King 2.5 problems
Discussion in '1st Gen Tundras (2000-2006)' started by Wmitch352, Dec 14, 2022.
  1. Dec 14, 2022 at 11:07 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    x2
    "-Did the poor ride quality change after you added tires or after you added more preload/lift? What tire rating do you have? This will definitely cause the ride quality you described."
    alb1k[QUOTED] likes this.
  2. Dec 14, 2022 at 11:14 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I bet ya those new Grapplers are Load E tires too...Those are gonna be way stiffer than the Load D or Load C tires
    AccuTune Offroad likes this.
  3. Dec 14, 2022 at 11:21 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    What tire pressure you running. This place a huge factor on feel. Do not add a spacer to the coilovers.
  4. Dec 14, 2022 at 11:59 AM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Also, just something to think about, those wheel spacers are going to increase rubbing on the pinch weld because the change in scrub radius. Lift height will only help fit "larger" tires for daily driving, as soon as the suspension articulates and compress there still might be rubbing. I think the happy medium is .75" to help limit frame rub and rubbing on the pinch weld.
    As mentioned above, the tires could be the reason for poor ride quality and not the coilovers.
    shifty` likes this.
  5. Dec 14, 2022 at 12:01 PM
    AccuTune Offroad
    El Cajon, CA
    Don't think wheel spacers have been mentioned
  6. Dec 14, 2022 at 12:03 PM
    805Tundra
    Ben
    Central Coast
    The first photo OP posted looks like he has some wheel spacers on, I just assumed them still might be on the vehicle. could be wrong but thought it was worth mentioning especially if that is his motive to crank the coilovers up more.
  7. Dec 14, 2022 at 12:07 PM
    805Tundra
    Ben
    Central Coast
    love this graphic, look forward to the article. you guys post a ton of useful suspension information.
  8. Dec 14, 2022 at 1:36 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    To add, I was running the 275/70’s prior to the spacers and only rubbed on the mud flaps / guards ( in everyday driving).
    It does appear you’re running spacers, maybe that’s causing you to need addition lift??
    (My main computer is down or I would provide a pick of my setup)
    shifty`[QUOTED] likes this.
  9. Dec 14, 2022 at 6:23 PM
    Wmitch352
    Wmitch352 [OP] New Member
    @abcinv @805Tundra @AccuTune Offroad @reywcms @shifty` @des2mtn
    First off let me say thank you to you guys for your responses here. Never doubt a bunch of guys that get obsessed about some stuff like this.
    The collar was turned down on the COA about a week before the new tires. The new tires definitely exacerbated the decreased ride quality but the decrease was noticeable on stock tires.The tires are 285/70/17 load E ridge grappler at 34lbs. my "droop" or down travel is 4". Friday i'll be able to get in there and get some better measurements. As far as wheel spacers, yes I am using Spidertrax 1.25" spacers.
