Key Fob Replacement 2002 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Peterv, Oct 29, 2019.
  1. Apr 9, 2020 at 10:45 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Yes...nearly ALL locksmiths stock and program Key Fobs now (though they may not have every key fob out there)...it's a big money maker for them and they are still cheaper than dealers. Hell, our local ACE hardware has a big selection of key fobs and can program them, so you might try there as well as your local locksmith.
  2. Apr 9, 2020 at 1:41 PM
    bigcoaxum
    bigcoaxum New Member
    Mark
    2002 Tundra
    Thanks alot. I'll try it.
  3. Apr 9, 2020 at 2:34 PM
    toyoboyo
    toyoboyo New Member
    Got this sorted out.
    I used the links and the posts above to program the fob, then I used this website link to program the transponder chip inside the key itself.
    https://www.programautokeys.com/cla...g-instructions-listing-8367.aspx#.Xo-Ud8hKiUl
    speedtre likes this.
  4. Apr 9, 2020 at 2:50 PM
    bigcoaxum
    Mark
    2002 Tundra
    I think the method you listed for the key fob programming only pertains to trucks with the factory installed keyless entry system and not the RS3000 system. I have the RS3000 system and this is dealer installed, I think. correct me if I'm wrong.
  5. Apr 9, 2020 at 2:54 PM
    toyoboyo
    toyoboyo New Member
    Yes I believe you are right.
    What I posted was for an 05 Sequoia
  6. Apr 17, 2020 at 6:58 AM
    JQ3
    JQ3 2005 XSP rwd
    I just got around to trying again for about the 50th time with the instructions you gave. No mater what I do I cannot get my truck to even prompt what mode it’s in, let alone program the remotes I bought months ago! My last time trying, about 10 minutes ago, my truck’s unlock stopped working! I got it working again, but I was so frustrated I couldn’t even think to try again! I’m sooooo damn pissed right now!!! I guess I’ll have to take it to the dealer...dammit!!!!!!
  7. Apr 17, 2020 at 7:05 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I would recommend taking it to the dealer who sold you the key fobs on the off chance they sold you the wrong ones, so at least that hassle would be eliminated. Hopefully that don't charge you more than 1/2 hour of book time (probably $60-70).
  8. Apr 20, 2020 at 6:03 AM
    wildduk
    wildduk New Member
    Atlanta
    2006 DC 2WD
    I purchased a used/ new to me key FOB. It’s square in shape with 2 buttons on front, lock and unlock, and a red panic button on the back. The ny,her on the back are identical. FCC ID ELVATDD.
    It’s for a 2006 DC.
    I took the FOB to the dealer and they said that their techs could not program it. I’ve tried with no luck.
    Any advice on how to do this. The FOB has been sitting in my center console for years since I’ve given up, then I stumbled upon this forum.
    Thanks.
  9. Apr 20, 2020 at 6:56 AM
    speedtre
    speedtre New Member
    Inland Northwest
    So you are saying you had a known good key fob for your truck and you bought a used one with the same FCC ID (ELVATDD)?
    Do you know where your Toyota was originally sold from? If it's a SET/GSR (SouthEast Region or Gulf States Region) Toyota, it probably has a port installed system. If you don't know, go to toyota.com\owners register your truck and click on view specs...
    Then look for this...
    Does it say port or factory?
    TX-TRD1stGEN likes this.
  10. Apr 20, 2020 at 7:18 AM
    wildduk
    wildduk New Member
    Atlanta
    2006 DC 2WD
    My report does not specify.....But yes, I had a good working FOB and purchased the same one.
  11. Apr 20, 2020 at 10:46 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Ok, well, your selling dealer is Marietta Toyota in GA (only about 30 miles from me!) so your's is a SET vehicle.
    look at these two posts...you may want to confirm the number on your square black box behind the kick panel. If the instructions attached to that post don't work then I would start to think that the FOB you have is bad (especially since the dealer said they couldn't program it...are they a SET dealer?). In that case, you might want to try a new FOB, since the one you bought was used and you don't know for sure if it worked before you got it.
    https://www.ebay.com/itm/For-Toyota...-ELVATDD-ELVAT1B/293410225732?epid=1339572008
  12. Apr 25, 2020 at 1:42 PM
    wildduk
    wildduk New Member
    Atlanta
    2006 DC 2WD
    Is this the control box? It was behind the drivers side kick panel....
  13. Apr 27, 2020 at 7:27 PM
    JQ3
    JQ3 2005 XSP rwd
    I think I found out why my FOBS won’t program. I have a BlueDriver scanner and today I was just goofing around with so I decided to do “scan”. My scanner found code B1242 Wireless Door Lock Tuner Circuit. Now I have figure what to do next. I Googled it, of course, but there is a plethora of things to investigate! So the journey continues to program the remotes I’ve had for almost a year! Any ideas???
  14. Apr 28, 2020 at 1:01 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Inspect wiring. But good chance it’s a failed module
  15. Apr 28, 2020 at 8:44 AM
    JQ3
    JQ3 2005 XSP rwd
    Where exactly is the module?
  16. Apr 28, 2020 at 10:03 AM
    empty_lord
    05 rollover special
    Wireless door lock computer. No clue where it is on a double cab, but access and reg cab are behind the instrament cluster
  17. Apr 28, 2020 at 11:31 AM
    JQ3
    JQ3 2005 XSP rwd
    Oh my that sounds crucial!!! Thanks!!!!
  18. Apr 28, 2020 at 12:45 PM
    empty_lord
    05 rollover special
    A tech stream or snap on scanner should be able to get into the door computer and be able to better diagnose any issues.
  19. Apr 30, 2020 at 9:15 PM
    #49
    pock
    pock New Member
    USA
    2005 Access Cab 4.7L V8 4x4 SR5
    Pretty sure mine is factory. Any idea? Would love to program a spare.
  20. Apr 30, 2020 at 9:21 PM
    #50
    pock
    pock New Member
    USA
    anyone try this with an 05 access cab?
  21. Apr 30, 2020 at 9:27 PM
    #51
    pock
    pock New Member
    USA
    How did that process work? (using the original key fob). I’ve never thought of upgrading the key fob like you did. But I have to admit for $17 you did great!
  22. Apr 30, 2020 at 9:42 PM
    #52
    empty_lord
    05 rollover special
  23. May 1, 2020 at 4:21 AM
    #53
    speedtre
    speedtre New Member
    Inland Northwest
    #53
    pock[QUOTED] likes this.
  24. May 30, 2020 at 11:24 AM
    #54
    Skoolieman
    Skoolieman New Member
    Chattanooga, TN
    02 Tundra Limited V8 4x4 trd offroad package
    How do I know which fob my 2002 ac limited needs. I looked at Toyota owners site but it doesn't specify port or factory. It just lists keyless entry as a feature. I'd really like to get a fob for this truck since the previous owner had a new ignition installed and the keys are not the same now.
  25. May 30, 2020 at 2:06 PM
    #55
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    @speedtre My fob has the red light but on my toyota owners it doesn't say anything about a keyless entry. Since I have an 03 Do I have the RS3200 and whats is the difference between they two?
  26. May 30, 2020 at 7:07 PM
    #56
    speedtre
    speedtre New Member
    Inland Northwest
    What is the FCC ID on your key fob?
  27. May 30, 2020 at 8:28 PM
    #57
    jImmegart
    Jonah
    California
    BAB237131-056
  28. Jun 1, 2020 at 4:46 AM
    #58
    speedtre
    speedtre New Member
    Inland Northwest
    You need to read this link and pay attention to the links in it that tell you how to find your ECU for the remote entry. Once you find that, it should have your FCC ID that you then buy a key fob for.
  29. Jun 1, 2020 at 4:52 AM
    #59
    speedtre
    speedtre New Member
    Inland Northwest
    Yea...you have an RS3200...not sure what you mean by difference between the two unless you mean the difference between an RS3200 and RS3000...then you can read these..
    https://www.manualslib.com/manual/621697/Toyota-Rs3200.html
    https://www.manualslib.com/manual/806718/Toyota-Vip-Rs3000.html
  30. Jun 14, 2020 at 7:08 PM
    #60
    empty_lord
    05 rollover special
    I’m just waiting for meso designs to release the flip keys for the 4runners so I can get the single piece setup for the tundra in a slick color matched case
