Ladder rack choices
Discussion in 'General Tundra Discussion' started by WrigglingWilly, Jul 24, 2018.
  1. Jul 24, 2018 at 7:38 AM
    WrigglingWilly
    WrigglingWilly [OP] Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
  2. Jul 24, 2018 at 10:11 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I got this rack and these bolts off Amazon. On the part that drops into the bed I welded on a piece of flat stock to extend it far enough to use the bed rail system. Just drilled a couple holes in the flat stock. I also wrapped the crossbar with some pipe insulation and tape( like people do with roll cages ). It works great and cost about 150 total. Goes on and comes off in a few minutes. ED69487E-46E5-4196-8A39-B09386DBD28D.jpgC813125B-1418-4039-96AE-CB40AF1A5185.jpg 1A46327E-60D8-475D-9D78-3AED3F410871.jpg
  3. Jul 24, 2018 at 10:17 AM
    WrigglingWilly
    LineX
  4. Jul 24, 2018 at 10:36 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I liked the idea of the two crossbars being separate so when they’re not on the truck they store up against the wall pretty tight. I usually have a tonneau cover on. It mounts to the bed rail system as well. Everything comes on and off quickly.
    WrigglingWilly[OP] likes this.
  5. Jul 24, 2018 at 10:43 AM
    phnominon
    phnominon New Member
    Rich
    Upstate NY
    Blue 2015 SR5 Crewmax
    @Bprose Do you have any pictures of the flat stock connections for us non-backyard engineer types? I have a buddy who can do it, but a picture is worth a thousand words.
  6. Jul 24, 2018 at 10:46 AM
    WrigglingWilly
    LineX
    I am really torn between these racks. Too be track mounted, or not to be...I will rarely remove mine once it is on the truck(the racks also make great hammock mounts) so reliability over ability to remove easily is more practical for my needs . I dont know whether to go for the better looks but less easy to use, or full on utility, but ugly since I do intend to work this truck to death. I have not installed the deck rail system yet either, so not in the way of the heavy duty rack yet.
  7. Jul 24, 2018 at 11:33 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    No. But it was just a piece of 1/8” x 2” flat bar. If I remember when I get home I’ll try to get a pic. Maybe....it’s gonna be 117 today by the time I get home. Might not want to spend any time outside.
    Very simple though
  8. Jul 24, 2018 at 11:51 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    pretty slick, if the bracket was modified some more, could it work with a tonneau cover.
  9. Jul 24, 2018 at 12:19 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I imagine so. I’ve thought about it. I think the edge of the tonneau would hit. You’d have to get a little creative with the piece you attach.
  10. Jul 24, 2018 at 1:43 PM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    Yea, I figured you would have to cut a notch out of the foam on the cover. I guess the trick would be if there was enough room on the bed rails for the post to still be on the rails, but not contact the cover.
