharfauros likes this.
  13. Mar 30, 2021 at 10:14 AM
    #313
    ConspiracyOfOne
    ConspiracyOfOne New Member
    Raymond
    Husdon Valley NY
    2021 TRD Sport MGM
    I must be the only one looking at a narrower tire? 265/60/20 Michelin Agilis
  14. Apr 9, 2021 at 5:19 PM
    #314
    birdman86
    birdman86 New Member
    Man just when I think three hours of reading the 'Lets see your wheels thread' has me understanding this stuff, this post throws it out the window.
    I thought I'd figured out that, with a stock '17 TRD Offroad there should be no problems or rubbing with:
    295/70R18's on +25 wheels
    285/75R18's on +20
    Or am I out to lunch??
    Would be Wildpeak AT3W's fwiw
  15. May 14, 2021 at 3:05 AM
    #315
    F.N.G MOTO
    F.N.G MOTO New Member
    2019 Tundra TRD
    Did you have to trim the body mount? Im going with the bilstiens 6112 up front set at 1.9 and the 5160 in the rear. Going with a 18 rim +20 offset.
  16. May 15, 2021 at 4:25 AM
    #316
    F.N.G MOTO
    2019 Tundra TRD
    How did it go? I want the same tire but on 18
  17. Jun 9, 2021 at 11:39 AM
    #317
    StockedUp
    StockedUp If you come to a fork in the road, take it.
    Carrollton, TX
    2018 Black 1794 4x4
    TBD
    2018 Stock Platinum Wheels with 295/60/20 on 3/1.5 lift
    I simply wanted to share in the event someone was wondering like I was a month ago. There are a few rigs on here that put on 295/60/20's with stock wheels, but none that I saw were running them on the platinums. I was told by a local shop that although the offset was the same (60+) the TRD's had a "lip" that allowed for a wider arrangement of tires and the 295/60's would likely require body cutting with a 3/1.5 lift. After talking with a few of you on here, I was confident the shop was incorrect.
    I'm happy to say, indeed they were. I did front Bilstein 6112's on top setting (2.75" but sits closer to 2.6" with heavier 4x4). Also added a Toytec 1/4" strut shim to get me close to 3". Added the CB front bumper shims, 1" wheel spacer and removed front spat. Did a procomp lift kit for the back and ended up swapping the 1" block with a 1.5" RC block for the rear. Glad I did because I'm almost level. Wanted to ensure the radar worked as I heard some had issues with level rigs. Please to report all systems retained their function. Good clearance all around.20210607_183931.jpg 20210608_083418.jpg 20210607_173748.jpg Truck Height Change.jpg 20210607_173721.jpg
    SHAKA U F4KA and Turk980 like this.
  18. Jun 27, 2021 at 5:02 PM
    #318
    jetmonkey
    jetmonkey New Member
    Peoria AZ
    2019 Platinum Crew Max - (Sold) 2005 Double Cab TRD
    Retrax Bed Cover...more to come...hopefully.
    That looks great! Does it still fit in the garage?
  19. Jun 27, 2021 at 5:30 PM
    #319
    StockedUp
    Carrollton, TX
    2018 Black 1794 4x4
    TBD
    Thanks. Fine on the height as I assume you're asking. Barely fits length in my small garage.
  20. Jun 27, 2021 at 5:46 PM
    #320
    jetmonkey
    Peoria AZ
    Yeah I was asking about height because it looks so tall. I have 2019 Platinum with those wheels and I'm trying to figure out how I want to set it up but I need it to fit in a standard garage. Thanks your truck looks awesome.
  21. Jul 4, 2021 at 12:39 PM
    #321
    Gamer68
    Gamer68 New Member
    2016 Toyota Tundra limited
    2.5 front lift//Hooke Road Front Bumper w/lightbar//20" Black spoke Fuel Wheels//Weather Tech Floor mats//Black Waterproof seat covers//Hard tri-fold tonneau cover//
    So I read the thread about tire fitment. Here is my query. 33 x 12.50 x 20 on Rockstar 20x10. I am running 275/60/20 with stock wheels. Math says the 33 package is .01 taller and 1.5 wider. Stock 16 limited tunnie. Found the used 33 package and interested on fitment from the pros.
    Your thoughts.
    B
  22. Jul 6, 2021 at 9:55 AM
    #322
    Turk980
    Turk980 Freedom Isn't Free
    2019 Tundra Limited TRD Double cab
    Leveling kit, tires and wheels, fender flairs, nerf bar steps, flow master dual exhaust, spray in bed liner, rear airbags
    Didn't do Anything to body mounts. Just had to remove the little mud flaps and some minor changes with the wheel well liner
  23. Aug 9, 2021 at 8:57 PM
    #323
    AZ_BO
    AZ_BO New Member
    Ricardo
    Colorado Springs, CO
    2018 Tundra SR5
    1) Leveling kit 2) Sound system upgrade 3) Color matched grill 4) Leather seat covers
    Have a dumb question…when one says you have to trim in order to fit certain tires/wheel combos, what does trimming entail? I’ll be putting in a 3” lift kit to my 2018 SR5 CM.
  24. Aug 10, 2021 at 5:45 PM
    #324
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    You might have to cut some of the plastic by the bumper and part of the mudflap behind the front tire to prevent the tires from rubbing or hitting.
  25. Aug 10, 2021 at 5:47 PM
    #325
    AZ_BO
    AZ_BO New Member
    Ricardo
    2018 Tundra SR5
    Cool, that’s what I was hoping for. I’ve seen some people chop up part of their bumpers and I wasn’t having any of that noise.
    equin[QUOTED] likes this.
  26. Aug 11, 2021 at 10:20 AM
    #326
    AZ_BO
    AZ_BO New Member
    Ricardo
    2018 Tundra SR5
    I'm torn between 34x12.5R18 and 275/70R18, both BFG KO2s. Would one give better ride quality than the other?
  27. Aug 12, 2021 at 9:03 AM
    #327
    StockedUp
    Carrollton, TX
    2018 Black 1794 4x4
    TBD
    In my experience, albeit small, with a 3" lift you're going to have rubbing with the 34x12.5. This doesn't even address wheels/offset and/or wheel spacers. Even with cutting of plastic and removal of the front spats you'd have rubbing imo. The alternative may be a cut and weld job or adding a front bumper shim like this https://shop-coachbuilder.myshopify.com/products/coachbuilder-front-bumper-shim-kit
    The 34 is obviously a 34", the 275/70 is just over 33" but the 34 being much wider. The combination of the additional diameter & width would cause the rub. Good luck!
  28. Aug 14, 2021 at 11:24 AM
    #328
    AZ_BO
    AZ_BO New Member
    Ricardo
    2018 Tundra SR5
    Thanks for the detailed reply, I appreciate it!
    StockedUp[QUOTED] likes this.
  29. Aug 27, 2021 at 4:59 AM
    #329
    TheSheriffisNear
    TheSheriffisNear New Member
    2019 Toyota Tundra 1794 Crewmax 4x4
    I put 275/65/20 Nitto Recon Grapplers on a 2019 1794 CM 4x4, (stock wheels, stock height) yesterday without a single issue. No rubbing to be found. Hope this helps someone out there.
    TipToeTyler and ToyoLife like this.
  30. Aug 27, 2021 at 5:19 AM
    #330
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Impressive. That's almost 2" larger diameter than my stock (TSS Offroad package) 285/55R20. at 34.1" vs. 32.3". It's also an inch taller than what is listed on the first post for the largest 20" tire on Gen3 with stock height of 275/60R20 or 33".
