Kinetic Recovery Strap VS Kinetic Recovery Rope
Discussion in 'Recovery & Gear' started by plumber802, Dec 18, 2019.
  1. Dec 18, 2019 at 9:05 AM
    plumber802
    plumber802 [OP] New Member
    Andy
    Vermont
    2018 White Platinum CM
  2. Dec 18, 2019 at 9:16 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Those look like snatch straps and are good to yank someone out but not to pull someone for a long time.
    15whtrd and Joss1799 like this.
  3. Dec 18, 2019 at 10:13 AM
    plumber802
    Andy
    Vermont
    That's right. I'm not looking for a tow rope. Recovery only.
  4. Dec 18, 2019 at 10:26 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I had the ARB. Would get again. I don't think there's anything different from a rope to a strap besides profile. An extra $50 seems like a lot for a smittybilt than an ARB that does the same thing.
  5. Dec 18, 2019 at 10:46 AM
    plumber802
    Andy
    Vermont
    Thanks. That's what I was wondering.
  6. Dec 18, 2019 at 10:53 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I wouldn't get the ARB for snow recovery. It's a good strap but not very waterproof and is going to soak up water and mud.
    831Tun, DjSamthrax and Vizsla like this.
  7. Dec 18, 2019 at 11:08 AM
    plumber802
    Andy
    Vermont
    I spent some time doing research on both styles and don't remember being waterproof as a major selling point. I'm not challenging you just trying to understand. Don't they all soak up water and mud due to the fact that they are multi stranded by design?
    831Tun likes this.
  8. Dec 18, 2019 at 11:19 AM
    Vizsla
    Vizsla 2 = 2.5
    I have the Smittybuilt, good stuff. It has a higher rating, stretches further 30% vs 20%, and waterproof. Definitely harder to stow due to size.
    831Tun and joonbug like this.
  9. Dec 18, 2019 at 11:27 AM
    plumber802
    Andy
    Vermont
    Thanks Dave. I don't mind spending the extra for the rope over the strap if there is a clear advantage. In my case it would only see occasional use since my truck is a pavement pounder. Will the extra 10% of stretch from the Smittybuilt have a clear advantage during a recovery?
    Vizsla[QUOTED] likes this.
  10. Dec 18, 2019 at 11:32 AM
    snivilous
    SW UT
    None of the straps I've ever owned were "waterproof". They all soaked up water and mud. I never worried about that, but if that's an issue then just hand wash it. Probably 90% of the recoveries I've done were in the snow and slush. The ARB I had never showed any signs of degradation and I never once washed it and had it for years in lots of different circumstance. One dumb shit hooked it up wrong once and tore a hole in it, otherwise I'd still have it and still have never washed it unless it was absolutely caked between the fibers.
    Have you had straps fail from water intrusion? Just curious since I've never heard or seen a need for a "waterproof" strap.
  11. Dec 18, 2019 at 11:46 AM
    plumber802
    Andy
    Vermont
    Is the 30% vs 20% difference in stretch worth the extra $43 for the Smittybuilt?
  12. Dec 18, 2019 at 11:47 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No, I'm not worried about it failing from water intrusion. I've never actually got my ARB wet. Just saying that the material is very fabric like, flat and wide, and I know it'll absorb alot of water and mud. It'll probably get very heavy and definitely look like shit once mud gets on it. Most kinetic ropes I've seen seem to be more nylon material like and tightly braided or they're coated with something and just look like they'll do much better with water resistance in snow and mud.
    Vizsla likes this.
  13. Dec 18, 2019 at 12:07 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Vizsla and plumber802[OP] like this.
  14. Dec 18, 2019 at 12:12 PM
    plumber802
    Andy
    Vermont
  15. Dec 18, 2019 at 12:15 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You see Alex's 1,000,000 lb. anaconda rope? That thing is like 3" in diameter. :laugh:
    831Tun and Vizsla[QUOTED] like this.
  16. Dec 18, 2019 at 12:16 PM
    plumber802
    Andy
    Vermont
    Size matters!
    Vizsla and joonbug[QUOTED] like this.
  17. Dec 18, 2019 at 12:59 PM
    Vizsla
    Vizsla 2 = 2.5
    I have no idea where he puts everything, think that “microwave” might actually be some magic portal to his garage.
    It is definitely worth it to me, sure strap is fine, but the ropes are better aside from the added bulk. If your buying from Amazon put it in the cart and leave it for awhile, got mine for $107 that way.
    831Tun, 14burrito and joonbug[QUOTED] like this.
  18. Dec 18, 2019 at 1:27 PM
    plumber802
    Andy
    Vermont
    Thanks Dave.
  19. Dec 18, 2019 at 1:30 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    joonbug likes this.
  20. Dec 18, 2019 at 2:04 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    No, they won't all soak up water. Amsteel, commonly used as a winch line, (AKA Dyneema or Cuban Fiber) is hydrophobic. Aramid, commonly known as Kevlar, will soak up water. Just depends on what fibers are used.
    Vizsla and joonbug like this.
  21. Dec 18, 2019 at 2:18 PM
    Vizsla
    Vizsla 2 = 2.5
    Nothing wrong with the Smittybuilt Oliver, way better quality than expected. I don’t consider VooDoo because the ratings seem a bit off. Every 3/4” rope I know of is rated for 19,000 lbs, not enough for our trucks pulling other full size trucks. The VooDoo 3/4” is rated 5,500 lbs more at 24,500, :notsure:which is still too low imo..
    joonbug and 831Tun like this.
  22. Dec 18, 2019 at 2:26 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Looks like all the snatch ropes that I've researched including Smitty, Voo Doo, Billet, Bubba are made from Nylon which is hydrophobic. Not that anyone cares. :notsure:
    At some point I'd like to pick up a 1" Billet 4x4 rope.
    joonbug likes this.
  23. Dec 18, 2019 at 2:36 PM
    15whtrd
    15whtrd Mr. Blonde
    I carry a 30’ kinetic rope
    BILLET4X4 (Full-Size Truck) U.S. Made 1-1/8 inch X 30 ft Safety Orange Kinetic Energy Recovery Rope - Snatch Rope with Heavy-Duty Carry Bag https://www.amazon.com/dp/B07JPXYWDM/ref=cm_sw_r_cp_api_i_9LQ-Db7DP85FB
    as well as a tow strap.
    motormic Tow Strap Recovery Kit - 30 ft x 3" (30,000 lbs.) Rope + 2" Shackle Hitch Receiver + 5/8" Locking Pin + 3/4" D Ring Shackles + Heavy Duty Bag https://www.amazon.com/dp/B072V51TRC/ref=cm_sw_r_cp_apip_FYOGriqIL3ZTZ
    That way I have options.
    WVI, joonbug, 831Tun and 1 other person like this.
  24. Dec 18, 2019 at 2:46 PM
    plumber802
    Andy
    Vermont
    Vizsla and 831Tun like this.
  25. Dec 18, 2019 at 3:04 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    So, if it's too big you run the risk of not utilizing the stretch. But, if you're truck is buried to the axle it's gonna take a lot more to pull it and require a larger rope. My neighbor was telling me about a site where there's a ton of info and numbers on this stuff. Need to ask him for a link. BRB
  26. Dec 18, 2019 at 3:29 PM
    Vizsla
    Vizsla 2 = 2.5
    It’s actually 1”, measures 1 1/16” thick. Imo 30,000 lb rating should be starting point for full size trucks. A full size HD pickup truck with some tools etc. in it can hit 9k lbs x 3 = 27,000 pounds.
  27. Dec 18, 2019 at 3:48 PM
    plumber802
    Andy
    Vermont
    The Billet (Made in the USA) 1" X 30' rope is only a couple of bucks more than the Smittybuilt but almost $19 for shipping though.
    831Tun and Vizsla like this.
  28. Dec 18, 2019 at 4:39 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Shittybilt wasn't aimed directly at the strap, just an auto correct within my phone lol and i did in fact overlook ratings :/
    831Tun likes this.
  29. Dec 18, 2019 at 4:42 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    145 for a 38k rated voodoo
  30. Dec 18, 2019 at 4:43 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The price for buying American made? :oldglory:
    I haven't had a chance to check out this info yet. Neighbor just mentioned it yesterday and sounded interesting.
    https://discoveroffroading.com/about-bob-wohlers
    TundraDude18 and 14burrito like this.
