Land Cruiser V35A Engine
Discussion in '3rd Gen Tundras (2022+)' started by Jowett, Jul 5, 2021.
  1. Jul 7, 2021 at 6:47 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Conspicuously absent from that helpful under hood diagram was a transmission cooler.
    Wallygator likes this.
  2. Jul 7, 2021 at 6:52 PM
    Wallygator
    Not surprised, especially on the suv
  3. Jul 7, 2021 at 6:54 PM
    Coal Dragger
    Kung Fu Dick
    I am a bit surprised, Australian market customers frequently tow with their LC’s.
    Wallygator and =JSG= like this.
  4. Jul 7, 2021 at 6:55 PM
    Tundra TTH
    Tundra TTH New Member
    Maybe that’s what the electric fan is for in case the trans fluid starts getting too hot. It states “if equipped”. Is it an option for a trailer package?
    ShreveportTSS and Wallygator like this.
  5. Jul 7, 2021 at 7:00 PM
    Coal Dragger
    Kung Fu Dick
    Possible I guess, but there is no drawing of a cooler associated with that fan. It could also be a fan to move air over the condenser for the HVAC.
  6. Jul 7, 2021 at 7:22 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I lucked out before anything major went wrong. Had about 85k miles on it and the SMG gearbox started acting up so sold it quick (traded it in, along with an old Prius, towards a new 535xi around 2013) Was a fun car to drive but yeah they will get expensive to repair.
  7. Jul 7, 2021 at 7:33 PM
    Coal Dragger
    Kung Fu Dick
    Good deal, got to enjoy it while it was still fun and then get rid of it.
    Like dating a stripper.
  8. Jul 7, 2021 at 9:40 PM
    Wallygator
    I'm not given the way Toyota is going. It's obvious they can afford to cut some corners and still maintain a very respectful reliability level.
  9. Jul 7, 2021 at 9:54 PM
    Coal Dragger
    Kung Fu Dick
    I suppose.
    Plus they know what their transmission fluid can withstand for working temps. As synthetic fluids have gotten better and better the need to baby the fluids has lessened over time.
    I will probably still put on a supplemental transmission cooler on my next Tundra should I buy one.
  10. Jul 7, 2021 at 9:58 PM
    Wallygator
    I agree. It's bullshit! Probably why I have a cooler on my 2020. Ridiculous that is not included!! But I'm gonna do what I have to do. Truck was $39K out the door....I can afford some mods
  11. Jul 8, 2021 at 12:22 AM
    Coal Dragger
    Kung Fu Dick
    I think you're right, should have some decent tuning potential without a lot of hardware since the dyno plot you posted shows it is making power beyond 5200 RPM's and that means the turbochargers are not becoming a restriction too early in the rev range.
    For guys that want to change out some parts, those radiators for the air to water intercooler could also be replaced with larger aftermarket units with larger capacity and more importantly more surface area to transfer heat. Assuming the Tundra will use the same set up, the giant grille on the 2022 makes some sense and maybe the air inlets under the headlights are there to force feed those radiators? More capacity to keep charge air cool and resist heat soak is not a bad thing even if you never turn up the boost.
    At the very least a tune, intake(s), and maybe exhaust would be interesting. I suspect like most modern factory vehicles the stock exhaust isn't going to really rob that much power though. I would also be curious if turbo blankets would fit, and if so how much under hood temps could be lowered to keep everything happy while the truck is working hard.
    Hopefully there will be more quality aftermarket support for this engine than the 3UR-FE has. Too bad Toyota probably won't enjoy economies of scale with this engine and cram it in every engine bay that it can fit in and still be serviced. If they would there would be lots of good aftermarket parts for the V35A-FTS. Top of the line Tacoma and 4Runner for example should be able to get the V35A-FTS as an optional engine, they should put it in the next Lexus GX at the very least if they don't allow the 4Runner to have it. Any of the RWD architecture Lexus sedans should get a variant as an optional engine.
    ryanwgregg likes this.
  12. Jul 8, 2021 at 7:45 AM
    Tundra TTH
    Not sure if there is a trans temp gauge on current tundra’s. If not, do we know there is an issue with the trans getting to hot? And, maybe the 2022 radiator has more then enough capacity to keep the trans fluid cooled off.
  13. Jul 8, 2021 at 3:04 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    For fuck’s sake, the truck’s not even being made yet and folks are already complaining about no transmission cooler.
    LS3, snivilous, Larly5000 and 5 others like this.
  14. Jul 8, 2021 at 3:13 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Folks complaining about something new?
    DoMoToyota, =JSG=, Wallygator and 2 others like this.
  15. Jul 8, 2021 at 3:14 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    2 airboxes
    2 air filters
    2 maf sensors
    2 throttle bodies
    2 turbos
    2 intercoolers
    2 map sensors (assuming)
  16. Jul 11, 2021 at 6:06 PM
    Coal Dragger
    Kung Fu Dick
    Some more details on the Land Cruiser 300 and probably Tundra spec V35A-FTS ‘21 Variant:
    https://toyota-club.net/files/faq/19-09-10_faq_df_v6_eng.htm
    Differences between the ‘21 truck/suv version and ‘17 LS500 that I was able to pick up on:
    1.) Cam timing on the ‘21 intake cam is hydraulic instead of electronic as on the ‘17. Probably more simple and less costly to produce. Being hydraulic ‘2022 owners will of course need to stay on top of oil changes, but that’s nothing new for any vehicle with hydraulic cam timing adjustment.
    2.) Cam phasing for the intake cams of the ‘17 is up to 85 degrees where the ‘21 is only 65 degrees. Exhaust cam phasing is identical on both at 44 degrees.
    3.) Oil pan is different on the ‘21 than the 2 versions on the ‘17.
    4.) Wonder of wonders the ‘21 uses a spin on oil filter! Hooray Toyota please make sure the Tundra also gets a spin on.
    5.) Piston oil squirters on the ‘21 are simplified compared to the ‘17.
    6.) The ‘21 uses a single throttle body and a single intercooler on a single piece intake manifold. My guess is the more generous vertical space under the hood of the Land Cruiser vs LS500 allows for a simpler and larger single intercooler to do the job. Plus it’s probably less expensive to produce.
    7.) The ‘21 uses a belt driven clutched cooling fan instead of the electrical fan of the ‘17.
    8.) The ‘21 uses two accessory belts instead of one on the ‘17.
    Probably some things I missed. Enjoy.
  17. Jul 12, 2021 at 11:15 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Did enjoy, thanks. I suppose having experience in the Lexus for a few years Toyota learned some things. They put it in the Land Cruiser so that shows confidence, LC is something they don't want to f up.
    Every Lexus/LC V35A has been built in Japan, I guess the Tundra/Sequoia V35A will be built in the Alabama engine plant, hopefully they have that workforce trained and ready to go.
    sf319 likes this.
  18. Jul 27, 2021 at 6:52 AM
    mass-hole
    mass-hole New Member
    If its anything like the Ecoboost then those are not maf sensors. The Ecoboost is speed density tuned, meaning it relies on the manifold pressure and some volumetric efficiency calculations done within the PCM to calculate the air flow into the motor. It then has factory wideband O2 sensors to run it in closed-loop mode and keep the AFR's exactly where it wants. The sensors by the intakes could just be pressure/temperature sensors.
    Since the engine is a twin turbo V6, I actually really like the dual intakes. It gets rid of some extra tubing and stuff that has to cross over the motor and probably makes it a lot easier to work on.
  19. Jul 27, 2021 at 7:05 AM
    #49
    mass-hole
    If I had to guess, its more like:
    2 air filters
    0 maf sensors
    1 throttle bodies
    2 turbos
    1 intercooler
    1 map sensors
    1 TIP sensor
    The intercooler is probably split up to two exchangers on the LC due to size of the truck. i bet they could use a single unit on the Tundra with that gargantuan grille.
    10TundraSR5 likes this.
  20. Jul 31, 2021 at 9:58 AM
    #50
    Dilleytech
    Dilleytech New Member
    Is there any fuel mileage info out on the land cruiser yet?
  21. Jul 31, 2021 at 11:41 AM
    #51
    Coal Dragger
    Kung Fu Dick
    I’ve looked but didn’t find anything.
  22. Jul 31, 2021 at 11:58 AM
    #52
    Coal Dragger
    Kung Fu Dick
    Had to download a brochure from the Toyota of the United Arab Emirates….
  23. Jul 31, 2021 at 12:02 PM
    #53
    Coal Dragger
    Kung Fu Dick
    So…. 9.3 km/L = 21.87 MPG.
    Since there is only one rating and I have no idea if that is city, highway, mixed driving cycle it’s hard to translate into mileage we can easily quantify by our standards.
    The fuel tank is 110L = 29.05 gallon fuel tank.
    So if we *assume* the fuel consumption listed is per Japanese testing standards which include a mixed driving cycle that combination could yield a range just over 600 miles on a tank of refined dead dinosaurs. Figure a real world range of 500 miles before the fuel light comes on.
  24. Jul 31, 2021 at 12:57 PM
    #54
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Best sounding motor BMW has ever made imo but also one of their biggest POS lol.
  25. Jul 31, 2021 at 1:24 PM
    #55
    Coal Dragger
    Kung Fu Dick
    Best sounding BMW motor? I’ll give that honor to the BMW V12 built for the McClaren F1.
  26. Jul 31, 2021 at 2:13 PM
    #56
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Looks like the V6 layout in my 350Z. Battery is under passenger side cover and brake & clutch fluid on driver side. 6F3348D0-D063-4A50-A6CC-8EC0AE632500.jpg
  27. Jul 31, 2021 at 8:26 PM
    #57
    JuicyJ
    JuicyJ New Member
    Looks like my Q60:
  28. Jul 31, 2021 at 9:19 PM
    #58
    Acedude
    Acedude New Member
    Colorado Plateau
    29g tank is pretty good. If Toyota can get that into a shorter wheelbase, narrower vehicle on the scalable TNGA-F platform that seems to point to a 29g+ base tank for Tundra/Sequoia. I researched the Ford Ecoboosts MPG towing and found it's less than the 5.7l on the same hill, the same trailer, on the same day (TFL Ike Gauntlet). Never owned a Ford TTV6 but I've read enough people say you get either Eco or Boost to think the V35A will be the same. So a larger stock tank will be nice for towing range. Looking at fuelly.com Ecoboost owners are up into the 18-20mpg range consistently.
    TK1979 likes this.
  29. Jul 31, 2021 at 9:32 PM
    #59
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Its good to see some new changes, its inevitable, you have to change or make no money in the car business and its good to see new engine with more power and torque. My only complaint with the new 300 series landcruiser is they took away the split tailgate, that was a unique feature, its only one solid piece that opens upward like most SUVs.
  30. Jul 31, 2021 at 10:04 PM
    #60
    Coal Dragger
    Kung Fu Dick
    Sure if memory serves the EcoBoost was also considerably faster up the hill than the Tundra too. I’ll take power over fuel economy 99% of the time thank you.
    The run with the Ford 3.5L EcoBoost up the Ike: 8:02 seconds, with quote "the ability to accelerate at any time". Also 3.5 MPG.
    https://youtu.be/0zSB2VYCYr0
    The latest Tundra run up the Ike: 8:13 seconds with the pedal buried to the carpet…. and 3.4 MPG.
    https://youtu.be/I8upLk9jlcQ
    Can you say ass whipping? ‘Cause the Tundra 5.7L is getting it’s ass whipped in the mountains. Also beat by the basic bitch 5.3L GM V8 and 10 speed combo on the same day.
    TK1979 likes this.
