just replaced the air flow sensor and now getting 2 new codes
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Bear_Murray, Apr 24, 2021.
  1. Apr 24, 2021 at 8:13 AM
    Bear_Murray
    Bear_Murray [OP] New Member
    Logan
    2016 SR5 Black Tundra
    NONE YET
  2. Apr 24, 2021 at 8:19 AM
    Bking
    Bking New Member
    B
    New York
    TRD PRO
    Check your vacuum hoses
  3. Apr 24, 2021 at 10:56 AM
    Bear_Murray
    Logan
    NONE YET
    on what part?
  4. Apr 25, 2021 at 12:53 AM
    Bking
    Bking New Member
    B
    New York
    TRD PRO
    Disregard. (1) I thought maybe you knocked loose a vacuum hose while replacing the mass air flow sensor. (2) Code is rich NOT lean. A lean code can be caused by a vacuum leak. Sorry and I hope you resolve.
  5. Apr 25, 2021 at 1:10 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Did you use a factory part or aftermarket? This is a common issue with aftermarket
    Rex Kramer likes this.
  6. Apr 25, 2021 at 3:57 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    If it's an aftermarket sensor, replace it with OEM right away.
  7. Apr 25, 2021 at 6:57 AM
    Bear_Murray
    Logan
    NONE YET
    i have a K&N cold air intake and i replaced the air sensor with a duralast (from Advanced autoparts), the 172 & 175 are different codes after i switched air flow sensor.
  8. Apr 28, 2021 at 9:08 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Did you replace it while the battery was connected??? If yes, then it may be a "ghost" code... Make note of the code, then try disconnecting the battery, or clearing the codes and restart the truck and see if it comes back.
