KB Voodoo Premium Bed Rack for Tundras
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by KB Voodoo, Jun 15, 2017.
  1. Feb 14, 2018 at 11:28 AM
    #61
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    The deed has been done.:bananadance:
    itsdchz and KB Voodoo[OP] like this.
  2. Feb 15, 2018 at 6:22 PM
    #62
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
  3. Feb 15, 2018 at 6:26 PM
    #63
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This looks like a great rack Chad. Nice work.
  4. Feb 16, 2018 at 7:19 AM
    #64
    KB Voodoo
    KB Voodoo [OP] New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
  5. Feb 16, 2018 at 7:19 AM
    #65
    KB Voodoo
    Chad
    Thanks man!!
  6. Feb 16, 2018 at 9:06 AM
    #66
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Installed it last night after I got home from having the Icon lift installed!
    WOW- The 18" Rack is pretty amazing. At first I was overwhelmed with, what I thought, was a lack of directions. My Bad! This was WAY easy to understand, put together and get on the Tundra! I was able to mount the TRED1000s using the TRED mounting plate to the top rail.
    Bummed that I added the MaxTraxx mount thinking that it would somehow work with the TREDs, but that is on me. I am sure I will find use for the mount.
    I do need to figure out the best way to mount my HiLift jack. Any thoughts Chad? I tried rigging the OEM HiLift mount that I had on my 4Runner rack, but the mounting points wouldn't work, plus I am worried about the thin metal on the side flexing over time with the weight of the Hi-Lift. Maybe the top crossbars? Thoughts?
    Also will the RotoPax mounts simply attach to the side support beams?
    Thank you so much for your speedy delivery as we head out on our 2000 mile trip this weekend!
    Some pics:
    Sunnier, blue16, pdiddy and 2 others like this.
  7. Feb 16, 2018 at 9:10 AM
    #67
    KB Voodoo
    Chad
    You do know that I'm stealing these pics, right?
    For the Hi Lift, run a long 5/8" bolt through the jack and into the side plate. Fender washers are your friend. I'd use a wing nut for quick access to the jack.
    Sunnier and itsdchz[QUOTED] like this.
  8. Feb 16, 2018 at 9:35 AM
    #68
    itsdchz
    Clovis, CA
    Awesome, that is what I was going for. Thanks!
    I will be taking more pics this weekend with the Nikon D850 ;)
    Those will be even better keepers!
    KB Voodoo[QUOTED][OP] likes this.
  9. Feb 16, 2018 at 9:44 AM
    #69
    KB Voodoo
    Chad
    Full frame deliciousness.
  10. Feb 16, 2018 at 2:06 PM
    #70
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    I don't believe you!
  11. Feb 17, 2018 at 3:12 PM
    #71
    erik_jm
    erik_jm New Member
    Erik
    Michigan
    2017 TRD Pro
    '18 LED Headlights & Fog lights, Center console safe
    Any chance you could take a pic level with the top of the rack? I’m considering this rack but would like to see the relation to the roof line of the cab. Thanks!
  12. Feb 17, 2018 at 8:17 PM
    #72
    itsdchz
    Clovis, CA
    Absolutely! Took this in Zion today for you!
    KB Voodoo[OP] likes this.
  13. Feb 18, 2018 at 7:22 AM
    #73
    erik_jm
    erik_jm New Member
    Erik
    Michigan
    2017 TRD Pro
    Thank you! Looks beautiful there.
  14. Feb 18, 2018 at 6:26 PM
    #74
    itsdchz
    Clovis, CA
    Thank you!
    I’ll have some more pics for the trip later this week!
  15. Feb 20, 2018 at 3:39 PM
    #75
    itsdchz
    Clovis, CA
    Some updated Pics!
    blue16, pvdubber and KB Voodoo[OP] like this.
  16. Feb 20, 2018 at 4:22 PM
    #76
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    You are killing me dude, that is one nice Tundra.
    itsdchz[QUOTED] likes this.
  17. Feb 20, 2018 at 5:59 PM
    #77
    itsdchz
    Clovis, CA
    Thank you!!
  18. Feb 21, 2018 at 11:02 PM
    #78
    itsdchz
    Clovis, CA
    Added the HiLift and Rotopax:
    blue16, pdiddy and KB Voodoo[OP] like this.
  19. Feb 21, 2018 at 11:07 PM
    #79
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    First your T4r, now this. When my T4R & Tundra grow up they hope to be yours.
  20. Feb 21, 2018 at 11:10 PM
    #80
    itsdchz
    Clovis, CA
    Ha! Thank you... You can spot my T4R in one of the pics ;)
  21. Feb 23, 2018 at 3:28 PM
    #81
    erik_jm
    erik_jm New Member
    Erik
    Michigan
    2017 TRD Pro
    Do you mind measuring the width of the rack along the top bar? Trying to figure out how much room I’ll have after mounting my RTT. Thanks again.
  22. Mar 1, 2018 at 5:08 PM
    #82
    KB Voodoo
    Chad
    1UPPER likes this.
  23. Mar 3, 2018 at 10:43 PM
    #83
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    My contribution to this thread. Man is this Rack well built, and I am incredibly happy with it thus far, but those instructions need work it basically says here is picture of a rack use parts provided to make yours look similar. I kid.
  24. Mar 6, 2018 at 8:46 AM
    #84
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    Any info you can share as to where the axe mounts you are using in this picture came from.
  25. Mar 6, 2018 at 8:51 AM
    #85
    itsdchz
    Clovis, CA
    pvdubber likes this.
  26. Mar 6, 2018 at 9:13 AM
    #86
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
  27. Mar 6, 2018 at 9:23 AM
    #87
    itsdchz
    Clovis, CA
    Mine is the Double fist with the 1.125" tube diameter. Depending on your rack, you would need either a tube clamp mount or a flat.
  28. Mar 10, 2018 at 8:22 PM
    #88
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Nice rack.
    My wife is not liking this site at all. Everyday I come up with a couple more things I “Need”.
    LOL
    Sunnier, blue16 and KB Voodoo[OP] like this.
  29. Mar 22, 2018 at 12:23 PM
    #89
    EP34FR
    EP34FR New Member
    How's visibility out the rear-view mirror with the 10" high rack?
    I like the lower profile looks of the 10" rack, vs. the 18" one, and think it'd help keep an RTT a little lower - to help with fuel economy and to keep from snagging low hanging trees - but it looks like it kills your use of the rear-view mirror. Especially once you mount a RTT on it.
  30. Mar 22, 2018 at 1:29 PM
    #90
    CCLA
    CCLA New Member
    I'm still curious about 2 things with this rack
    1: Will it fit over a Diamondback Bedcover?
    2: Is it tall enough to mount a full size roof rack on it that will overhang the cab?
