Key out of ignition won't shut off
Discussion in '2nd Gen Tundras (2007-2013)' started by Chazkini, Dec 12, 2016.
  1. Dec 12, 2016 at 12:24 PM
    Chazkini
    Chazkini [OP] New Member
    Blue tundra
    How's it i came to my truck and the battery was drained but when I went to jump it all my dash lights came on, which was weird. All the switches were off in my truck: I jumped it and started right up, it was fine. Until I went to turn it off! It was still runnin with the key out of the ignition! About 15 seconds later it shut off and the dash lights were still on! Any ideas?
  2. Dec 12, 2016 at 12:25 PM
    15whtrd
    15whtrd Mr. Blonde
    I think I'd start looking at the ignition switch.
  3. Dec 12, 2016 at 12:30 PM
    15whtrd
    15whtrd Mr. Blonde
    See if when you jiggle the ignition switch if the lights will turn off on the dash.
  4. Dec 12, 2016 at 4:02 PM
    davesnothere
    davesnothere New Member
    Dave
    Down South, Texas
    2016 Tundra Limited 4x4 5.7ffv
    Pro Comp stage 2 6" lift- 20" XD Rockstars- 35" pro comp a/t sport- Hypertech Interceptor- 7" BA Muffler- 4.88 Yukon gears
    Sounds like you got hacked by the Russians
    Chazkini[OP], gosolo and Achuop like this.
  5. Dec 12, 2016 at 4:09 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    Do you have a remote start??
  6. Dec 12, 2016 at 6:27 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yea I would suspect something here. Might need to get someone to look at it. Dealer maybe.
  7. Dec 12, 2016 at 7:00 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Brian is right, take it to dealer and let them sort it out. Not good brother...
  8. Dec 12, 2016 at 11:28 PM
    Chazkini
    Blue tundra
    No remote start bro it's all stock.
  9. Dec 12, 2016 at 11:33 PM
    Chazkini
    Blue tundra
    Ya I still have warranty so I'm stoked on dat. But I wouldn't want to get but fucked by them if I could do it my self hahah but hopefully they can get it diagnosed and then maybe go from there.
  10. Dec 12, 2016 at 11:35 PM
    Chazkini
    Blue tundra
    I pulled fuses and it went back to normal which was sick but If it happens again I'll try your method. Is there a sensor in the ignition?
