Kicker HS10 Install (and T-Harness)
Discussion in '3rd Gen Tundras (2022+)' started by bearsman34, Dec 28, 2022.
  1. Dec 28, 2022 at 11:05 AM
    bearsman34
    bearsman34 [OP] New Member
    2022 Tundra TRD Off Road 4x4
    Nothing yet!!
    Ok guys... I looked everywhere, and nobody had information. So I went looking on my own. Between looking at the wiring diagram, the connector list, and a quick look at Taco Toonz add a subwoofer harness, I think I figured everything out. Holy smokes, I hate electrical everything. I'm a mechanical engineer, so I dabble in electrical, but it is definitely not my forte. All that being said, attached is what I have figured out, but I need some help locating parts.
    There is a 10-pin harness (part # 12C39) that houses all of the speaker wires from the head unit. Based on the wiring diagram for the 2022 Tundra, the speaker wires (+/-) can be identified. (Speaker harness is under the large brown and black connectors)
    This is the top of the harness. Picture is for wire identification.
    Picture below is bottom of harness (again for wire identification)
    PDF below shows the wiring for speakers and my markup on the connector itself. Does anyone know where I can get the male and female equivalent of the 12C39 connector? I want to build a t-harness to prevent the need to cut factory wiring. It looks like Mr. T Toonz only pulls audio from right rear meaning it would be a mono setup, but the Kicker HS10 has a stereo input. Additionally, I want to connect it to the front speakers since I have heard they have a fuller sound output vs. the rears. Can anyone check my work and make sure I am not on the wrong path? And any help finding these connectors would be amazing!!!
    TundraWorkHorse likes this.
  2. Dec 28, 2022 at 11:19 AM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
  3. Dec 28, 2022 at 11:54 AM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    If it is just for a woofer, you should only need to grab the signal from the two rear woofers in the doors. I agree, using only the right side will not work right for a setup like this (it'd work, but any song that actually makes use of stereo recording will sound weird). You won't need a full range signal for the input, since it will just get filtered out by the amps crossover anyway, so the rear door woofers should be perfect.
    Skidmarcx and bearsman34[OP] like this.
  4. Dec 28, 2022 at 1:27 PM
    2017TundraNC
    2017TundraNC New Member
    North Carolina
    2022 Tundra 1794 4x4 6.5'
    Is this for systems WITH JBL Audio or WITHOUT? I may have some info for you if it is WITH JBL.
  5. Dec 28, 2022 at 4:49 PM
    bearsman34
    Nothing yet!!
    It is without JBL. And thanks for the info on the rear vs fronts. Anyone have any idea on a source for the male and female plugs to build a t harness?
  6. Dec 28, 2022 at 6:28 PM
    Jaxb103
    Jaxb103 New Member
    2023 Tundra TRD Sport
    Hope you get it figured out. I’d love to add a sun to mine.
    bearsman34[OP] likes this.
  7. Dec 28, 2022 at 7:13 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
  8. Dec 28, 2022 at 8:09 PM
    bearsman34
    Nothing yet!!
  9. Mar 4, 2023 at 4:43 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    Did anyone figure this out yet?
    I’m the duct tape will fix everything type of guy, and was thinking . Couldn’t you use the harness from Mr. T. Tunes and splice directly on that? This would take the guesswork out of finding the correct connectors and as a bonus it’s already pre wired for you.
    I bought the alpine pwe-s8 sub and was planned on connecting it this way.
  10. Mar 4, 2023 at 5:19 AM
    Jaxb103
    Jaxb103 New Member
    Yeah the T Tunes harness works fine. That’s what I used. Plug and play
  11. Mar 4, 2023 at 5:27 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    Did you use the harness as is and have the sub setup in mono, or did you tap into it to get a right and left signal?
  12. Mar 4, 2023 at 5:32 AM
    Jaxb103
    Jaxb103 New Member
    With the kicker it is used as is. Don’t need the remote turn on. Power, ground then just connect the speaker wire. Should be the same with any powered sub
    Soflo likes this.
  13. Mar 5, 2023 at 12:07 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    I’m intrigued… does this harness provide power ground remote and signal. Or is this harness simple for signal?
  14. Apr 2, 2023 at 7:11 PM
    Pleiades97
    Pleiades97 New Member
    Brandon
    2023 Tundra TSS
    Black widow TRD likes this.
  15. Apr 2, 2023 at 9:40 PM
    Black widow TRD
    Manuel
  16. Apr 3, 2023 at 10:25 AM
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    I used the tunes harness for my unit. Works great for me
  17. Sep 13, 2023 at 8:50 AM
    a1dookie
    a1dookie New Member
    which harness did you get, ad did you use their output converter of another?
  18. Oct 15, 2023 at 7:58 PM
    Goobax
    Goobax New Member
    Sorry to bump this but any luck on someone making a complete jumper harness to pull all wires to feed something like an audio control LC7i for a 5 channel set up? I see the Amazon one above and don’t mind trying that but wonder if anything pre-wired.
  19. Oct 20, 2023 at 9:03 AM
    a1dookie
    a1dookie New Member
    I just ordered the individual harnesses, will start soon.
  20. Oct 20, 2023 at 9:04 PM
    Goobax
    Goobax New Member
    from TT? I was looking at their remote turn on/ power harness but wondering if I can just find my own connector/harness separately. Wanting to basically build something similar to LLJ elite harness system on my own
  21. Oct 21, 2023 at 6:55 AM
    a1dookie
    a1dookie New Member
    No didn’t get the TT, I’m in Canada and they never responded to my email.
  22. Oct 21, 2023 at 8:04 AM
    Goobax
    Goobax New Member
    where did you find the 28pin harness? Do you mind sending the link? Thanks
  23. Oct 21, 2023 at 1:41 PM
    a1dookie
    a1dookie New Member
    https://www.autoharnesshouse.com/
    saw it mentioned on here somewhere, sent a message and they were helpful choosing the right ones I need. A bit on the pricy side but a few people on here swears the quality is way better.
