Largest tire size with 4" lift?
Discussion in 'Wheels & Tires' started by Acop215, May 15, 2016.
  1. May 15, 2016 at 9:33 PM
    Acop215
    Acop215 [OP] New Member
    2016 toyota tundra sr5 crew
    I bought my Tundra a few months back and now want to add 4" suspension lift. I have no idea what the maximum tire size I can go with once doing the lift. Can anyone give me some insight on this. I have a 2016 Tundra SR5 Crewmax
  2. May 15, 2016 at 10:31 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    It depends...are you willing to cut your fenders? What tire size do you want to run? How do you intend to use the truck?
  3. May 15, 2016 at 11:09 PM
    Acop215
    I prefer to not do any cutting or trimming. I'm wanting to run 35x12.5x20. Truck is simply used for daily commute.
  4. May 15, 2016 at 11:25 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    35s will fit on a 4" lift with the proper wheel offset. Some trimming of front ww plastic may be needed and removal of front mud flaps.
  5. May 15, 2016 at 11:49 PM
    Acop215
    Can you tell me what the proper wheel offset I will need if I use the stock wheels
  6. May 16, 2016 at 5:28 AM
    Stock wheels are +60 IIRC
  7. May 16, 2016 at 7:06 AM
    Acop215
    Do know what wheel spacers I will need to get with putting 35x12.5x20 on stock 20" wheels
  8. May 16, 2016 at 9:17 AM
    csuviper
    Broomfield, CO
    1" or 1.25". I would just go to the 1.25" as they are the most common. Spidertrax or Bora.
  9. May 16, 2016 at 9:38 AM
    Acop215
    Thank you
  10. May 16, 2016 at 10:44 AM
    BuggyMasters
    BuggyMasters New Member
    I have the 4" ReadyLift on mine (includes new upper control arms) and I run 295/60R20 tires on DropStars 20x9 rims with the +18 offset. Removed the mudflaps and the lower front section of front liners and all is good. The +18 puts the outer edge of the tires just outside the fenders. The 1.25 spacers should put you right at the edge of the fenders I would think using stock rims.
    ALLIDOISWIN likes this.
  11. May 16, 2016 at 10:54 AM
    BuggyMasters
    Should add....be prepared for sticker shock on tire prices as you get wider. For example a 275/60/20 Terra Grappler G2 is $217 which to me is tolerable. Just going up to a 295 bumps it to $325 per tire!! Looks like the 35/12.5's are about $350 a piece right now.
  12. May 16, 2016 at 12:50 PM
    Acop215
    Thank for the pics. It definitely helps to see what it will look like. I'm going to try the stock wheels out to see how it looks. I like the Dropstars you have. Very nice truck there
