Killer Chiller alternatives?
Discussion in 'Performance and Tuning' started by Saltyhero13, Jul 24, 2022.
  1. Jul 24, 2022 at 12:34 PM
    Saltyhero13
    Saltyhero13 [OP] Throbbing Member
    Anyone know of another similar product?
  2. Jul 24, 2022 at 1:27 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’ve seen a brand called inter chiller mentioned before. I’ve also seen it said that the tundras cycle the AC compressor off during WOT so it’s not doing much in that scenario. Don’t know if that’s true though.
    Saltyhero13[OP] likes this.
  3. Jul 24, 2022 at 1:51 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Nitrous :cool:
    Saltyhero13[OP] and Vizsla like this.
  4. Jul 24, 2022 at 2:07 PM
    Vizsla
    Vizsla 2 = 2.5
    Lol. I ghetto sprayed the intercooler(scared to hit the intake) on one of my 6.0 Powerstrokes during a dyno pull, helped little bit. Never seen anyone spray an air to liquid cooler though.
  5. Jul 24, 2022 at 2:11 PM
    snivilous
    SW UT
    I meant spray into the intake, then you get the full effect of massive cooling and more oxygen, but your method would work too :D
    Saltyhero13[OP] and Silver17 like this.
  6. Jul 24, 2022 at 2:18 PM
    Silver17
    Eastern PA
    I’m curious how much lower the IATs would be if we lowered the percentage of glycol in the intercooler loop from 50% to 30 or 40%. Just have to make sure there is adequate freeze protection. It would also lower the IC pump amperage a little.
  7. Jul 24, 2022 at 2:19 PM
    snivilous
    SW UT
    Run straight water in that bitch and see if it makes a difference.
    4firemandan and Silver17[QUOTED] like this.
  8. Jul 24, 2022 at 2:22 PM
    Silver17
    Eastern PA
    I guess that would answer more quickly if it is at all worth the effort of mixing to a lower percentage lol.
  9. Jul 25, 2022 at 6:27 AM
    Saltyhero13
    Thank you.
    It doesn't look like they support Tundra (or Toyotas for that matter).
    Regarding WOT I read the same thing but I haven't seen it confirmed. Easy enough to test. <smashes pedal> "Is it getting warmer in here?"
    Silver17[QUOTED] likes this.
  10. Jul 25, 2022 at 6:36 AM
    Silver17
    Eastern PA
    @ViktorG don’t you have a killer chiller on your truck?
  11. Jul 25, 2022 at 6:48 AM
    Saltyhero13
  12. Jul 25, 2022 at 5:40 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
  13. Jul 25, 2022 at 11:24 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I was also thinking this.
  14. Jul 26, 2022 at 6:29 AM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    I had the KC on a blown Silverado I had. Went through 2 compressors in 2 years and only drove it about 3k miles per year.
  15. Jul 26, 2022 at 8:20 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Just a thought, wouldn't be easier if a small metal box is build that clamps onto the IC hose? so we can just add ice to it at the track?
  16. Jul 26, 2022 at 1:54 PM
    Bluecobra
    2014 Tundra
    Yeah I had a 1.5 gallon tank on my Magnacharger on my Silverado. The thing was you had to siphon out a portion of the water/glycol mix before you added the ice, then you had to hurry up and wait to stage at the line before the ice melted. It never worked out well for me. The 40 gallon cooler in the bed was a better way to do it really. Leave about 10 gallons of water in it, throw 2 bags of ice in it, get in line and it was cold for several runs. Of course then you may need more pump, etc....
  17. Jul 26, 2022 at 1:58 PM
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    In regards to a lower percentage glycol, I've seen a few different studies where straight water out performed everything else
    I guess the only reason we even use the additives is to prevent freezing. performance wise water is were it's at.
    I have also heard of "water wetter" being used with straight water, but I don't know anything about it personally.
  18. Aug 15, 2022 at 6:25 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Throw a frozenboost.com heat exchanger on in conjunction with the OE heat exchanger...fairly inexpensive...I haven't read any poor things about it...
    reywcms, Saltyhero13[OP] and Vizsla like this.
  19. Aug 16, 2022 at 11:52 AM
    Downytide
    GTA
    HulkSmurf14[QUOTED] likes this.
  20. Aug 16, 2022 at 11:59 AM
    HulkSmurf14
    2014 Tundra Limited
  21. Aug 16, 2022 at 12:33 PM
    Downytide
    GTA
  22. Aug 16, 2022 at 1:21 PM
    Saltyhero13
    Don't under estimate the benefits of spraying the intercooler. I inadvertently did this by running through a touchless car wash, temps plummeted significantly. While in the tunnel they dropped well below ambient and took a while to jump back up once on the highway.
    HulkSmurf14 likes this.
  23. Aug 16, 2022 at 1:27 PM
    Saltyhero13
    May be able to mount them one below the other parallel to the ground, looks like the 101 has mounting points below and above. Space is tight.
  24. Nov 21, 2022 at 3:13 AM
    So1988
    So1988 New Member
    I paid 885 for a kit, but they are irresponsive.
    They don't pickup calls, ignoring my emails too.
    5 weeks now with no luck. Any suggestions? I just need a refund!
