Key fob issues
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Flipmode, Jun 30, 2020.
  1. Jun 30, 2020 at 7:17 AM
    Flipmode
    Flipmode [OP] New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    Cold air intake, LED upgraded lights, 295/70/18 Toyo Open Country M/T.
    I bought a brand new 2020 Tundra TRD Pro two weeks ago and started having issues with the key fob locking the doors. When I close the door and press lock, I can press it over and over again, but it takes about 10-20 seconds to respond and lock. I got the second remote out to make sure the first didn’t have a faulty battery, but same thing. Anyone else experiencing this on a new Tundra?
  2. Jun 30, 2020 at 7:54 AM
    Superwhite19
    Superwhite19 New Member
    2019 Superwhite CM
    My 2019 does the same, i have replaced the batteries in both key fobs and still same result. sometimes the buttons do as they are intended to do first click, sometimes it takes some button mashing to get the truck to respond accordingly.
  3. Jun 30, 2020 at 8:00 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I would just schedule a diagnostic with your first free oil change; it’s under warranty so they’ll have to fix it.....
  4. Jun 30, 2020 at 9:08 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Did you recently change your cargo lights to LEDs?
    RainMan_PNW, Superwhite19 and hagrid like this.
  5. Jun 30, 2020 at 9:54 AM
    King R 808
    King R 808 New Member
    Ryan
    2020 White Tundra TRD Pro
    i have this same issue. I noticed mine tho once i changed to a AJT Designs key fob so i figured it was that. But now that i read this maybe i should pull the second Fob out and test it.
  6. Jun 30, 2020 at 9:58 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Please see this response.
    The antenna is in the cargo light area and some LED bulbs cause interference. Turn the cargo light off. Try again.
  7. Jun 30, 2020 at 10:05 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    VLED came out with a suppressed bulb to stop that type of interference. I witnessed it first foot.
  8. Jun 30, 2020 at 10:17 AM
    Superwhite19
    2019 Superwhite CM
    cargo light it is. thanks fellas!
    turned the light to off and works as it should
  9. Jun 30, 2020 at 10:23 AM
    King R 808
    Ryan
    what bulb is it from Vleds? I wonder since mine isn't that old they would return it and give me one that doesn't cause issues.....
  10. Jun 30, 2020 at 1:33 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I think this it... had to dig through my emails:
    921_36_5.5K_TUNDRA 5500K WHITE HIGH OUTPUT 36 LED 921 | 2018+ TOYOTA TUNDRA
  11. Jun 30, 2020 at 1:47 PM
    King R 808
    Ryan
    Yep that's the same one i have to. I just finished talking to Vleds and they are shipping me a new set because i'm having this issue. Good looking out on this one! Thank you!
    hagrid[QUOTED] likes this.
  12. Jul 28, 2020 at 10:56 AM
    Flipmode
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    That was definately it. I made it to where the truck lights turn off when truck is off, and works just fine. I did upgrade to LED's using Precision LED's. Guess I should've done more research and used Vleds. Think changing just the cargo light to Vleds would fix this?
  13. Jul 28, 2020 at 12:13 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Yaesh...
  14. Aug 9, 2020 at 6:51 PM
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    Changing my over to LED this week. Thanks for the heads up and i will be watching that issue.
  15. May 8, 2021 at 10:48 AM
    Chicko2020sx
    Chicko2020sx New Member
    Michael
    2020 Tundra SX
    Led headlights, Led fog lights, tonneau cover, ventvisors.
  16. May 10, 2021 at 1:59 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Here is a update also. If you have the Fyre flys I have the 3014 series causing the issue on my 21 tundra Pro. He know s about it and sending me out new bulbs to stop the key fob issue. He is also going to have prototypes soon to be out to stop the key to. Issue. It’s the map lights and cargo lights that cause the issue. I turned mine off and key fob is fine.
    IndianaGeologist likes this.
  17. Oct 14, 2021 at 2:31 PM
    ggrazuli
    ggrazuli New Member
    G-
    2020 crewmax SR5
    Leveled, decked, soft topper, 100ah backup with fridge and solar
    I had a similar issue with my 2020 crewmax sr5 with smart key. after reading this thread I changed all my LED bulbs back to factory and the problem still persisted. It turns out that a usb to 10V charge adapter for a baofeng radio was causing the problem. The dealership unplugged it and now it works like a charm. I'm going to try and buy another one from a different brand and see if it has the same issue. Will post findings.
  18. Nov 1, 2023 at 2:18 PM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    I'm running into this issue right now and figured it was the battery in key fob. I replaced and no go. Turned off cargo lights and still only works when warm out. Cold mornings not working. Battery is an AGM Northstar and only 2 years old
  19. Nov 19, 2023 at 5:01 AM
    ronrich
    ronrich New Member
    I just recently changed my cargo lights on my 2015 Tundra with the LED kit from Fyreflys.com I contacted them before I purchased the kit about this issue and they told me they added shielding to the resistors on the cargo lights. They arrived and the cargo lights had what appears to be EMI shielding over the resistors. I have no problems with my key fob, works as it should. The lights are much brighter than stock and they look great!
  20. Jan 22, 2024 at 9:38 AM
    Bigrobdsp
    Bigrobdsp New Member
    Robert
    2008 SR5 and 2019 TRD Pro tundra
    TBD
    I've been dealing with this problem for 4 years and just saw this post. I love the interwebs.
    RedRegCab and H-Nanni like this.
  21. Feb 21, 2024 at 10:18 PM
    H-Nanni
    H-Nanni New Member
    2018 Tundra Platinum
    same... lol
