KING 3.0 coilovers
Discussion in 'Suspension' started by TheBeast, Oct 3, 2017.
  1. Apr 18, 2018 at 6:18 PM
    #271
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I think it varies from truck to truck. SDHQ mentioned that they have to cut the tie rods on like every 2 or 3 out of 10.
  2. Apr 18, 2018 at 6:25 PM
    #272
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Personally, I think it has a lot to do with the Camburg arms and the amount of caster they require. They were heim joint arms and I think they needed some more adjustment?
  3. Apr 18, 2018 at 6:31 PM
    #273
    TheBeast [OP] The Beach
    guys...it's only :spending::spending:
    831Tun and GodlessPro like this.
  4. Apr 18, 2018 at 6:32 PM
    #274
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Did you have to?
    That’d make sense. I’ll be getting UCA’s at some point, and the alignment/caster issues have turned me off in regards to Camburg.
    dcsleeper408 and 831Tun[QUOTED] like this.
  5. Apr 18, 2018 at 6:32 PM
    #275
    TC ;)
  6. Apr 18, 2018 at 6:33 PM
    #276
    zcarpenter92
    Zach
    NE Colorado
    In sig
    That’s what I’m thinking!
  7. Apr 18, 2018 at 7:06 PM
    #277
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Don't get me wrong, Camburg is great stuff. But I've run their UCAs (bj) and Icon's. For what I want I'm going with MCM. Like @TheBeast said, It only :spending:
  8. Apr 18, 2018 at 7:07 PM
    #278
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Nope, I have TC so that makes sense
  9. Apr 18, 2018 at 7:51 PM
    #279
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Aren’t caster numbers similar between the MCM and TC control arms? I seem to remember @dcsleeper408’s being around 4*.
  10. Apr 18, 2018 at 8:10 PM
    #280
    both are very similar. even MCM shackles and TC shackles are similar.
  11. Apr 18, 2018 at 8:23 PM
    #281
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    This has been a pretty big issue for me so I've done a lot of investigation. Mark's (@dcsleeper408 ) caster is about 4.5* if I remember correctly. There's a bend in the TC Uca in the rear portion of the arm. because of that slight bend I don't believe you can get much more than 3*. MCM are straight, Camburg is angled back, Icon has more bend than TC.....etc.
    So, what's wrong with 3*? Nothing that I know of. At 2.3* I don't like the way the truck feels, it felt great with Camburg at 6* but I think that's a little too much. This is all my personal preference in terms of caster and how I like my truck to feel. I expect other people will prefer different settings. :notsure:
  12. Apr 18, 2018 at 8:26 PM
    #282
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    @zcarpenter92 i forgot my last alignment #’s (4.5 driver/4.9 passenger I believe)but I was having issues bringing the caster to match. Got em close as possible. Some camber was sacrificed. Toe was cool.
    I think this issue is coming from the driver lean after bumping the rxt packs to 3rd setting.
    Before that I was pulling 4-6* every time. I ran 6* ever since I got the mcm uca. Dropped it down bc I was getting some issues with my rack. Possibly just my intermediate shaft making noise again.
    831Tun likes this.
  13. Apr 18, 2018 at 8:32 PM
    #283
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I'll keep this in mind when I order UCA's. Granted I haven't done any wheeling with the Tundra yet, and when I do it won't be high speed stuff since we don't have deserts here in CO.
    831Tun[QUOTED] and dcsleeper408 like this.
  14. Apr 18, 2018 at 8:33 PM
    #284
    I'm at slightly above 3.5 on each side with TC
    831Tun and zcarpenter92 like this.
  15. Apr 18, 2018 at 8:39 PM
    #285
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Not many deserts here in NorCal either:D.
    ---" much more than 3*." :thumbsup:
    3.5* is a whole lot better than 2.3.
    dcsleeper408 likes this.
  16. Apr 18, 2018 at 8:43 PM
    #286
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Haha well you guys still have Death Valley in the same state as you though, I'd assume thats a "go fast" type trip
    On stock arms I'm sitting at 2.4 and 2.6*. Sounds like a significant improvement to me!
  17. Apr 18, 2018 at 8:45 PM
    #287
    Vizsla
    Vizsla 2 = 2.5
    Here are numbers from my 2016 with TC at 3” lift for reference. Expect around 4+ degrees caster at 2.5” lift. My cams where almost neutral as well, no struggles.
  18. Apr 18, 2018 at 9:22 PM
    #288
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    we have some good desserts.
    TheBeast[OP] and 831Tun[QUOTED] like this.
  19. Apr 18, 2018 at 9:24 PM
    #289
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    NorCal or SoCal? I've never been to clear on where that dividing line is.:notsure:
    dcsleeper408[QUOTED] likes this.
  20. Apr 18, 2018 at 9:53 PM
    #290
  21. Apr 19, 2018 at 7:30 PM
    #291
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    FWIW we don't have alignment issues with our Icon 3.0 and Icon billet adjustable uppers. And we're running 37" tires on a 2" lift.
    We prefer about 3.5* caster because it self centers on the road nicely, but also doesn't have so much caster that rock crawling becomes cumbersome. As you get into the 5-6* caster realm, the amount of off-centerness between the contact patch and steering axis can become an issue in tight rock gardens and add stress to the rack as it tries to lift the truck and turn the wheel at the same time. Imagine the face of the tire against a rock and partway up it, and as you turn one way or another without rolling forward or backward, the steering rack is effectively lifting the front of the truck.
    TheBeast[OP] and 831Tun like this.
  22. Apr 27, 2018 at 9:24 AM
    #292
    JH6124
    JH6124 New Member
    California
    2011 Toyota Tundra Rock Warrior
    King 3.0 coilovers in front King 3.0 3 tube bypasses in rear Camburg UCAs 35” General x3 Grabbers Painted head light Mod Method 17” double standards Smoked tail lights and 3rd brake light. KC Hilite A pillar cube LED lights. Pedal commander
    GodlessPro likes this.
  23. Apr 27, 2018 at 9:59 AM
    #293
    JH6124
    JH6124 New Member
    California
    20097D2A-4E29-4E63-9A60-4938F0CF8B7F.jpg Here she is as she sits currently
  24. Apr 30, 2018 at 9:51 AM
    #294
    n2deep
    n2deep Pavement Princess
    And how did the rack like those settings?
    M C M and Bannock452 like this.
  25. Apr 30, 2018 at 9:52 AM
    #295
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Lol too soon
  26. Apr 30, 2018 at 10:30 PM
    #296
    very nice
  27. May 3, 2018 at 4:11 PM
    #297
    KevinK
    Tundras to Sedona
    :anonymous:
  28. May 3, 2018 at 4:16 PM
    #298
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Was there an issue running those #’s?
  29. May 3, 2018 at 4:36 PM
    #299
    KevinK
    Tundras to Sedona
    I think they’re referencing our broken steering rack. Which I’m not sure is related to alignment numbers as much as general use and abuse.
    Ironically though, our alignment last week, right before the blown rack, was in the 4.5 to 4.9 caster range. I had planned to go back and have it decreased after the trip. But instead I did this and need a whole new alignment anyway.
  30. May 3, 2018 at 6:27 PM
    #300
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    No problems with my ADS 3.0's. Set up works great:thumbsup:
