Key Fob Replacement 2002 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Peterv, Oct 29, 2019.
  1. Aug 25, 2021 at 1:26 PM
    #181
    daveeasa
    David
    Pretty sure I bought the key you have? It’s not compatible with my truck.
    EDIT: maybe not, I guess I don’t know what your truck needs.
  2. Aug 25, 2021 at 3:17 PM
    #182
    toyoboyo
    toyoboyo New Member
    I have an 05 Sequoia. After cross referencing the numbers it appears that your key won't communicate with my car.
    daveeasa[QUOTED] likes this.
  3. Oct 28, 2021 at 2:40 PM
    #183
    g2turbo
    g2turbo New Member
    Joining in on the fun here, lots of useful information but i'm still slight confused.
    2002 Tundra, Access Cab
    Info i've found:
    -Window sticker says "convenience pkg w/keyless entry, power windows, door locks"
    -Checked Toyota site using my VIN - Port or Factory installed - "VP Convenience package w/ keyless entry". No mention of security
    What i've tried:
    -going through the programming procedure to see if my truck will accept programming mode (note this is listed as 2003)
    https://www.programyourremote.com/c...ey-programming-instructions-listing-6164.aspx
    - after several attempts, truck isn't accepting. And yes, i made sure to go to the correct key position (on) instead of ACC
    Question
    Is it possible I have an RS system (3000 or 3200)? I can check under dash
    Any advice on next steps? perhaps check under dash for the box?
    Thanks!
  4. Oct 28, 2021 at 2:40 PM
    #184
    daveeasa
    David
    Check under dash for box. Likely rs3000
  5. Oct 28, 2021 at 2:49 PM
    #185
    g2turbo
    g2turbo New Member
    Thanks @daveeasa , just crawled under there and saw a box wrapped in black electrical tape, going to lookup a few pictures and see if that is the unit.
    If so, is there a specific thread for instructions for the RS3000, or do I just need to weave through this thread and put the pieces together? ;)
  6. Oct 28, 2021 at 3:29 PM
    #186
    g2turbo
    g2turbo New Member
    No luck, that ended up being a handful of connectors bunched together and wrapped with Electrical tape.
    What if I don't have either box? Is the truck still equipped with keyless entry like it mentions on the VIN and Window sticker?
  7. Oct 28, 2021 at 3:33 PM
    #187
    daveeasa
    David
    Mine was as you describe. Connectors (not used) in tape and behind that the box in the photo.
    there are instructions (in this thread) to unwind the connectors to allow programming as they are in a loop which blocks programming. Then a button to press to set up new keys. Up to 6? I’ll have to re-read myself as I’m forgetful
  8. Oct 28, 2021 at 4:50 PM
    #188
    g2turbo
    g2turbo New Member
    @daveeasa Does your truck have the security light? Mine has a blank in that location...
    I only ask because the instructions for programming (per the diagram you posted) refer to that light and making sure it's on during the programming for part of the process
  9. Oct 28, 2021 at 4:53 PM
    #189
    daveeasa
    David
    Mine does not. I believe our security modules are entirely add on. Though the toyota owners website seems to imply mine was added at the factory.
    I’m planning my RedArc dial for the blank It’ll be nice to not hit my knee on it like I do in my Tacoma.
  10. Oct 28, 2021 at 6:50 PM
    #190
    g2turbo
    g2turbo New Member
    I found the box, I do indeed have the RS3000 system.
    Unfortunately the fob I bought ends in -056 instead of -022, which I dont think will work with the RS3000 (08190-00921) according to @deh4170
    Also, regarding the connectors being looped (which I also see), do they simply need switched just for the programming, or do they remain swapped afterward?
    Thanks for the help @deh4170 and @daveeasa i'm getting close!
  11. Oct 28, 2021 at 7:09 PM
    #191
    deh4170
    deh4170 New Member
    Donnie
    Knoxville, TN
    2002 Toyota Tundra SR5 Access Cab
    The connectors remain swapped...you should notice that your door locks will automatically lock when ignition is started and unlocks when shut off. Sounds like you are one step closer!
    daveeasa likes this.
  12. Oct 28, 2021 at 7:10 PM
    #192
    g2turbo
    g2turbo New Member
    Awesome! thanks for the help, any need to disconnect the battery before doing that connector swap?
    Ordering a different Fob now, should be back in business by the weekend.
    shifty` likes this.
  13. Oct 28, 2021 at 7:17 PM
    #193
    deh4170
    deh4170 New Member
    Donnie
    Knoxville, TN
    I didn't disconnect the battery, but it never hurts to be 100% certain nothing shorts out. Ensure that ignition switch is turned to the "on" position before pressing the green button on the ECU...I would also do the erase procedure mentioned in earlier posts to erase any previous key fobs.
  14. Oct 29, 2021 at 1:44 PM
    #194
    g2turbo
    g2turbo New Member
    One thing that I still don't understand, is why the plugs need swapped to program and for the functionality to work? If that were the case, maybe the original owner had never used any keyfobs and the feature was just never enabled at the dealer?
  15. Oct 29, 2021 at 1:45 PM
    #195
    daveeasa
    David
    If I'm understanding things correctly, they plug them in, program the pair, lock it down by changing to the loop, then stuff it all up in the dash. Hence no easy key add (probably a potential revenue source for the dealership?) and no security risk? Not really sure though to be honest.
    Seems pretty clear that unplug-replug is the way to go though.
    shifty` likes this.
  16. Nov 3, 2021 at 9:36 AM
    #196
    g2turbo
    g2turbo New Member
    The programming worked! Thanks for all of the help. I went ahead and replaced the ignition lock cyclinder as well during the process.
    Happy to help anyone else that might need it :)
  17. Nov 11, 2021 at 10:46 AM
    #197
    daveeasa
    David
    Got a chance to do this finally. They work. However all buttons do the same thing, lock or unlock based on if it’s currently locked or currently unlocked. The beep tells you what it did. Not bad though, I’ll take it, even though it’s a bit non standard. Preferable to a separate key and fob.
    well, actually, not entirely true. The lock button doesn’t do anything. But unlock, panic and trunk pop either lock or unlock.
    trueblue1981 likes this.
  18. Nov 11, 2021 at 11:13 AM
    #198
    g2turbo
    g2turbo New Member
    That is a much nicer key setup than mine, can you please provide a link for that? Are you going to have it keyed to the same as your ignition key?
  19. Nov 11, 2021 at 11:20 AM
    #199
    daveeasa
    David
    I think I already posted it in here but don’t mind spamming again. Note the points about the icons not actually doing what they say they do. Also note it’s my 2002 with rs3000 not the newer models with 3200 or whatever.
    https://www.ebay.com/itm/SPECIAL-MA...-BAB237131-022-RS3000-BLACK-KEY-/132327596635
  20. Nov 13, 2021 at 12:05 PM
    #200
    daveeasa
    David
    And I’m fully up and running with the flip fob. Yay.
    0166AD78-2FB9-44DF-B4C6-490945B63F4D.jpg 820A5CED-DC1C-4EDB-AF2B-952B48C65D69.jpg
  21. Nov 13, 2021 at 8:20 PM
    #201
    shifty` Goons of Hazzard
    I think I'd actually enjoy this in my 2006. I really get sick of my fob smacking into the dash on bumpy roads, which in ATL is, like, every friggin road.
  22. Jan 11, 2022 at 9:56 AM
    #202
    Belair-o
    Belair-o New Member
    2002 Tundra
    I have a 2002 Tundra that has the factory installed keyless entry system. I bought the truck used, and it came with one remote. I lost the remote, and would like to buy a refurbished OEM unit, but I only see remotes for dealer installed entry systems for sale. I am told if I have the Toyota part number, some of the used remote sellers say they can get me one. I have called Toyota dealer parts, and they give me part numbers for 3-button remotes that aren't for a 2002. Does anyone have a factory installed system and can tell me any info from their remote (FCC#, part #, ?) that might help me get a replacement? Thanks, Doug
  23. Jan 11, 2022 at 10:12 AM
    #203
    Do you happen to have a picture of the original factory remote anywhere, in a picture, anything?
    I think this thread confirms, there were only two types of OEM key fobs, depending on whether you had the earlier RS3000 system or the RS3200.
    Really though, the dealership can run your VIN to figure out which of the two factory systems you have. The part number they gave you should give you the visual pic.
  24. Jan 11, 2022 at 10:18 AM
    #204
    Belair-o
    Belair-o New Member
    2002 Tundra
    Thanks for the reply! I don't have a pic, but it was a two-button OEM remote. The dealership ran my VIN, and said part #0819100922, which is a 3-button remote that isn't listed for my year (when I searched on the part #). I talked to a different dealership and was told they have a 2-button remote for a factory installed system, so I will go look at it in a day or two. Should I be able to program the factory system myself?
    Thanks, Doug
  25. Jan 11, 2022 at 10:28 AM
    #205
    daveeasa
    David
    If you have RS3000 like I do in my 2002, you need to do the unplug and de-loop as instructed in this thread, and you also need physical access to the receiver to program.
    Step 1 is locate the receiver box, take a photo, post here and confirm your FCCID. That then tells you which fobs are compatible.
    No real point in going to the dealer for this stuff, it's not hard, just a little time consuming and you have to learn stuff (took me several attempts to figure out wtf was going on).
    RUSTYNUTS likes this.
  26. Jan 11, 2022 at 10:41 AM
    #206
    Belair-o
    Belair-o New Member
    2002 Tundra
    Thanks for the reply. Is your system factory installed? I will seek to get a pic when I am able. The confirmation from the pic will be good. Thanks! Doug
  27. Jan 11, 2022 at 10:53 AM
    #207
    daveeasa
    David
    Yes. It looks like this on my toyota owners site and also shows on my window sticker. The receiver is tucked up high so you have to take off that lower panel under the steering wheel then remove the ducting and it's still a bear to get to the 10mm nut holding it. Hint: It is not the tape wrapped connector block, it's a foam wrapped box, you'll separate the foam to see the FCC ID. Then you do the connector loopback undo and once you have a fob you can program it.
    So, unfortunately a two step process if you want to avoid potential frustration of purchasing the wrong fob.
  28. Jan 11, 2022 at 11:02 AM
    #208
    Belair-o
    Belair-o New Member
    2002 Tundra
    Thanks for the reply! That info in your pic on the VP portion is just what mine says. I delved into this a couple of years back when I was trying to get a non-OEM fob I bought from ebay to work, so hopefully I can find my way again. Thanks!
  29. Jan 11, 2022 at 11:07 AM
    #209
    daveeasa
    David
    If you have my FCCID you might be interested in going the flip fob route I did. Took 2 tries to find someone who had the right machine to cut it, but works pretty good (just no functional difference between any of the buttons and I think one of the 3 doesn't do anything). Programmed easy enough for me at least, but you really want to know your FCCID before buying anything.
  30. Jan 11, 2022 at 11:51 AM
    #210
    Belair-o
    Belair-o New Member
    2002 Tundra
    Howdy! Thanks for the tip on the flip fob option - I appreciate you telling me the options.
    Thanks, Doug
