K an N air filter
Discussion in 'Performance and Tuning' started by Steplift20, Apr 28, 2021.
  1. Apr 29, 2021 at 6:05 PM
    Azblue
    The Dirty T ( ^_^)_且
    Good points, but on this we will have to agree to disagree. Like I said, I have used K&N filters in my area and have seen the dirt they let pass. I've never seen evidence of dust getting past a paper filter.
    Vizsla and Black Wolf[QUOTED] like this.
  2. Apr 29, 2021 at 6:12 PM
    Vizsla
    Vizsla 2 = 2.5
    Me too. Ran the PG-7 on turbos at 50ish psi, no dusting always clean but not much off-road. These are very good filters also, never used on a Tundra, but a few F-150’s that weren’t slow.
    https://greenfilter.com/store/7290
  3. Apr 29, 2021 at 6:16 PM
    Use what is best for you. Keep in mind I never once claimed that K&N's are the best filter. All filters pass particulates even paper filters otherwise there would be no airflow. No vehicle air filter has surgical mask specs. When you get down to less than 20 microns, any dust/silt that small that will be instantly pulverized to oblivion before doing any damage. Science......
  4. Apr 29, 2021 at 6:21 PM
    S&B has the best filter efficiency in the business. They make mil spec filters for helo's and Abrahm tanks that are/were used in the middle east invironment. Alas....no drop in for us civilian peons!
  5. Apr 29, 2021 at 6:35 PM
    Vizsla
    Vizsla 2 = 2.5
  6. Apr 29, 2021 at 6:47 PM
    The Volant has great efficiency specs and a very good testing protocol like S&B has. You run a lot in extreme conditions so naturally you want what works for you. All of you folks here that run the desert a LOT definitely want good filtration and good cameras for the anti gravity situations....ha!
  7. Apr 29, 2021 at 6:49 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Stick to paper. Not worth buying a reusable filter. Their not cost effective till 90K if you replace a paper filter every 30K. Plus depending on environment it maybe sooner than that.
  8. Apr 29, 2021 at 6:51 PM
    Millions of folks that use reusable filters would disagree.....just sayin. Decent Purolators run around $20. Replace every year. Adds up unless you buy cheap paper filters.
  9. Apr 29, 2021 at 6:52 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Millions of folks are wasting money and don’t have a clue...just sayin. Regular filters will filter far better that reuseables.
  10. Apr 30, 2021 at 5:54 AM
    Steplift20
    Steplift20 [OP] New Member
    2018 Tundra
    From what I have been reading it seems that the best air filter is the OEM .
