Kayak Rack Options
Discussion in '2.5 Gen Tundras (2014-2021)' started by freedomoftime, Aug 11, 2020.
  1. May 8, 2023 at 8:08 AM
    reefcomber
    reefcomber New Member
    New England
    2018 Platinum
    Checking to see if anyone knows about an aftermarket product that has some sort of mount that drills into the rails of the bed but the supports and the crossbars can be removed when not in use?
    Adjustable supports would be cool too but not a dealbreaker.
    I am just curious if there would be a way to use a rack for a kayak, but still be able to kee the tonneau closed.
  2. May 8, 2023 at 9:14 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I know this is an old post resurrected, but hats off to all you guys who have the energy and strength to lift your kayaks back onto a rack after a day of paddling. I have a 11’ and 14’ sit on top fishing kayak that weighs 65-85 lbs. I’ve just used a bed extender that attaches to the hitch for mine.
    Where I fish requires a lot of paddling and it’s difficult enough to just load it back in the bed when I’m done.
  3. May 10, 2023 at 2:17 PM
    NyCSnEaK
    NyCSnEaK New Member
    Yaq
    Tundra AG CM TRD
    I use a hitch bed extender and transport up 16’ long kayaks and canoes. Here’s my set up. I loaded up as much as 4 of them in various lengths. I use a combination of straps and bungee cords. Traveled thousand miles each way a few times with no issues. I just load into the bed, which makes it nice and easy.
    ejes likes this.
  4. May 10, 2023 at 4:23 PM
    seydou
    seydou Distinguished Member
    Trailers are the easiest.
  5. May 10, 2023 at 9:05 PM
    SD Surfer
    Bruce
    So Cal
    I was surprised how few options there are to run racks and tonneau together... fewer still if you want a tri-fold rather than roll-up or retract.
    I went with Elevate racks and T-Slot rails, and a BakFlip MX4 Tri-Fold.
    Had some Yakimas off my old Tundra so I MacGyvered the landing pads to the the cleats that came with the Elevate system, so I have the option to run the Yakima bars down low if I want. May mount bike fork mounts to that.
    I bought the Elevate rails ($200) so they could get installed at the same time as the tonneau cover, then I added the racks later.
    The racks come with a high and low setting, but the low was an inch or two too short to let my tri-fold fold, and the high was way too high and kinda' goofy looking, so I drilled a new set of holes for the med height you see pictured.
    I wanted them just high enough that my cover would open and my SUP's and surfboards would clear the cab. I don't have a kayak, but my touring SUP is 14' long and wifey's is 12' 6".
    I'm real happy with the set-up so far.
  6. May 15, 2023 at 9:53 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Yakima HD overhaul truck bed rack system should solve your issues
  7. Jun 4, 2023 at 2:24 PM
    LJOHNS
    LJOHNS New Member
    Here is mine:
    Add a rack and cover from Agri-Cover.
    DrRansom likes this.
  8. Jun 4, 2023 at 3:41 PM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    I have 2 10.5 sit on tops (they are wide barges). I just trap them in the bed.
  9. Aug 15, 2023 at 3:58 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    Normally for just a quick morning paddle at a local lake with my daughter, I just toss them in the bed resting on the tailgate and strap them down.
    For longer trips and times when I want to be able to access cargo stored under the kayaks without unloading them, I built this rack that ties into the cargo rail system. I load the kayaks on top of that and strap them down. Then I can still open the tailgate without having to unload the kayaks. In fact, I’ll be loading my truck like this on Saturday for vacation. All our other gear and food for the week will fit under the kayaks.
  10. Aug 15, 2023 at 5:00 PM
    NyCSnEaK
    NyCSnEaK New Member
    Yaq
    Tundra AG CM TRD
    I like that 119 Discovery Sportsman. Got the same one and it’s a workhorse.
