Just got truck back from shop..wheels & tires
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraCoast, Mar 18, 2018.
  1. Mar 20, 2018 at 6:33 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    The previous owner of my truck must have had a light installed here too. My lower grille insert is missing. I have a big 30" two-row rough country light bar mounted on my roof rack I would gladly trade for this set up. Mine is in the way of me being able to use my fly rod rack as is.
    RNBKTOY likes this.
  2. Mar 20, 2018 at 8:02 AM
    SuaveRC
    SuaveRC New Member
    Great job on the truck. I didn't know you can powder coat whellw. I may see of someone can paint my wife's 4runner. Is it your local paint shop?
  3. Mar 20, 2018 at 9:37 AM
    TundraCoast
    TundraCoast [OP] Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    The rear bumper flush mount lights are Rough Country Black Series the inner-optics housing is black, rather than chrome Part # 70803BL.
    They were about $70 for the kit which includes lights, harness and template (used to mark the hole you will cut). Two options on wiring, you can wire up to each tail light and use t-taps to connect the neg & pos its that simple, the rear lights come on when you select reverse. Alternately, you can run up to font of truck snd mount a switch and control them independently. The harness teach light has nice waterproof connectors, I just cut it with enough length to reach each tail light used so zip-ties nice and clean. 1440 lumens per light with a 30 degree spot which works perfect for a low but wide light pattern behind truck (I also upgraded my tail light back up bulbs with super bright LED bulbs. I like that the added light, it makes the back-up camera perform (close to) as it does in day light,
    Now the part that took quite a while to get just right, you are cutting through the plastic outer-cover and inner metal bumper which is a huge PITA. No matter what combo of tools (3" cut-off wheel, autobody jig saw, Dremel, drill, hand file) I had to fine tune the opening to get the lights to sit flush, the flange on the lights doesn't leave a lot of room for error so a smaller cut with power tools then refine with a a new and or sharp heavy duty file is what I found works best.
    (note: some owners will have just the metal bumper end caps that might simplify the process a bit, fine-tunning the hole is always a pain if you know what I mean)
    I measured 3-4 times per hole before I cut or did anything. The kit provides (1) cardboard template. I would make a second one out of an old box before I tape and mock up the first one. Placement is personal preference however, there is a limited area where they will sit flush due to bumper curve and contour so find the "flat-spot'
    Mid project, I used black rustoleum paint with a small brush and painted the hole I cut in the metal inner bumper for rust resistance
    Final result, I bought black hex bolts to go with the "black series theme", ss-washers & nylock nuts for the back side, the lights look OEM in person, really smooth and rock solid.
    jewsNbrews and B737 like this.
  4. Mar 20, 2018 at 9:48 AM
    TundraCoast
    Ian
    California
    1794 4x4
    I have had a bunch of factory and after market wheels and other parts powder-coated over the years, its cost effective and holds up really well. Look for a dedicated powder-coat shop in your area, they can coat anything metal in a hundred different colors and textures.
    The plastic center caps on most Tundra OEM wheels will need to be color matched via painting. Not a big deal you can rattle can (make sure you prep- and adhesion promote really good) or have a auto body paint shop color match. On this truck I had the center caps professionally color/texture matched and painted. Went another step further and had the Toyota emblems on the caps painted Silver Sky Metallic.
    Not the best pic but this is the end result.....I have "color lug" black lug nut covers, they work great. here is a link: https://www.colorlugs.com
    RNBKTOY likes this.
  5. Mar 21, 2018 at 10:59 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    So what tire size are you running now on the oem's and 5100 on top setting?
  6. Mar 21, 2018 at 11:39 AM
    TundraCoast
    Ian
    California
    1794 4x4
    Running
    Toyo RT's 275/65/20 next week moving to 295/55/20
    Suspension Setup
    Rough Country 3.5" Kit
    RC Upper Control Arms
    RC Nitro 2.0 shocks front & rear
    CB adjustable shackles rear
    TRD swaybar rear (installing TRD front bar)
  7. May 17, 2018 at 11:57 AM
    supertran82
    supertran82 New Member
    Man
    DFW
    2024 Black Platinum Tundra
    got any pics with the new tires? Very tempted to powder coat mine as well but I am also wanting to install the fender flares and want the tires to stick out to at least be flush with the flares. I think the stock wheels offset won't allow that. But yours looks great so if I follow your path I guess no fejder flares lol. Not wanting spacers either
  8. May 17, 2018 at 1:17 PM
    JCTundra2323
    JCTundra2323 New Member
    2018 Toyota Tundra TRD
    33” Nitto ridge grapplers on 20”/12” fuel coupler +20 offset 2 1/2 front level Running boards
    Looks good, is your ride lifted at all? and what trimming do you need to do so you fit the 295/55/20 ?
  9. May 17, 2018 at 6:06 PM
    TundraCoast
    Ian
    California
    1794 4x4
    The offset on the factory wheels (even with large tires) will sit inboard if you add fender flares. I had the same setup on my last tundra and added 1 1/2" spacers. Looked great. In your case you don't want spacers so maybe aftermarket wheels.
    supertran82[QUOTED] likes this.
  10. May 17, 2018 at 6:09 PM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    Looks very clean :)
    TundraCoast[OP] likes this.
  11. May 17, 2018 at 6:18 PM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    love the smell of new tires.
  12. May 19, 2018 at 12:42 PM
    Paul84
    Paul84 New Member
    Paul
    2014 4x4 Crewmax
    Looks very nice.
  13. May 19, 2018 at 4:04 PM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    I like the look of your rig.I'm trying to decide what lift and tires I want for my '18.Considering a 285/65/20 Nitto.Not sure yet what lift .
  14. May 19, 2018 at 6:46 PM
    Rica25
    Ricardo
    Tulare
    How you like those step bars?
  15. May 19, 2018 at 7:14 PM
    Audie
    Audie New Member
    Audie
    2018 Tundra TRDOR Crewmax Super White
    Came out great. Love the tail lights.
    jewsNbrews and TundraCoast[OP] like this.
  16. May 19, 2018 at 8:10 PM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    I love the front end. Very tasteful.
    Wheels came out good.
  17. May 20, 2018 at 1:26 PM
    TundraCoast
    Ian
    California
    1794 4x4
    Step bars are rock solid, Westin HDX series, satin black textured finish, easy one person instill. I had the nFab steps on last Tundra and loved those too, wanted to change it up on the truck.
  18. May 20, 2018 at 1:29 PM
    TundraCoast
    Ian
    California
    1794 4x4
    New tires are the best, Tire dressing companies should have "New Rubber" smell rather then all the BS scents normally
    Tony v[QUOTED] likes this.
  19. May 20, 2018 at 1:33 PM
    #49
    TundraCoast
    Ian
    California
    1794 4x4
    I like the lighting in this pic, makes the front end look milled from metal
  20. May 20, 2018 at 1:56 PM
    #50
    Pale_Horse
    FL
    Cupcake chit.
    Yea. It has me seriously debating color matching the pro grille on my cement taco...:spending:
    Thanks a lot :rofl:
    Pudge likes this.
  21. May 20, 2018 at 2:01 PM
    #51
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Me too. This front end has had me thinking that same thing for a while now.
  22. May 20, 2018 at 2:08 PM
    #52
    Looking very good!
  23. May 21, 2018 at 6:43 PM
    #53
    Tundrastu
    Tundrastu New Member
    Stuart
    Kentucky
    2016 Tundra Platinum Crewmax
    HID retrofit headlights from Lightwerkz, Morimoto LED fog lamps from Lightwerkz. JL audio upgrade from Tech12Volts, Powdercoated factory black wheels local, ESP rear storage trays under seat, bed cover by BakFlip, bed liner, console safe, LED light bar by Back Country. Weathertech floor liners and ventshades. TRD rear sway bar. TRD Pro exhaust, TRD Skid plate, Fortin EvoOne Remote start from Anderson Electronics.
    I had my wheels powdercoated as well, a gloss black though. I like the look on a good off-road tire. I went with the Micheline tires this go around, but I might have to swap out.
    Nice truck,
  24. May 22, 2018 at 10:12 AM
    #54
    RNBKTOY
    RNBKTOY New Member
    2008 Toyota Tundra TRD SR5 5.7L
    Powdercoated 2018 TRD Wheels, Blacked out Badges, Spec-D Tuning Headlights
    Your new wheels look great!!!!! I recently had my TRD wheels powder coated a low gloss. I looked into the color lug nut covers because my friend had purchased them. His rims have more of a high gloss finish. My fear is the lug nut covers and going to have to high of a finish. Are you happy with yours? I wish they came in a more flat black color. I'm very happy how my rims turned out. Tempted to keep them chrome to match the rest of the chrome on my TOY.
    Hammerhead, hi_rawb and 040Tundra like this.
  25. May 22, 2018 at 10:52 AM
    #55
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    BADD ASS MAN! What size rim and tire?
  26. May 22, 2018 at 11:16 AM
    #56
    RNBKTOY
    RNBKTOY New Member
    Thanks!
    18” wheel, wrapped with 275/65/R18 Duratracs tires.
  27. May 22, 2018 at 3:58 PM
    #57
    MrAJ
    MrAJ Toyota Enthusiast
    AJ
    Cathedral City, California
    2018 White Tundra TRD 4x4
    Truck looks nice! What side step are you using there?
  28. May 22, 2018 at 4:03 PM
    #58
    TundraCoast
    Ian
    California
    1794 4x4
    Westin HDX step (textured black finish) bolts into factory locations on the frame
  29. May 22, 2018 at 4:39 PM
    #59
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Nice truck! I gave me a few ideas of my own.
  30. May 22, 2018 at 8:51 PM
    #60
    Gatire
    Gatire New Member
    2014 Tundra
    Hey your truck looks great. My last truck was silver.
    Any part number on the taillights?
