Key Fob Replacement 2002 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Peterv, Oct 29, 2019.
  1. Jun 15, 2020 at 4:10 AM
    #61
    Professional Hand Model
    Hand Protectors
    Pics?
  2. Jun 17, 2020 at 5:05 PM
    #62
    Tundruh
    Tundruh New Member
    Tony
    VA BCH
    2005 Tundra Access Cab 4x4
    Did you use to have a regular key and then a fob? I’d love to have this for my 05 AC. What would I need to do to get this key?
    #62
  3. Jun 18, 2020 at 5:39 AM
    #63
    speedtre
    speedtre New Member
    Inland Northwest
    Do you have a current FOB? If so, what is the FCC ID on the back?
  4. Jun 18, 2020 at 8:12 AM
    #64
    chester
    chester best member
    2005 Double Cab SR5
    I checked toyota.com\owners, and there is no listing for any keyless entry on my truck.
    I just bought my 05 DC, and it didn't come with any key fobs. Did all trucks come with keyless entry, or was it an option? I want to make sure my truck is capable before I start this process.
  5. Jun 18, 2020 at 3:44 PM
    #65
    speedtre
    speedtre New Member
    Inland Northwest
    It was an option on the SR5 and Standard on the Limited, which is weird cause it was standard on SR5 ACs...I will say I've not come across a DC without it in any year...call your local Toyota dealer with your VIN, they should be able to tell you if it had it or not.
    TX-TRD1stGEN likes this.
  6. Jun 22, 2020 at 10:11 AM
    #66
    chester
    chester best member
    2005 Double Cab SR5
    Thanks for the info. I called my dealer, and my truck didn't come with keyless entry.
    speedtre[QUOTED] likes this.
  7. Jun 22, 2020 at 6:19 PM
    #67
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    2002 Tundra Factory alarm. Randomly the doors will lock when the fob has not been depressed. Sometimes, I hit the button to lock and it then locks and a moment later unlocks. The inside of the fob looks clean and the battery is good. Ideas?
  8. Jun 23, 2020 at 4:05 AM
    #68
    Hand Protectors
    Mine does this (not randomly) but everytime I enter from only the pass side door. It will lock on its own within 10 seconds as soon as the door shuts. The FOB has nothing to do with it in my case. Its been doing it for a few years. Doesn’t happen on the drivers side.
    Also, my door chime doesn’t work when the pass side door is open like it does with the driver. I wonder if the two are related? I’ve not dived in too hard in this, but from some general reading there may be a fix via the Toyota programming through the OBD?
    robabeatle[QUOTED] likes this.
  9. Jun 23, 2020 at 4:37 AM
    #69
    robabeatle
    AZ
    My issue is not related to the passenger's side door but it does seem to happen within 10 seconds or so of depressing the fob. Yesterday, I closed the doors, pressed the fob to lock, "chirp," and then within 10 seconds another chirp and the doors unlocked. I definitely did not bump the button on the fob. This has happened about 5 times in the last 10 days or so.
  10. Jun 23, 2020 at 5:01 AM
    #70
    Hand Protectors
    Its probs a simple fix, but not worth the track down time for me.
    robabeatle likes this.
  11. Jun 23, 2020 at 6:20 AM
    #71
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    These systems have many optuons that can be customized. One is the auto relock if the door isn't opened within a certain amount of time.
    @Professional Hand Model sounds like your truck isn't registering your passenger door opening. (and therefore relocking after 10 seconds). Perhaps your door switch is bad. Does your interior light come on when you open the passenger door??
    @robabeatle perhaps your issue is happening due to the truck thinking something is left open? Door, hood? Just a guess? I know on some newer vehicles if you leave your fob in the car it will cause the car to unlock and beep after 10 seconds. Do you have a spare fob in your car or something?
  12. Jun 23, 2020 at 2:27 PM
    #72
    Hand Protectors
    Yeah. I replaced both door switches last year with Wells (Toy OEM). When I open the Pass Side suicide door the light comes on. Short maybe?
  13. Jun 23, 2020 at 2:48 PM
    #73
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    I doubt it. Prob just keyless entry installed wrong (not hooked to pass for switch). Many of these "factory installed" keyless entry systems where actually installed by the dealer before sale.
  14. Jun 23, 2020 at 4:15 PM
    #74
    robabeatle
    AZ
    No spare in there but thanks for giving me some things to think about.
  15. Jun 23, 2020 at 4:54 PM
    #75
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
  16. Jun 26, 2020 at 12:10 AM
    #76
    Tech26
    Tech26 New Member
    David
    Seattle
    Blue 2005 Tundra DC 4WD
    Thanks for posting the PDF with the Double Cab key programming dance instructions. I only have 1 fob right now, but ordered a new one on Amazon that matches my current FCC code.
  17. Oct 18, 2020 at 4:34 PM
    #77
    chetsvr6
    chetsvr6 New Member
    Chet
    06 tundra
    None
    No numbers on my remotes. 2006 tundra. Numbers off my remote box is 100500298913618881 and mpx module part# 00016-0C050-01.Hope you can help.Thank you
  18. Oct 18, 2020 at 4:34 PM
    #78
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The owners manual has the fcc is in it somewhere at least 03-06 does
  19. Oct 18, 2020 at 4:57 PM
    #79
    chetsvr6
    chetsvr6 New Member
    Chet
    06 tundra
    None
    BAB237131-056.Not sure if this is it. Printed in owners manual. Can't see every owners manual printed different
  20. Oct 18, 2020 at 4:58 PM
    #80
    empty_lord
    05 rollover special
    Possible the 02 and older being dealer installed 90% of the time I believe it would of been in the manual with the rs3200 setup
    speedtre likes this.
  21. Oct 18, 2020 at 6:39 PM
    #81
    chetsvr6
    chetsvr6 New Member
    Chet
    06 tundra
    None
    How about elvatdd
  22. Oct 18, 2020 at 6:46 PM
    #82
    empty_lord
    05 rollover special
    this is what i ordered off of for my trucks fob. worked perfectly Amazon had the one with the correct FCC id number.[​IMG]
  23. Oct 19, 2020 at 6:28 AM
    #83
    speedtre
    speedtre New Member
    Inland Northwest
    abcinv likes this.
  24. Oct 21, 2020 at 7:18 AM
    #84
    chetsvr6
    chetsvr6 New Member
    Chet
    06 tundra
    None
    #84
    Tundy_Dan likes this.
  25. Nov 17, 2020 at 1:56 PM
    #85
    blur000
    blur000 New Member
    Josh
    2002 SR5 4.7L V8 Access Cab 4X4 4 speed auto
    Hi there everyone,
    I recently purchased a 2002 Tundra SR5 AC V8 from it's original owner. So far i have replaced the seat belt, with the help of Professional hand model and lssami's help, changed all of my interior lights out to LED thanks to this forums help...and soon enough will be embarking on changing out the timing belt / accessories belt, thermostat and water pump. So for starters, thank you! Appreciate this community and the help everyone graciously gives!
    When i bought the truck, it didn't come with FOB's. The lock set on the drivers side was broken so that it would only turn in the unlock direction, not lock. I pulled the lock set and fixed the tumblers...but given i would like to go easy on the lock AND the added convenience of unlocking / locking my truck with a remote seems important.
    Would anyone be able to help me track down what remote i need to order? Here is the facts i know:
    • It was factory installed (attached image).
    • It is a RS3000 system (attached image).
    • The box itself has an FCCID stamped BAB237000-129 on it (attached image).
    I know there are two keys out there: BAB237131-022 and BAB237131-056. Will either of those work for my truck? Do i need an exact FCCID Match to BAB23700-0129?
    Any help would be super appreciated here!
    Cheers!
    Josh
  26. Nov 17, 2020 at 2:05 PM
    #86
    speedtre
    speedtre New Member
    Inland Northwest
    This post has all the info you need to make a choice...
    https://www.tundras.com/threads/key-fob-replacement-2002-tundra.55779/#post-1457777
  27. Nov 17, 2020 at 3:41 PM
    #87
    blur000
    blur000 New Member
    Josh
  28. Nov 17, 2020 at 4:25 PM
    #88
    speedtre
    speedtre New Member
    Inland Northwest
    RS3000 programming is pretty easy...:thumbsup:
  29. Nov 17, 2020 at 8:08 PM
    #89
    BlueShadow1
    BlueShadow1 New Member
    2006 Black Tundra 6 Cylinder 4L
    I got mine at carandtruckremotes.com, for my '06 Tundra, for $59. The directions to program it were crazy and fun, and they worked. The only mistake I think I made was on one step I held the button down for 2 seconds instead of 1.5 seconds...I guess my sense of half a second isn't that great (grin!)
    Edited to add: I bought my truck without a fob, so I couldn't look up the information on the back of a fob. According to the Toyota dealership (who told me it that a fob would cost me $159 plus whatever time it took them to program it (!!!)) which fob to get depends on whether it was factory installed or dealer installed. I asked carandtruckremotes.com what fob to order based on the year, make and model of my truck, and might have just gotten lucky to get one that worked. But since they said I could return it for only shipping (they quoted $2.62, I think), I figured it was worth it to order one of them and if it didn't work, to send it back order the other one.
  30. Dec 2, 2020 at 1:21 PM
    #90
    blur000
    blur000 New Member
    Josh
    Well..I ordered the BAB2371-022 from ebay. I'm not getting anything at all. I decided that maybe it was the ECU and I ordered another from ebay for $25. No dice on that either. I'm at a loss for the moment and if anyone has some ideas, I would appreciate it.
    Wrong remote? Bad wiring?
    Here is the link to the remotes i bought.
    2 Replacement for Toyota BAB237131-022 RS3000 Key Fob Remote Grey
    #90
