Katana light upgrade. No fog lights.
Discussion in '1st Gen Tundras (2000-2006)' started by fighthedude, Nov 6, 2020.
  1. Nov 6, 2020 at 12:57 PM
    fighthedude
    fighthedude [OP] New Member
    As title states. Plugged in the katana h4 LED lights. Newer model that @Professional Hand Model recommended. I read somewhere that some people had issues with fog lights not working properly. Mine just turn on the high beams. These are the only LED lights on the truck. Also it is a 2006 double cab 4wd. Thanks
  2. Nov 6, 2020 at 1:04 PM
    Hand Protectors
    The later Gens seem to have this problem. Not sure of the fix. Resistors?
  3. Nov 6, 2020 at 1:23 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  4. Nov 6, 2020 at 1:45 PM
    fighthedude
    I pulled them in case I have to return. Sorry @Darkness
    Darkness likes this.
  5. Nov 6, 2020 at 2:14 PM
    fighthedude
    Anyone have suggestions for running LED headlights in a 2006 tundra double cab 4wd?
    pm07 likes this.
  6. Nov 6, 2020 at 2:49 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Oh I missed the issue, so you plugged them in but it just runs high beam? These should have built in drivers to regulate the power right? Maybe defective.
  7. Nov 6, 2020 at 3:41 PM
    fighthedude
    @Darkness. lows work. Highs work. When I checked the fog lights. It turned my highs on and fogs stayed off.
  8. Nov 6, 2020 at 4:16 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats very strange
  9. Nov 6, 2020 at 5:30 PM
    Hand Protectors
    This is normal in the later 1st Gens.
    Not sure if LED Fogs would solve the problem or not. The guys at HeadLight Revolution said that may be a fix.
    Keep in mind I bought and installed LED Fogs first and then did the Headlights 6 months later. When considering Headlights purchase with HR I asked if there would be a problem with the Fogs turning off (per reviewers) and they said no because they were already LED.
    Hope that makes sense.
  10. Nov 6, 2020 at 5:51 PM
    fighthedude
    Makes sense and doesn't make sense. I reached out to katana via Amazon. I'll keep digging. No problem swapping all over to LED because that was original intention. Just started with this.
  11. Nov 7, 2020 at 8:36 AM
    Gmillz85
    Gmillz85 Ski Bum Extraordinaire
    greg
    2004 Salsa Red AC 4x4 Pro Edition
    She's a Pro
    You need a resistor. It will plug into your driver's side light and correct the fog issue.
    Check out superbrightleds.com
    They have what you need for under $15 and their products are high quality.
  12. Nov 7, 2020 at 8:56 AM
    fighthedude
    Thanks for all replies. Katana is sending me a resistor to put in place. I have about $150 worth of led in my shopping cart with super bright led website to do swap over much of the truck. I need to do a test to see if my truck is a canbus system or not before I place the order.
  13. Nov 15, 2020 at 9:02 PM
    JacknIdaho
    JacknIdaho 04 Tundra SR5 Access Cab
    Idaho
    2004 Tundra SR5 Access Cab
  14. Nov 15, 2020 at 9:13 PM
    JacknIdaho
    Idaho
    I installed a set of AuxLights LED’s Headlights And Foglights bulbs in my 04 tundra and had the exact same problem. After a little research ordered a single load resister from super bright led dot co m $8.95 installed on the passenger side headlight (plug’n play) amazing what a difference these lights make, love’em
  15. Nov 16, 2020 at 4:36 PM
    Hand Protectors
  16. Nov 16, 2020 at 4:57 PM
    SouthWestGA
    SouthWestGA New Member
    Just remember resistors get hot and can melt stuff
    be mindful where you mount it
  17. Nov 16, 2020 at 7:37 PM
    fighthedude
    Affirm. Mounted to metal away from any plastic.
  18. Feb 23, 2021 at 3:36 PM
    two2cal
    two2cal New Member
    I'm pretty sure it's because of the LED fogs. I have a 2000 and just installed the Katanas and lost my fogs. Strangely, I also lost the blue "brights" light on the instrument panel.
    Can anyone link the resistor they used? TIA
    Or should I just get Katana fogs? much cheaper than anything I've seen on headlight revo
  19. Feb 23, 2021 at 4:50 PM
    Hand Protectors
    Give it a try. Better than resistors if it works. Never had an issue, yet. Switch back to your old bulbs in the Headlights and put in the LED Fogs and make sure they work proper, then put the Katanas back in. Hope it helps.
    Note: Never used Katana Fogs. Mine are High Dolla Supernovas.
    two2cal[QUOTED] likes this.
  20. Feb 24, 2021 at 9:41 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    If you decide to get the resistors contact katana and tell them about your issue. They will send you the resistors for free. That’s what I did.
  21. Feb 24, 2021 at 9:46 PM
    two2cal
    two2cal New Member
    I'm gonna do that as well just in case. I looked at superbrightled dot com and they're out of stock until late March.
    I'm in love with the Katanas. Can't wait to see how they look paired with LED fogs
  22. Feb 24, 2021 at 10:05 PM
    Toyoda Tundra
    Looks good! Here’s a pic of mine( low beams) Definitely a lot better.
  23. Feb 25, 2021 at 3:39 AM
    Hand Protectors
    My favorite lights are my Fogs SupernNovas. When I turn them off, the light is so reduced compared to before. Also, that wrap around light from the Fogs disappears. I couldn’t imagine driving just with Head Lamps.
    Very interested in seeing/hearing how these Katana Fogs perform.
    two2cal and Toyoda Tundra like this.
  24. Feb 25, 2021 at 10:19 PM
    Toyoda Tundra
    Interesting, I may consider upgrading my fogs in the future. I’m happy with my headlights for now, no problems. Thank you sir for the katanas recommendation btw!
  25. Mar 4, 2021 at 3:01 PM
    two2cal
    two2cal New Member
    I'm here to report that my Katana fogs finally arrived today. They were scheduled to arrive on Saturday but "A" listed them as lost and there was no tracking info until they were delivered today. I threw them in and to my dismay they don't work with my Katana H4s. I had already reached out to Katana and they said they were going to send me the resistor but I had my fingers crossed that they would miraculously work for me ( like PHM's). I'm thinking about just doing the anytime fog mod so I don't have to install a hot resistor near my airbox but that step by step for the 00-02 is hard to find.
    I did unplug one of the H4s and threw back in the halogen and the fogs then lit up so at least I know they're working. Pulling out the halogen then burned a hole in the rubber palm of the glove I was wearing! I'm going on vacay to Santa Fe next week so hopefully when I return the resistor is here.
    At which point I'll take pics.
    Cheers
  26. Mar 4, 2021 at 3:04 PM
    Hand Protectors
    The Secret Sauce must be in the High Dolla Fogs then.
  27. Mar 4, 2021 at 3:06 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  28. Mar 12, 2021 at 8:31 PM
    two2cal
    two2cal New Member
    True dat. Those high dollas prolly have some built in resistors or something.
    But I'm back from vacay and got the katana LED fogs installed and oh wow. I thought just the low beams were rad but these things light up both shoulders of the road. I have been driving around at night as much as I can the past two nights and so far no flashes. I asked my gf to drive opposite of me and she said they look "normal" from her perspective.
    I had to break out the DSLR because phone cameras never maintain the same ISO, shutter and Aperture. I wanted these photos to be as accurate as possible so that you all can see the difference these fogs make. For $35 they are rad. "A" actually refunded me because they were lost in the mail for a couple of days but I'll definitely order again when I need to. Katana sent me 2 resistors and I used metal zip ties to attach one to the metal body above my driver side light housing. No issues and everything works again like normal. Highly recommend.
    Lights looks slanted cause fence slats are level and driveway is sloped. Also, fence is approximately 30ft away from headlights
  29. Mar 12, 2021 at 8:58 PM
    Toyoda Tundra
    They look good!
  30. Mar 13, 2021 at 5:30 AM
    Hand Protectors
    Nice. We have an unfair advantage with our Sweet Chrome Wraparound Front Bumpers. The Fogs design on the 00-02 is far superior than the later years. Your lighting looks nice. The High Dollas might have a little better output, but these are close.
    Tundra2 likes this.
