Lamin-x
Discussion in 'Lighting' started by frichco228, Feb 26, 2020.
  1. Feb 26, 2020 at 12:42 PM
    frichco228
    frichco228 [OP] Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Typically I have run yellow fog lights. In my 4th gen 4runner, I used the Lamin-x film, stock bulbs. After a few years the film looks like it has burnt from the heat of the fog lights. Burn looking discoloring for sure. Id just replace the film but that adhesive is a mess to try and get off.
    I would like to have yellow fogs on my Tundra, but am now hesitant about the film. Id rather not replace the bulbs, the aftermarket yellow fog bulbs I have seen are super bright, and overpower the headlights...they just dont seem to match well together.
    Anyone use it on a 3rd gen Tundra? Good results or did the film burn? Any other yellow bulb options that match well with the stock halogen headlights?
  2. Feb 26, 2020 at 1:15 PM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Are the fog lights LED on the 4runner? On my '19 Limited the fogs are LED. LED bulbs will generate much less heat, making films like Lamin-X a good option.
  3. Feb 26, 2020 at 1:18 PM
    frichco228
    No, it is a 2006 SR5 4runner- has they halogen fogs and headlights.
  4. Feb 27, 2020 at 6:49 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    I have Lamin-X on mine for several months now and no issues. My fogs are also LED pods as well
  5. Feb 27, 2020 at 6:53 AM
    tlr641
    tlr641 New Member
    Robb
    Oregon
    2018 Tundra Sport
    Trd dual exhaust, bilstein 5100’s, tint
    Have them on mine for 2 years with no problems...
  6. Mar 16, 2020 at 9:50 AM
    bft305
    bft305 New Member
    2016 tundra limited
    Try windex to get off the adhesive. It worked when I removed some old window tint and didn’t want to buy special adhesive remover
  7. Mar 16, 2020 at 12:11 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I had the yellow laminx on my morimoto led fogs for sometime. Removal was quite easy. Heat gun or hair dryer. Heat up a little bit as you peel it off. Super easy. No residue.
