Just got hosed on a 1st Gen Tundra (HELP!)
Discussion in 'General Tundra Discussion' started by RobR78, May 21, 2021.
  1. May 22, 2021 at 10:03 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I would Go after the guy simply to save next person. This isn’t his first time.
  2. May 22, 2021 at 10:16 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    you can most likely pull the title hx and if the title when he bought it reflects anything at or above 150k then you should have a leg to stand on.
    sucks you got carfax after sale
    I bought an impreza in HS with a known "TMU" on title
  3. May 22, 2021 at 10:25 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    It doesn’t require an ECM (on the tundras) - mileage is stored in the instrument cluster. Swap in a cluster from a junk yard and done.
    I swapped my 2008 out for an optitron (Limited) gage cluster and had to find a place that could flash the correct mileage onto the cluster so that I could keep it square. For the guys that do it, it’s a pretty easy job with the gear they have, but costs about $150 around here.
  4. May 22, 2021 at 10:26 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    The only bad thing is you are stuck with a truck with a mileage discrepancy - might be harder to sell. I’d at least report the dude so he doesn’t do it again.
    Leo's first likes this.
  5. May 22, 2021 at 10:30 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    You have a lot of good documentation there. You may want to contact your local sherriff's office. The DMV also has a dept that handles fraud. From what I'm seeing here, this was intentional but keep in mind people flip titles. Mr. Guzman may have not been the person who sold you this vehicle. For those that don't know, both parties should fill out the transfer of ownership in its entirety before leaving and verify identities. These are mistakes we only make once, don't let it get you down. You lost some money but on the bright side, its a 4.7 Tundra, its still got a lot of life left to give you.
  6. May 22, 2021 at 10:37 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Obviously some big red flags here which you acknowledged should have been identified before the purchase in your original post, but it definitely sounds like this guy committed fraud. If you can track him down, and he is actually who he says he is, then you probably have a case. My guess is "Juan" at that address isn't the guy you dealt with and "knows nothing" about the whole thing. Good luck!
  7. May 22, 2021 at 10:47 AM
    See what your options are at the DMV. I would go after him with everything I could as I cannot stand thieves and those who try to take advantage of someone like this
    Barrett50, MS22, Terndrerrr and 6 others like this.
  8. May 22, 2021 at 10:49 AM
    Oh wow! So super easy to do. Thanks for the tech. Learn something new everyday.
    OP, would really turn this POS into the authorities.
  9. May 22, 2021 at 11:37 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah - it’s a ROM chip in there that stores the info. The crook here may have just as easily reflashed the ODO himself or had a friend do it.
    for sure I’d be exploring options with the DMV and/or sheriff’s office on odometer fraud. Even if you keep the rig, hopefully can keep the shitbag from doing it to someone else.
  10. May 22, 2021 at 11:56 AM
    RobR78
    RobR78 [OP] New Member
    Rob
    2005 Tundra
    I’ve made contact with Mr Guzman, he’s going to help me with this. He’s not responsible and is a straight shooter. The guy he sold it to is the scumbag who tampered with the odometer. I wouldn’t be surprised at this point if the title I have is fake. I’ll sort it out at the DMV on Monday. And yes absolutely I will report this to make sure “Domingo” Perez is held accountable. I’ll update what happens at the DMV.
  11. May 22, 2021 at 12:27 PM
    18" TRD Off Road Wheels
    May want to edit your photos to hide the personal info on the documents. Doxing isn't a good thing.
  12. May 22, 2021 at 1:03 PM
    If you find "Domingo", ask if he has any spare cats........and quite frankly I wouldn't trust Juan either. This whole thing is quite shady from the git go. Kali DMV WILL persue blatant fraud. Altered paperwork/misleading info on official State issued documents=jail time and a hefty fine. I hated San Fernando Valley....
  13. May 22, 2021 at 1:13 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Maybe I missed it but there is no odometer reading on the title. The DMV probably couldn't care less if you bring information from carfax and a smog shop saying the odometer doesn't match.
    You bought a older toyota in california with high resale value, fraud is abundant. Unfortunately you got scammed. This is why you have to be more thorough when buying a vehicle like this. 15 year old truck with 100k less miles than 95% of the other 15 year old Tundras for sale? Pay for the Carfax before handing over money. Study the truck looking for collision damage, body work, and mismatched parts.
    I would probably just let the odometer issue go. You have other issues to worry about like title fraud or passing emissions. Have you checked to make sure the VIN on the truck matches the title?
  14. May 22, 2021 at 1:20 PM
    Kali Smog Check stations are licensed by the state. They issue official state Smog documents. They must record what they find as in an odometer discrepancy. They could lose their license to operate if they didn't. Of course Kali DMV will be quite interested indeed. I'd persue this in a heartbeat .
    TaquitoBandito likes this.
  15. May 22, 2021 at 1:23 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I completely agree with you on everything.
    But, yeah you missed it…or “half assed” read it. Mileage is on the transfer part of the title.
    Black Wolf likes this.
  16. May 22, 2021 at 1:25 PM
    Yep, always is. TO HELP PREVENT AGAINST FRAUD...heh...heh:thumbsup:
  17. May 22, 2021 at 1:43 PM
    Half Assed
    Heartland Florida
    That's the odometer reading written for the sale to the OP. I want the odometer reading from when it was sold a month ago (another huge red flag).
    Maybe California doesn't list that information on their vehicle titles. In Florida they do.
  18. May 22, 2021 at 1:47 PM
    Ahhh.....OP posted the pic of the altered Smog certificate dated.....a month ago....which is submitted with the title as in most states to get your vehicle registered...smh
    Every state has a grace period before another smog check is required.
  19. May 22, 2021 at 1:49 PM
    #49
    Half Assed
    Heartland Florida
    Carfax shows entries in past years in the 200k mileage range. The title was transferred on 4/19/21. On 4/20/21 the odometer was read at 270k. Now it's 150k.
    OP says the previous owner didn't tamper with the odometer and he says it was the guy before him. Yeah bullshit on that. The previous owner bought it, flipped it in a month, and scammed OP.
  20. May 22, 2021 at 1:55 PM
    #50
    I think the OP was saying the guy on the title is not who he bought it from. That the guy he sold it to swapped the odometer and then sold it to the OP.
  21. May 22, 2021 at 2:01 PM
    #51
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Sucks when shit like this happens, but you got to ask yourself... did you get a Tundra that you wanted at a price you were happy with? Sure, if you had known you could have gotten a better deal but... lesson learned, good money after bad yada yada... You still got a nice truck, and if you can find the guy, we'll all swear you were out wheeling with us when you get your 2 pounds of flesh. :D
    RobR78[OP] likes this.
  22. May 22, 2021 at 2:05 PM
    #52
    Half Assed
    Heartland Florida
    I read that incorrectly then. If that's true OP should have walked away at that point. If you're not buying from the person listed on the title, walk away. Or let them straighten it out by transferring the title into their name like they were supposed to and then buy it.
    I almost got burned that way buying a truck in highschool. Previous owner was dead. Thankfully his family helped me get a valid title.
  23. May 22, 2021 at 2:05 PM
    #53
    glowblue
    VA
    Bottom line: it’s shady, and needs to be reported. It’s shit like this that I rarely buy used, and if I do, I run multiple checks. I was looking at a used car and ran an AutoCheck report that showed no accidents. Carfax showed an accident.
    RobR78[OP] and Black Wolf like this.
  24. May 22, 2021 at 2:18 PM
    #54
    Yeah, the guy on the title seems to be in the clear. My bag on that. "Domingo" needs to be found. Not looking too good come to think of it. Gone with the wind comes to mind. Maybe Juan can shed some light.
  25. May 22, 2021 at 2:30 PM
    #55
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Hehehe. “Domingo” Perez has been canceled on Tundras.com:gossip:
  26. May 22, 2021 at 2:48 PM
    #56
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I may be the only one who feels this way, but other than reporting the POS that did this, hopefully nailing him to the wall, the other preventive action you can take is to never buy a vehicle from Craigslist. I truly believe that for every honest person on Craigslist, there are a dozen crooks.
  27. May 22, 2021 at 2:53 PM
    #57
    Yep. I ordered a Jabba the Hut pizza yesterday afternoon. Carryout. When I went to pick it up.....I lifted the hood of the box to see if what I ordered was what was in the box and matched my receipt before I claimed it. I'm old and have learned from experience. Sucks that the OP had this happen. I'm pretty much easy going but don't cross my ass. I'd be checking back in with "Domingo"....legally of course......:anonymous:
    TaquitoBandito and Bakershack like this.
  28. May 22, 2021 at 3:00 PM
    #58
    Just like used car lot salesmen....ha! All about due diligence no matter who you might be buying anything from.
  29. May 22, 2021 at 3:14 PM
    #59
    RainMan_PNW
    Casey
    Clark County, WA
    That’s because everyone knows you always get fucked at the drive though
  30. May 22, 2021 at 3:18 PM
    #60
    jwatt
    jwatt I heart men
    Jack
    Oregon
    My last 2 vehicles have been from craigslist. I made sure I personally inspected them, and had a dealership also inspect them. It cost me a bit more, but they both were good transactions. One thing of note; I always like to deal with a couple rather than just one person. It gives me a better feel for the situation. Also I like to look for that little fish on there car bumper.
    Bakershack likes this.
