Katzkin Install Tips/Advice
Discussion in '2.5 Gen Tundras (2014-2021)' started by Danimal86, Oct 18, 2020.
  1. Oct 25, 2020 at 9:32 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    ElNopal likes this.
  2. Oct 27, 2020 at 4:09 PM
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    @socaltundra951 @Patch999
    how do you get the seat release off? I see a couple clips, but i dont want to pry too hard on it.
    There are two philips head screws on top and bottom, but how the hell do you get to the ones on the underside
    This is the passengers side rear seat. Its the handle on the side to lift the seat.
  3. Oct 27, 2020 at 4:12 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Again, you need to remove that? I just did this job and did my rear seats and never removed the seat release or latches, I just massaged the Katzkin covers on around them.
    ElNopal likes this.
  4. Oct 27, 2020 at 4:33 PM
    Danimal86
    Daniel
    Sacramento, CA
    I got it off, the factory cover wouldn't release from the seat release, so i figured the whole thing needed to come out. I ended up seeing the that factory cover was threaded through those clips. Thanks for your help.
    Patch999 likes this.
  5. Oct 27, 2020 at 8:31 PM
    Danimal86
    Daniel
    Sacramento, CA
    I'm going to move on to my next seat tomorrow, if I go with one of the fronts, what orientation should I put the seat in before I disconnect it? Just normal fine, or should I tilt it forward or back?
  6. Oct 27, 2020 at 9:46 PM
    Armstrs
    Armstrs New Member
    Steven
    East Texas
    2017 Silver CrewMax 5.7L 4x4
    Amp research power steps OEM tow mirrors OEM tonneau cover TRD Sway Bar Black Texas Lone Star plates :) Auto tail gate lock KB Voodoo 22” aluminum bed rack TRD Pro headlights Katzkin seats Black badges
    I left the seats as they were sitting normally. I did the drivers seat while it was together but the passenger side I separated the seat back from the seat bottom. It was much easier to get a good fit while it was separated and it was easy to put them back together. I wish I would have done the drivers side the same way instead of trying to shove the covers through the crack between the halves.
  7. Oct 28, 2020 at 4:20 AM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    I leaned the drivers back far enough for me to push my hand between the top and bottom. It wasn't all the way back to keep it sitting upright when I needed it to. My passengers was manual and I did it first so I had an idea of how far back it needed to go with the drivers before I killed the battery again.
  8. Oct 29, 2020 at 12:52 PM
    Danimal86
    Daniel
    Sacramento, CA
    How on earth did you guys get the bottom zipper on the front seats to close? I'm not even close, about 4" shy.
  9. Oct 29, 2020 at 1:14 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    I didn't at first. I had some better luck on the passengers side still didn't get zipped all the way. My drivers was about that far apart. It covered with the flap so I left it that way. A few months later I remembered that I hadn't zipped them and I guess it loosened up. I was able to get them zipped after some pulling and a warm day.
  10. Oct 29, 2020 at 2:02 PM
    Danimal86
    Daniel
    Sacramento, CA
    I think i'm going to have to do the same. I'm worried if i pull any harder it'll rip something. I'll probably leave it unzipped for a while and re-visit it.
    Patch999[QUOTED] likes this.
  11. Oct 29, 2020 at 4:00 PM
    Danimal86
    Daniel
    Sacramento, CA
    So i've left the headrests for later because i dont really get how they attach. Happen to have any pictures?
  12. Oct 29, 2020 at 4:12 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    I'll PM you some pics. Let me find them.
  13. Oct 29, 2020 at 4:12 PM
    Armstrs
    Armstrs New Member
    Steven
    East Texas
  14. Oct 29, 2020 at 4:16 PM
    Armstrs
    Armstrs New Member
    Steven
    East Texas
    Patch999 I never did thank you for your write up. It was incredibly helpful when I tackled this project.
  15. Oct 29, 2020 at 4:17 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Glad it helped.
  16. Oct 29, 2020 at 5:29 PM
    Danimal86
    Daniel
    Sacramento, CA
    Perfect.....thanks!!!!
  17. Oct 29, 2020 at 6:43 PM
    socaltundra951
    Southern California
    Black CrewMax 5.7
    On both sides I worked at them with some plyers wrapped in towels so it wouldn't damage the leather. The leather stretched so much I swore it was going to tear but it held. I had to move the zipper along inch by inch as I worked it together.
  18. Oct 31, 2020 at 10:07 AM
    Danimal86
    Daniel
    Sacramento, CA
    Did it take a little time for the seats to soften up? I feel like it's a little flat where before the bolsters kinda held you in?
    I'm sure it just needs some time, but wanted to see what you guys experiences.
  19. Oct 31, 2020 at 10:51 AM
    #49
    sillydadztrksR4momz
    sillydadztrksR4momz New Member
    Looks great but for some reason after I pulled out my headrest in the front they won’t go all the way down they both sit like an inch up from the bottom and I used to have them all the way down. Did you have that problem? I hope not but if so any advice? It bothers me....
  20. Oct 31, 2020 at 12:03 PM
    #50
    Armstrs
    Armstrs New Member
    Steven
    East Texas
    See if when you remove the headrest if you can just pull the headrest guides out. The reason I say that is I had the same problem and found the headrest shaft was hitting the clips that hold the guides in because they were not in all the way. I had to trim some more foam around the holes before I heard the click of the guides snapping firmly into place. Just an idea. Hope this makes sense.
    You can shine a light down the guide to see what is obstructing the path.
    ElNopal likes this.
  21. Oct 31, 2020 at 12:13 PM
    #51
    sillydadztrksR4momz
    Thank you I’ll try and see if that works (hope so) the thing is I can’t even pull them out so once I can do that I’ll try your trick. At first I thought I put them back in wrong but it doesn’t look like i did. Here’s a pic passenger and driver both the same...
  22. Oct 31, 2020 at 12:20 PM
    #52
    sillydadztrksR4momz
    Ok wait I was just able to get them off and this is what I found. What is this? I mean I know it’s what’s stopping it from going all the way down....
  23. Oct 31, 2020 at 12:23 PM
    #53
    Armstrs
    Armstrs New Member
    Steven
    East Texas
    Yep! I believe those are the clips that hold the guides in place. The guide is not pushed in far enough. Once they are pushed in all the way those clips should click out of the hole. If you can’t push them in any more, you may have to trim the hole in the leather slightly.
    ElNopal likes this.
  24. Oct 31, 2020 at 12:28 PM
    #54
    sillydadztrksR4momz
    Ohhhh ok thank you so much! Appreciate your help.
    Armstrs[QUOTED] likes this.
  25. Nov 9, 2020 at 4:11 PM
    #55
    Danimal86
    Daniel
    Sacramento, CA
    Fellas....its done.
    Thanks everyone for all your advice, especially @Patch999 for answering all my questions.
    There's some little house cleaning items i still need to do. Still have to wire up the seat heaters, and next spring i'll attempt to zip up the bottoms of the front seats after they've had time to stretch.
    Now, normally i keep all my stock parts so in case i end up trading it in, i can go back to stock. I'm really tempted to put them in a steel can and BURN THEM, so there's no option to ever even think about pulling these off and putting the factory ones on! Holy hell that was a real pain in the ass. The most physically demanding piece was the front two headrests. Looking at the covers, i thought there was no way they would fit. I even tried the shop vac trick, but couldn't get it to work on those big bastards. The rear headrests were super easy.
    Its drinking o'clock....thanks fellas!
    panicman and sillydadztrksR4momz like this.
  26. Nov 9, 2020 at 4:25 PM
    #56
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Looks great Daniel. That’s a great color combo.
    Danimal86[QUOTED][OP] likes this.
  27. Nov 9, 2020 at 4:38 PM
    #57
    sillydadztrksR4momz
    Looks so
    Good. You did a fantastic job.
