Larger tires affect on towing?
Discussion in 'Towing & Hauling' started by proROB, Apr 10, 2019.
  1. Apr 10, 2019 at 8:47 AM
    proROB
    proROB [OP] New Member
    Robert
    Temecula, Ca.
    2017 Tundra TRD PRO
    Hey all, we are going to be buying a new boat here soon, and while I don't think it will be an issue, I just want to get some clarification on towing. Our stock gearing is 4.30, the stock tire size is 32". Stock towing is 9,000 pounds.
    Increasing to the 295/70-18 size tire, size increases to 34.3, this effectively reduces the stock gear to 4.02.
    Question, how will the lower gear affect towing? will it decrease it substantially? just make it harder to tow? etc., I'm considering buying a cheap set of rims and stock size tires to use when towing, but if it's not necessarily, id hate wasting the money on it. what are your guys thoughts?
  2. Apr 10, 2019 at 8:51 AM
    TTCrewmax
    TTCrewmax New Member
    I basically have the same tire size - but in a 20" and the only thing it will affect is the MPG. You won't notice a loss of power. I'm pulling about 10K when my trailer is fully loaded. I set the cruise at 62 (really 66) and enjoy the drive.
    Mnorris1206 likes this.
  3. Apr 10, 2019 at 9:45 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You’ll be fine
  4. Jul 7, 2020 at 11:07 AM
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    2020 Silver Tundra Crewmax Limited 4x4
    You use cruise control while towing?
    Medic343 likes this.
  5. Jul 7, 2020 at 11:19 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    I do all the time.
  6. Jul 7, 2020 at 11:21 AM
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    I would t recommend that. Owners manual even says not to use cruise while towing. Lol if it works for you go for it.
  7. Jul 7, 2020 at 11:32 AM
    snivilous
    SW UT
    I can understand it not being recommended for your normal person who is ignorant and doesn't pay attention to their truck making noises or feeling things. It's not gonna hurt it being on flat ground with cruise control on, I know when the truck is happy and when I need to take over control. Nothing wrong with it chugging along not shifting and letting my leg rest.
  8. Jul 7, 2020 at 11:36 AM
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    just curious what MPG do you get normally not towing and when towing with your 295/70/18?
  9. Jul 7, 2020 at 12:28 PM
    snivilous
    SW UT
    Not towing is usually 13mpg, that's with the supercharger and it was maybe 1mpg higher before the blower. That's mixed city/highway. This past weekend I drove 1000 miles round trip to Colorado and back, and actually averaged around 15mpg for the whole trip, and that was usually speeding by 5mph and with 80mph speed limit in Utah :D
    Towing varies a ton, I have a UTV and 2500lb 18ft flat bed (4000lbs total) and usually get 11-12mpg. When I tow heavier stuff (cars, my buggy, etc.) it plummets pretty fast to like 8mpg. I got the UTV after the supercharger, but before the supercharger I still got around 8mpg towing heavier stuff and just had to slow down more on hills. No denying I drive fast (the blower helps a lot) so if you're more conservative you'll probably get quite a bit higher mpg.
    All stock besides the supercharger and a 3" lift. Stock gears, stock wheels, etc. Just some ~35"x11" tires.
  10. Jul 7, 2020 at 12:51 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I have the same size Michelin tires, 295/70/18 E rated ties and what I found is it is really dependent on how fast you want to go. IIRC a 295/70/18 tire will be +3.5 mph over what your speedometer says. So 70 mph is really 73.5 mph.
    That being said, I have had to slow down some with the bigger tires and towing - otherwise my mileage just blows. If I have a headwind, and an open 14' trailer (2 atvs, 2 dirt bikes) I will routinely get 11 mpg at 73.5 mph. Add a 20 mph headwind (aka traveling across North Dakota) with smallish hills and I go sub 10 mpg.
    Not towing or just a motorcycle trailer w/295 tires gives me around 12.5-14.0 depending on any hills and speed.
    With the bigger tires and the 14' open trailer and a head wind, there were times the truck never went into 6th gear.
    So now I am contemplating either:
    1. Taking the mileage hit and dealing with it, or;
    2. ReGearing the truck, or;
    3. Moving into a Duramax diesel and spending wayyyy too much money
  11. Jul 7, 2020 at 12:57 PM
    Brlowe
    Brlowe Tundra Owner
    Idaho
    2020 Cavalry Blue Tundra Limited 4x4
    Think of how many gallons of gas you can buy with the extra money you would spend on that Duramax? Better yet calc the difference in MPG and then see how long it will take to break even.
  12. Jul 7, 2020 at 1:07 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Exactly why I don't already have one. I got a smok'in trade in offer on the Tundra and had test drove 3 of them (Chevy/GMC 2018, 2019, 2020). So yah...am doing that mental check. But DaHam.......would be nice to start s duramax build project, or get a new one with the 10 speed Allison. All drool worthy.....but I don't have endless pockets.
  13. Jul 8, 2020 at 8:33 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    That matches about what I get. I got about 8 mpg towing 6600 lbs recently.
    snivilous[QUOTED] likes this.
  14. Jul 10, 2020 at 7:48 AM
    Handbanana
    Handbanana New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    My question is our tundra calls for 49 psi but we dropped it down to 45 psi for comfort will this all affect towing? Does it matter? Nitto ridge grapplers
