Ko2 275/65/20 PSI
Discussion in 'Wheels & Tires' started by Big Green Thing, Jul 19, 2018.
  1. Jul 19, 2018 at 2:56 PM
    Big Green Thing
    Big Green Thing [OP] My cause is to have no cause.
    Dallas, TX
    '17 Limited White 4x4
    DAP Tune. 1.5" level on front. Revolver X2 Roll Back. Firestone 2445 air bags. TRD sway bar.
    what PSI do you guys recommend? Looking for ride quality. Tire shop filled to 41psi. Would 35 be okay for a little smoother ride?
  2. Jul 19, 2018 at 3:01 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Yeah, 35 should be okay. Just be sure to check your tires for uneven wear and/or cupping and add more air if necessary.
    Big Green Thing [OP] likes this.
  3. Jul 19, 2018 at 3:09 PM
    hogpiolet
    hogpiolet New Member
    Jimmie
    2018 tundra Platnium
    none
    mine run between 33 and 38 and they are fine
  4. Jul 19, 2018 at 3:31 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I never go with the flow ! I run 30/33 on my KO2's..lol
  5. Jul 19, 2018 at 4:39 PM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    I have BFG KO2 285x55x20 I run 46 front and rear
  6. Jul 19, 2018 at 4:40 PM
    Sas
    OKC, OK
    I've got the exact same and run 39-40 on all 4. When I bought it, it had 50 in it and felt like I was driving around a bounce house.
  7. Jul 19, 2018 at 4:48 PM
    ARES
    God Bless America
    Im thinking of dropping the pressure down to around 40. But with the 6112/5160 suspension truck rides pretty smooth
  8. Jul 19, 2018 at 6:24 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    That is what I run and i believe it is what door sticker shows.
    ARES likes this.
  9. Jul 19, 2018 at 6:47 PM
    Sas
    OKC, OK
    Had to break out the ol' manual and reset my TPMS when I did it. I like the ride much better at 39/40 than at 50/51. But I don't have any sort of lift... yet.
  10. Jul 20, 2018 at 12:42 PM
    Big Green Thing
    Dallas, TX
    Thanks for all the input. I put them all at 38 and the ride is as good if not better than the stock highway tires that came on the truck.
