Largest spare tire?
Discussion in 'Wheels & Tires' started by TuffTRD, Aug 25, 2018.
  1. Aug 25, 2018 at 11:17 AM
    TuffTRD
    TuffTRD [OP] New Member
    2014 Double Cab
    3/1 ProComp level, 20x9 Fuel Vector, 295/60R20 Toyo A/T
    Can anyone tell me what the largest spare tire that will fit into the factory location under the bed? I have 295’s on the truck now, and would like to have same size for a spare.
  2. Aug 25, 2018 at 11:59 AM
    I know some guys have put a 35" tire under there it's tight but will fit.
    Williams and TuffTRD[OP] like this.
  3. Aug 25, 2018 at 12:09 PM
    TheBeast The Beach
    295 will fit with some moving/cutting. 35" maybe if it's used a bit.
    040Tundra likes this.
  4. Aug 25, 2018 at 12:16 PM
    305/70/18 under mine
  5. Aug 25, 2018 at 1:37 PM
    TheBeast The Beach
    STT Pro ? big lugs for big boys
    because_wumbo-truck and Pinay like this.
  6. Sep 27, 2018 at 2:33 PM
    mrflyinghigh
    mrflyinghigh New Member
    Jared
    2018 Blazing Blue Tundra Platinum
    Would a 305/55/20 fit?
  7. Sep 27, 2018 at 2:45 PM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    35" tire fit on stock location
  8. Sep 27, 2018 at 2:48 PM
    crochetjohn
    crochetjohn New Member
    2015 Inferno TRD Pro
  9. Sep 27, 2018 at 2:54 PM
    mrflyinghigh
    Jared
    Any modifications to fit the aftermarket wheel?
  10. Nov 25, 2018 at 2:35 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Would a 35 still fit with a TRD dual?
  11. Nov 25, 2018 at 7:16 AM
    Rica25
    Ricardo
    Tulare
    Does the spare rim and 295 70 18 have an issue with UCA?
  12. Nov 26, 2018 at 9:47 PM
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    I have 295 70 18 tires on 18X9 +25 rims, and ordered a fifth tire for the stock spare rim. If I get a flat on a front tire, can I put the spare on the rear and then the rear on the front to replace the flat? I know that with the offset on the front, I’d be rubbing like crazy, but didn’t know about the rear.
  13. Nov 27, 2018 at 4:25 AM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    I asked this question in another thread but maybe this the better one.
    Is there a downside to a full height but narrower spare? Something like a 255/80r18 would be cheaper and should only be temporary. Any negative impact to traction control?
    Jsena likes this.
  14. Nov 27, 2018 at 10:36 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    If the spare is the same diameter as the other rear tire you should be fine. If it's a different size, it could cause an issue with the rear differential.
  15. Nov 27, 2018 at 10:38 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I doubt it would be an issue.. look how much smaller a donut tire is compared to reg tire.. put it on, get to a shop and take it off.. ¯\_(ツ)_/¯
  16. Nov 28, 2018 at 4:37 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Not really a width issue. It’s more of a height. I don’t believe anything over 35 will fit. So as long as you are 35 or under you are good.
    bigblue14[QUOTED] likes this.
  17. Nov 28, 2018 at 6:02 AM
    bigblue14
    Craig
    Right this is what I thought but I wanted to make sure I wasn't missing something with the electronic traction control.
  18. Nov 28, 2018 at 9:20 PM
    bmcdds
    bmcdds New Member
    CA
    Thanks. I’m assuming that if I have a flat in the front, I can’t put the 295 70 18 +60 offset spare on the front though. Wouldn’t it have to go on the rear due to the +60 offset?
  19. Nov 29, 2018 at 11:44 AM
    equin
    Ed
    DFW, TX
    The tire might rub the upper control arm or skid plate or both, or it may not rub anything at all. I’d test fit it and then address whatever rubbing it may have, if any.
    bmcdds[QUOTED] likes this.
  20. Nov 29, 2018 at 12:24 PM
    TheBeast The Beach
    last thing you wanna do is play with a donut in the middle of nowhere with no cell reception or AAA. I recommend full size spare. And sometimes one is not enough either.
  21. Nov 29, 2018 at 12:58 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Would the 35 fit with coachbuilder shackles installed? Looks close to the stock shackles
  22. Nov 29, 2018 at 1:35 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Depends on the size of the tire. If it's a small 35, maybe. If it's a large 35, it will rub.
    NewImprovedRon and GodlessPro like this.
  23. Nov 29, 2018 at 1:48 PM
    2014 Tundra Boy
    2014 Tundra Boy New Member
    2014 White Tundra TRD
    I have the same size tire mr.flying high and was wondering the same thing. 305x55x20
  24. Nov 29, 2018 at 1:50 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Yes, that's barely larger than a 33". It'll fit no problem.
    GodlessPro likes this.
  25. Nov 29, 2018 at 1:51 PM
    2014 Tundra Boy
  26. Dec 3, 2018 at 11:44 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Anyone with 35 spare see it touch their exhaust ?? What to do???
  27. Dec 3, 2018 at 11:55 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :mad::censored: The struggle
  28. Dec 3, 2018 at 12:24 PM
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    35x12.5R18 KO2's on stock TRDP rims, fit without any issue.
    equin and Jsena like this.
  29. Dec 3, 2018 at 12:46 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    My exhaust is after market pipes n all. Waiting for my cousin to come over and turn it up while I push it from underneath to see what exactly is hitting .. FML
  30. Dec 3, 2018 at 12:48 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    No
