Kenwood eXcelon Reference DMX1057XR
Discussion in 'Audio & Video' started by BamaMan44, Sep 29, 2020.
  1. Jan 12, 2021 at 10:27 AM
    #151
    dkrou
    dkrou New Member
    dan
    2019 tundra
    No it works as well. They provide the gps antenna with the unit since they don’t know what oem antennas you have on yr truck to start with
  2. Jan 12, 2021 at 11:49 AM
    #152
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Havent decided on this or the one that has navigation built in
  3. Jan 12, 2021 at 8:08 PM
    #153
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Do I need the antenna adapter?
    BamaMan44[QUOTED][OP] likes this.
  4. Jan 12, 2021 at 9:28 PM
    #154
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Yes, if you want to use the stock antenna for FM radio.
  5. Jan 12, 2021 at 9:30 PM
    #155
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    It appears that JVC Kenwood released a new firmware update for our radios on 12/15/2020 : https://www2.jvckenwood.com/cs/ce/mm/firmware/2020/2020g/eng.html
    I updated my radio tonight, took about 5 minutes and was easy to do. We'll see if this helps at all with the wireless CarPlay stuttering I was intermittently experiencing.
    BamaMan44[OP] likes this.
  6. Jan 12, 2021 at 9:31 PM
    #156
    AZBoatHauler
    So.Arizona
    I didn’t connect the power on my 2017 and I still get all the channels I got before - even HDRadio. I do believe it’s required on the new trucks with the shark fin antenna.
    Edit for clarity.
  7. Jan 12, 2021 at 9:32 PM
    #157
    AZBoatHauler
    So.Arizona
    See if the stuttering is linked to a certain location. There are a couple intersections around that I get this and it’s always the same intersections.
  8. Jan 12, 2021 at 9:36 PM
    #158
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Hang on, what did you plug into the FM radio antenna receptacle on the radio then? Or did you just not plug anything into it?
    It's not location-specific for me. I've done plenty of trips where the wireless CarPlay works without a hitch, and others where it has problems every once in a while. I'm sure that actual RF interference of some type may cause these issues in certain cases but I don't think that's what's causing my issue.
    EDIT: Just to clarify, for example, it one time happened on a trip on 101 South heading through Gilroy, and hasn't happened again there since.
  9. Jan 12, 2021 at 9:58 PM
    #159
    AZBoatHauler
    So.Arizona
    I plugged the antenna in I just didn’t connect the blue wire for power as I read the 2014-2017 didn’t utilize powered antennas.
    Oats87[QUOTED] and 619Tundra like this.
  10. Jan 12, 2021 at 10:00 PM
    #160
    AZBoatHauler
    So.Arizona
    I have one if you want it.
  11. Jan 12, 2021 at 10:01 PM
    #161
    619Tundra
  12. Jan 12, 2021 at 10:06 PM
    #162
    AZBoatHauler
    So.Arizona
    I did the install a year ago so I can’t exactly recall every detail but my conclusion was I didn’t need it which is why I still have this.
    I’m not curious enough to pull the HU out to look.
    619Tundra[QUOTED] likes this.
  13. Jan 12, 2021 at 10:37 PM
    #163
    AZBoatHauler
    So.Arizona
    Ok, I lied. I went and pulled out the HU to see what’s going on. I do have an adapter that is plugged into the HU but the blue wire is not powered. I’m not sure why or how I ended up with an extra adapter but it’s yours @619Tundra if you want it. PM me your address and I’ll put it in the mail.
    panicman and BamaMan44[OP] like this.
  14. Jan 13, 2021 at 2:24 AM
    #164
    BamaMan44
    BamaMan44 [OP] Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    I have a 2017 and needed it.
  15. Jan 13, 2021 at 7:14 AM
    #165
    619Tundra
    That is awesome! You're the man. PM sent. Thanks for your kindness. I'll post pictures of the entire system install when I'm done here soon.
    Oats87 likes this.
  16. Jan 13, 2021 at 3:15 PM
    #166
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Do you have any kenwood app on your phone?
  17. Jan 13, 2021 at 3:38 PM
    #167
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    This is so sweet. Can the screen be fitted any higher than it is currently?
    619Tundra likes this.
  18. Jan 13, 2021 at 3:41 PM
    #168
    619Tundra
  19. Jan 21, 2021 at 12:40 PM
    #169
    Desolate
    Desolate New Member
    2019 White Crewmax Off Road
    Just received everything from Cruthfield in the mail yesterday. Thanks to all who have posted their installs for the help.
    I am still a bit hesitant to lose some of the functions of the factory stereo if it is so.
    Can anyone here confirm that all factory steering wheel buttons will work? Is there any change in the buttons? I have read volume is opposite? Does voice control work? Will the gauge cluster still show fuel mileage, stations, TPMS and maintenance?
    Thanks in advance
  20. Jan 21, 2021 at 12:57 PM
    #170
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Yes, your steering wheel buttons will continue to work. Volume up is still right, volume down is still left for me. When you are programming the Maestro unit, you have the option to remap the buttons to various functionality mapped to the radio/Maestro. Gauge cluster will still show you fuel mileage, TPMS, maintenance, etc, but will change your "Now Playing" screen to what the Maestro gives it, and also your arrow when navigating won't do that anymore.
    Voice control button now activates Siri for me, will probably activate google assistant if you have that.
  21. Jan 21, 2021 at 1:21 PM
    #171
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    You also gain the ability to mute by holding the volume down button for about three seconds. Pretty cool
    BamaMan44[OP] and Oats87[QUOTED] like this.
  22. Jan 21, 2021 at 3:16 PM
    #172
    Desolate
    Desolate New Member
    Thanks for the responses! Now I am even more sold. Will install this weekend and post pictures.
    BamaMan44[OP], 619Tundra and ATHiker like this.
  23. Jan 22, 2021 at 8:29 PM
    #173
    aresenalgunner007
    aresenalgunner007 New Member
    San Diego
    2019 Black TRD PRO
    BFG KO2’s
    So I’ve got the Kenwood DNX1057 XR coming in tomorrow to install in my 2019 PRO with OEM non JBL head unit into a JL VXI amp. Anything I’m missing or tips, so I can get it all done in one shot?
    upload_2021-1-22_20-31-4.jpg upload_2021-1-22_20-31-4.jpg upload_2021-1-22_20-31-4.jpg upload_2021-1-22_20-31-4.jpg upload_2021-1-22_20-31-4.jpg upload_2021-1-22_20-31-4.jpgupload_2021-1-22_20-31-4.jpgupload_2021-1-22_20-31-4.jpgupload_2021-1-22_20-31-4.jpgupload_2021-1-22_20-31-4.jpg
    Desolate likes this.
  24. Jan 22, 2021 at 9:24 PM
    #174
    619Tundra
    Why the over ride parking brake? You can ground the wire to the back of the unit.
  25. Jan 22, 2021 at 9:46 PM
    #175
    aresenalgunner007
    San Diego
    2019 Black TRD PRO
    BFG KO2’s
    See it’s tips like this that are appreciated! I haven’t installed a head unit since I was in high school and it was much simpler then haha.
  26. Jan 31, 2021 at 7:55 PM
    #176
    Desolate
    Desolate New Member
    Just finished installing mine today. It took longer than I thought but turned out great!
    I ran the microphone to the overhead console. I am not sure what this factory location is for but it worked great for hiding the mic.
    JPB_VT, panicman, HulkSmurf14 and 3 others like this.
  27. Jan 31, 2021 at 8:06 PM
    #177
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    That's were the mic used to be on earlier Tundras. Good choice! Looks clean. Can you tell me, can you scroll thru XM stored presets using the steering wheel controls? I cannot on my current Kenwood, and my desire to upgrade to this depends on that, because it's the one feature I miss from my stock radio.
  28. Jan 31, 2021 at 8:08 PM
    #178
    BamaMan44
    Andre
    Tucson
    good looking install!
  29. Jan 31, 2021 at 8:23 PM
    #179
    BamaMan44
    Andre
    Tucson
    I haven't driven my truck in a few weeks, but I'm pretty sure you can. At least I remember doing it. lol
  30. Jan 31, 2021 at 8:47 PM
    #180
    619Tundra
    This is the location o want to put mine in. Is it hard to run the Microphone?
