Knock sensors...
Discussion in '1st Gen Tundras (2000-2006)' started by Bjamin, Aug 1, 2017.
  1. Aug 1, 2017 at 12:26 PM
    Bjamin
    Bjamin [OP] New Member
    Benjamin
    05 Tundra 4.7 SR5
    My check engine light came on. Code suggested knock sensor. I changed the timing belt,water pump and tensioner. New Serpentine belt up front all at 100,000 miles. This seemed to make it happy for the last 13,000 miles . Now check engine light is coming back on same code . I learned there are two knock sensors under the manifold. Each time disconnecting the battery for just a second resets it, and it seems to be happy for a couple of weeks and then it does it again. Knock sensors are around $200 a piece. Labor to install is a killer. Is anyone else having these issues?
  2. Aug 1, 2017 at 2:46 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    huh. Code says knock sensor, so naturally you changed timing belt,water pump and tensioner. Must be a story around that :)
  3. Aug 1, 2017 at 2:49 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    T-Rex266 likes this.
  4. Aug 1, 2017 at 6:54 PM
    Bjamin
    Benjamin
    05 Tundra 4.7 SR5
  5. Aug 1, 2017 at 7:04 PM
    Bjamin
    Benjamin
    05 Tundra 4.7 SR5
    The time had come to change the timing belt. I was hoping that the timing belt stretched out just enough to cause a vibration. It actually did Stretch out a little compared to the new one. Timing belt, water pump and tensioner, all came in the kit. Shot in the dark. Just me being a little stubborn. Had this Tundra 11 years.Other than normal maintenance not a dime out of my pocket. Looks like I won't be saying that much longer...
    NewImprovedRon likes this.
  6. Aug 1, 2017 at 7:06 PM
    Bjamin
    Benjamin
    05 Tundra 4.7 SR5
  7. Aug 1, 2017 at 7:06 PM
    Bjamin
    Benjamin
    05 Tundra 4.7 SR5
    Thank you sir. I'll check it out.
  8. Aug 1, 2017 at 7:22 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Ah ok. that makes some sense :) Either way, let us know how it goes.
